I restored my modem and I lost my verizon connection
    Scholar:
  • 115 Answers
Ok there are few steps to solve the problem
  1. goto My network places and make the connection
  2. double click the make new connections and select which country and enter zip code of your country. and select tone or pluse.
  3. enter the new connetions.
  4. After finish that the window comes like welcome to network connections wizard.
  5. choose which connetions you are using like dial up or boardband connetion which high speed
  6. follow the wizards and select the region and connetions of which type internet and zip code.
These are modem connetions of intial part of the connecting the internet.please inform me any other .
Posted on Apr 30, 2008
How do i restore internet connection please
Restore Internet connectivity ' AVG
https://support.avg.com/SupportArticleView?...Restore-Internet-connecti...
To restore lost Internet connectivity please follow these steps: Restart your modem: - Unplug your modem/router from the power supply.
Resetting an Internet Connection (Flush DNS) ' Learning ...
247support.custhelp.com/.../resetting-an-internet-connection-(flush-dns)
Nov 22, 2015 - To correct it, please flush and reset the DNS by following the instructions below. You may also need to restart your modem and/or router ...
Fix Problems With Your Internet Connection - YouTube
? 6:35
https://www.youtube.com/watch?v=JgkX7XOZ71Q
Dec 21, 2015 | Internet Computers & Internet
NEDD TO REINSTALL VERIZON DSL BUT LOST
You have to connect to the computer to the modem directly. Turn off the firewall program. There should be a reset button located on the back of the modem. Push and hold the button for thirty seconds. After the thirty second the modem should reboot. After the modem reboot, loard any browser and the verizon online should take on it own.
Sep 28, 2009 | Westell Wirespeed LiteLine 6100...
Lost internet connection,verizon guess was the card was bad
First thing are all the micro-filters installed and in the correct direction? If they are then it sounds like your DSL signal is borderline and when the phone rings it is getting knocked out. If that is the case you will need a tech to come out and test the line.
Sep 10, 2009 | D-Link DFE-530TX+ Fast Ethernet PCI...
Intermittently lose internet connection with my Westell 7500 DSL Router. Power, E4 Port, Wireless and DSL LEDs stay on but the internet LED goes out. Verizon has replaced the router but the problem...
hi,
I used to work for verizon for two years as level 3 support,here is the thing,if verizon already replaced the modem,that means that its not really the modem,its the connection,thats what we call intermittent route,here is what you are going to do,contact verizon,have them run an intermittent connection line test,tell them that internet connection is not consistent,they will create an active ticket for you,it will be forwarded to the central office and the central office will run a different test,thats what we call a test assist...they will be able to verify if the problem is the line form the central office going to your house...
thanks and God Bless
Jun 24, 2009 | Westell Wirespeed VersaLink...
I have DSL/verizon,modem 6100F i keep loosing my internet connection
Your problem definitely sounds like an intermittent connection problem. It can either be one of two things. #1. You have a defective modem, or #2 It's a network problem. I will definitely go with #2. Here's the thing. The problem you have is very very very common not only to Verizon DSL customers, but also to other Internet Service Providers as well. The best way to fix the problem is to understand what's causing the problem. There are two types of intermittent connection problems. The first is Intermittent Sync. You'll know if you have this problem because the DSL light will be blinking everytime you get kicked out. That means there's no internet connection, The modem cannot detect and establish a connection with the Central Office. The second is Intermittent route (which I know is you're problem), The DSL light is steady, but the Internet light almost always turns OFF or turns RED. The only way to fix this problem is to coordinate with Verizon. The reason is because the problem is outside your house. The long cable lines, the drop wire, the cables that passes through from the Central Office to your House can all be damaged, If that's the case, then a technician is required to go out and fix the problem. Don't worry about calling Verizon, this is a network problem and you won't be charge for anything. I know losing internet connection is very frustrating. Give your ISP a chance, they will definitely fix the problem if you give them the opportunity to do so.
May 28, 2009 | Westell Wirespeed LiteLine 6100...
Can I use AT&T 2WIRE 2701HG-B DSL to ant ISP?
look if u wish to go for verizon service,,they will provide u with a wireless modem as well,,but if u tell them that u hav a modem then they might configure this modem only,,both ATT and verizon are DSL service providers with PPPoE connections.the only thing u need is the username and passwrd from verizon which u have to setup on the first page of the 2wire setup page,,both the connections are dhcp based.so no other connection settings change required.But when u talk with verizon make sure u tell them of the 2wire modem
Moreover verizon has wireless broadband service which is actually a express card tat u have to put into your computer and u can go online anywhere u go within ur country{it works like a mobile phone}
best of luck,,keep me posted
May 14, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Wireless connectivity with Vista
since you have verizon modem wireles router..
i have the same issue with the same model...I call verizon and tell the issue...verizon accepted that modem router have problem in wireless...i know that all my computers have no issues because i maintain and built those computer by me..
then Verizon send a new and different modem router...this time it works fine...since i received it last week. call Verizon regarding the wireless issues ..tell them too that you have some dead spot on your wireless..like if you move away more than 15 feet..your wireless connection get lost..
i hope this might help
Mar 16, 2009 | HP Computers & Internet
My verizon UM175 usb modem will not connect to my acer aspire one
- Verify the Internet settings of your USB modem by calling the Verizon support.
Feb 28, 2009 | D-Link DIR-450 Router (DIR450)
Linksys issues
It's clear that the router has lost its connection through the modem since there are no computers that can get online through it. Either the router lost the right settings or the modem is not online. have you tried to bypass the router and try the internet through the modem and check the internet connection? What is the brand or the model of the your modem from verizon?
Jul 21, 2008 | Computers & Internet
Ihave98 wind. cant hook to virzon modem wont takeit needs card was offerd a com dis. lost no
Most Win98 Machines connected with Dial-up, And have an RJ11 Port (Standard Telephone) For the Verizon modem to connect to your PC you need an Ethernet Card (RJ45) You need to purchase something like this http://www.bestbuy.com/site/olspage.jsp?skuId=3195642&st=ETHERNET+cARD&lp=4&type=product&cp=1&id=1051384122901
Jul 14, 2008 | HP Computers & Internet
Computers & Internet Logo
93 people viewed this question
David Payne
David Payne
