I have an acer9300 with vista and trying to restore but my alt f10 don't work what can i do
    Genius:
  • 1,226 Answers
You can use USB keyboard for tha mean time just to restore your vista. or any may ps2 key will work too.
melnavz
PS:
pls do not rate me if my solution not solve the issue and you need more further information. but if is invaluable solution rate me fixya.
Posted on Apr 30, 2008
NH_IMAGE_PATH_HDD
The Alt + F10 causes the computer to boot from a hidden partition to run the Recovery. If the infection has corrupted or intentionally deleted this partition Alt-F10 will no longer work. The eRecovery uses the same partition. You can format and reinstall using an OEM dvd and the product number from the sticker on your computer or you can contact Acer to purchase Recovery DVDs.
I'm surprised they let you use this for work, Vista reaches EOL and all support stops April 11, 2017 - that's less than a month.
https://support.microsoft.com/en-ca/help/13853/windows-lifecycle-fact-sheet
Mar 19, 2017 | Acer Computers & Internet
What to restore my Acer Aspire M5630, alt +F10 doesnt load any restore options?
try alt +F4 or just F4 this should kick in the recovery boot up or if hold alt + tap on F10
Feb 11, 2012 | Acer Aspire Computers & Internet
How do i use Bios? i need to reformat my acer aspire 3680 and everytime i try alt+f10 i get to a screen with a command and the only option is to submit or exit and if i submit it just starts up vista...
Alt-f10 will reload the restore dvd and boot from that. It has to be in the drive and detected before it works. That will restore or reset windows bak to factory so everything on the drives will be gone ie your pictures email etc etc so be careful.
When you first power on the keys to get into bios are very quickly displayed. This will be ESC or alt-F1 or some other key depending on the bios version. Unless you need to adjust hardware settings you won't need to use the bios.
Jan 20, 2011 | Acer Computers & Internet
I want to restore my laptop dell 1501 inspiron it has vista home basic back to factory setting i have tried the f8 and the ctrl +f11 and they dont work can you help i dont have a restore disc
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
or
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
Hope this helps
Jan 08, 2011 | Dell Inspiron 1501 Notebook
Acer aspire 7730 running vista BSOD error startuprepairv2
At this point I would suggest to try a full system restore as the sytem files might be corrupted. You can restore the computer back to factory default,to do so, follow the below steps:
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on the computer.
Jun 26, 2010 | Acer Aspire 5500 5570-2609 Laptop
My vista is not booting? My brother installed Ubuntu and we could use both but since we installed tune up utilities in wont boot please can you help?
best solution system restore
restore from bootup:
1. locate alt key, to the left of the space bar, and F10, row of keys.
power the system on
tap the alt and f10 key same time
please wait a moment............
recovery management will as yo about your restore potiona nd continue...................................
Dec 27, 2009 | Computers & Internet
Want to restore my Acer aspire 4720z!
From Acer direct
The other way before Vista starts up is to tap ALT + F10 (at the same time repeatedly) when the computer is first switched on.. The window of opportunity is very small, so this may take a few attempts
Once you have tapped both the ALT and F10 repeatedly, you may see a screen showing:
“Edit Boot options for Microsoft Windows Vista”
If you see this, unfortunately, you have missed the window of opportunity, and you need to restart, and try again.
If you see this:
“Edit Boot options for Windows Setup” OR “Edit Boot options for Acer eRecovery”
Then it indicates that you have tapped the ALT + F10 correctly, and all you now need to do is press “Enter” and the Recovery program should load on your screen after a short pause..
In some cases, you may need to remove the battery (for notebooks only) and run the machine directly from the mains.
The Disk2Disk recovery feature allows you to recover the system without recovery CDs.
This will return your system to factory settings and will delete everything stored on the machine.
If possible we strongly advise backing up anything important on your machine before starting the recovery process.
Jun 02, 2009 | Acer Aspire 4720 Notebook
ACER NETBOOK MESSING UP NEED TO RESTORE IT BACK TO ORGINAL FACTORY MODE
reboot and hit the alt and f10 buttons at same time and follow the prompts
May 03, 2009 | Acer Aspire One Netbook 8.9" Notebook
How restore to systeme
Hi
This is the only way to restore the system by switching on the laptop and before it show Acer on the press ALT + F10 in this order ALT + F10, ALT + F10 this will take you to the restore mode and from there you click on restore to factory defualt BUT if you formated the Data (d:\) drive then you have to buy vista and download the drivers from the internet
This is the only way I know to restore the OS 100% original
Kind regards mervin
Sep 22, 2008 | Acer Aspire 5315 Notebook
Acer Aspire 5920 laptop, cannot invoke Alt-F10 when booting initially
just press alt f10 ONLY when you see acer logo on boot and hold for a sec i had the same problem and its all adout timming hope i help...
my acer a0751h
Feb 14, 2008 | Computers & Internet
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
