Question about Hoover HTC243 Top Load Washer
Hoover Premier 710 - always fills to capacity (can't adjust water level).
I've been coping with always doing 'full loads', but my last load overfilled and flooded, so I think I will need to get something fixed. I've tried fiddling with the appropriate dial and pipe, but it didn't do anything. Any thoughts, or is it worth getting a new washing machine?
    Problem Solver:
  • 21 Answers
My one the same, I just adjust the water level switch to 60% then it work on full level, but no flood,I hope this help :)
Posted on Apr 04, 2010
Hoover premier 710 washing machine out of balance
WHAT IS WRONG WITH YOUR WASHING MACHINE?
small_11_21.jpg For a detailed Washing Machine illustration, click below.
redarrow.gif Top Load Maytag Style
redarrow.gif Top Load Whirlpool Style
redarrow.gif Top Load GE Style
redarrow.gif Front Load Maytag Style
redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
Jul 24, 2008 | Washing Machines
FILL CAPACITY
your machine has a pressure switch to tell it what the water level is-if it is overfilling make sure the small hose attached to the tub is not clogged-it may even be the fitting it attaches to is clogged-what ever you do don't give up your old machine-the new ones won't last as long or wash your clothes as good-cheers Denny
Oct 26, 2013 | Roper RAB2121KW Top Load Washer
Machine fills for about 10secs then stops and cycle begins.
Check the water level indicator not, make sure it is at full load. Also is the load balanced.
Nov 03, 2012 | Hoover AAA160 Front Load Washer
Wash starts before water is full
most washers if put on a large load do start going around before the water has finished filling this is just to get all the clothes fully wet before the proper cycle starts to wash them it is just how the washer copes with a large load peter
Nov 06, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Roper Top Load Washer Does Not Fill To The Top on ''Extra Large''
the water level switch can be adjusted to raise the water level but is not recommended. The level you have is normal.
Jan 24, 2009 | Roper RAS8445KQ Top Load Washer
Kenmore 80 Series - water wont fill to full load
remove edge decore trims from left and right side front of control panel8b608f8.jpg
remove phillips screws from bottom corners of contol panel
remove knob from water level selector
raise control panel ~1 inch then flip over backwords on pivots
depress lock tab on right/underside of water level control body where it touches metal mount plate
rotate water level control body 45deg anti clockwise
pull body off
top side of body next to knob shaft is 1/8 hex head bolt
turn clockwise to rais water level
anticlockwise to lower water level
machine can be operated with this part not fitted so can check level. fill, adjust screw, fill will start again, adjust screw, until water level is correct
reinstall in reverse order
Incidentally, the cause is a VERY small wire spring inside the control body that is not really up to the task, and stretches over years.
Its a common occurrence, and I make this repair, on callouts, no parts required, couple times a month you may have to flip the switch to reset to get the water to restart filling
Oct 25, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool washer
I'm assuming you have a top load Whirlpool washer with buttons and knobs, instead of electronic controls.
There are some things that will cause a washer to overfill. The only one that will cause it to underfill is the pressure switch (water level switch.)
Some older machines (15 yrs+) have a ***** on the back of the pressure switch to adjust for the fullest load. If that ***** has moved, that would explain the lower levels. If the pressure switch is plastic (nearly all newer models,) the switch is not adjustable and should be replaced.
Mar 11, 2008 | Washing Machines
Hoover HTC243 Top Load Washer Logo
538 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
Chris Hall
Chris Hall
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
