Question about Refrigerators
Fridge wont defrost and the silver wire going to a round silver thing in the fridge is off
Magic chef fridge
  • muskox Apr 30, 2008
    the silver wire in the fridge is going to a silver small round shaped thing what is it the thermostate. the wire more like hard wire is off is this why my defrost wont work ty
  • 172 Answers
It sounds like your thermostat sensor is what you are referring to. It should run to a small 1 inch piece of alluminum that keeps an average temperature. That makes your refrigerator stay more constant. That would not cause your refrigerator to have a defrost problem.
The three main parts of the defrost system are the defrost heater, the defrost thermostat and the defrost timer. One ore more of these are almost always the problem.
Please send us more information and we can narrow it down. Good luck. mca0824@aol.com
Posted on Apr 30, 2008
Ticking sound is this the defrost timer on magic chef fridge
Sound like the defrost timer. Just get unit info and grab a new one and replaced. They are very simple to do
Jun 01, 2017 | Magic Chef Refrigerators
My magic chef rb193p fridge wont stop running. I replaced the fan motor 4 months ago. The top of the fridge compartment is freezing. Is the defrost timer bad?
I had the same problem. When the evaporator heater stops working, frost will build up until there is no air flow to the refrigerator. This will cause the refrigerator to keep running. Remove everything from the freezer and remove the pan at the bottom and see if there is a frost buildup. .... Bruce
Jun 18, 2011 | Magic Chef CTB1922 Top Freezer...
THE FREEZER WORKS BUT THE FRIDGE PART DOESN'T. IT'S THE SMALLEST SIZE 2 DOOR FROST FREE MAGIC CHEF FRIDGE. ABOUT A YEAR AND A HALF OLD. WHAT SHOULD I DO?
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 16, 2010 | Magic Chef Refrigerators
Water collecting on shelf above veggie drawer in Magic Chef refrigerator
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Oct 15, 2010 | Magic Chef CTF2125 Top Freezer...
Magic Chef fridge, freezer compartment leaks water (side by side). Can't find a drip pan anywhere on fridge.
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 08, 2010 | Magic Chef Refrigerators
My brand new Magic Chef MCBR415SF Refrigerator is building up frost in both - fridge and freezer compartments. Is it normal?
it is not normal . the old saying ( frost clear .) it say's something right .. so you have a defrost problem with this unit look for heater system / defrost terminator / and the timer or what most use is adative defrost control / a pc board . that knowes what is going on .. mm hope this helps ..
Aug 17, 2010 | Magic Chef CTB1502AR Top Freezer...
I have a 13 month old apartment size Magic Chef refrige. It stopped geting cold about 1 month age. I uplugged and it work fine for until now. Same thing. Left it unplugged for a while and now it works...
The fault is very much with the auto defrosting of your fridge. When the firdge stops cooling you are unplugging the fridge to allow it to defrost. As there is so much frost in the cooling coils there will not be any convection of the cool air from the coil as it gets blocked. So after defrost the coils get cleared and works fine till the next time frost appears. So first of all remove the freezer compartment rear covers to access the cooling coils, check for break in wires to thermostat, to the deffrosting heater or open coils in the heaters.Now trace the wires to the defrosting timer which is a 8 hours timer for defrosting the coils by the heaters. You can see if the timer is working. Now one of these could be the culprit but you will have to make sure by testing each one and confirming before replacing. Please do this step by step. Hope you get it right. If not familiar get help. Good day
Aug 03, 2010 | Magic Chef CTB1821AR Top Freezer...
Just bought magic chef ctf2124ar fridge. cannot
Not a bad refrigerator I work on them for a living they have put out decent products in the past. Magic chef was made by maytag in they past probably a wpl made product now. Its probably got a calrod defrost heater and an embraco compressor two good things to have. Stick with it.
Jan 22, 2010 | Magic Chef CTF2126AR Top Freezer...
Side by side Magic Chef refrigerator. Freezer
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Could also be begining of a defrost problem.
Jun 14, 2009 | Magic Chef CTB1821AR Top Freezer...
Fridge is not cooling or freezing
can you tell me the model # on the fridge please? the motor is running continuously because it's trying to cool the fridge. it may be a few things, the defrost thermostat, the fan motor itself or the compressor.
Sep 13, 2008 | Magic Chef Refrigerators
Open Questions:
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
