Question about Motorola Mobility H500 Wireless Headset
Motorola H500 paired with Nokia phone
I had successfully paired my Motorola H500 with my Nokia phone. However, after connect for about 5 second, it will automatic disconnect by its own.
Why is this happened ?
How to solve this problem ?
Please advise.
Thank you.
Best Regards,
You have to keep the keyboard locked in order to use the headset. It assumes that you are able to talk without the connection when you touch any key, so it is gonna disconnect itself everytime.
Posted on Aug 31, 2008
Hold fone 7 feet about bathtub or pool.
drop you fone fast into wata.
take push toasta oven in wata.
unplug toasta and take you fone out
Posted on May 31, 2008
Motorolla h500 no steady blue light
Starting with your headset turned off, press and hold the call button for some 6 to 10 seconds, until the indicator light is steadily lit (it will flash some times as if it was being turned on, but don't release the button at that phase). With the light steadily lit It is in pairing mode. Now make your phone's bluetooth application search for new devices. After a while, the H500 should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is successful, the indicator light will flash rapidly, and then, it will enter the stand-by mode. Otherwise, turn your headset off, and go through the whole process again.
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Hope you are able to sort your problems out.
Regards, Carlos
May 11, 2012 | Motorola Mobility H500 Wireless Headset
Can not connect H500 bluetooth with Nokia 2680 slide cell phone. Need Motarola instructions.
Here are the steps to connect your Motorola H500 to your Nokia 2680 phone:
1. Switch off your H500 by pressing the main button for few seconds. 2. Put the H500 in discovery mode. To do this, press and HOLD the main button till it glows a solid blue light (no blinking). 3. Open bluetooth in nokia phone. Go to Menu, settings, Connectivity, Bluetooth. 4. Select "Add a new Device" and search for H500 5. Click on the name select pair. 6. it will ask for pairing code. Enter "0000"
You are done. Revert in case you have any problem
Jun 09, 2011 | Cell Phones
How do i run my motorola h505. I got it from a friend and have no idea how to use it.
the following procedure is dependent to the phone in use!
1. Turn on your mobile phones bluetooth function
2. On the Moto headset, From turned of state, Try holding down the power button for at least 5 seconds.
- The light should stay constantly on
3. search in your mobile phone for blue tooth devices(the phone and headset shouldn't be more than 5 meters away from each other )
4. When you find your blue tooth headset, chose it and hit "connect" or "pair" with the device!
5. you will be asked for a pin, put in "0000" and ok!
now your headset should be paired with your phone and work for receiving calls!
Great Success :P
Dec 07, 2009 | Motorola Mobility H505 BLUETOOTH HEADSET
Problems pairing up a Nokia 6301 with my Motorola H500
Try power cycling the phone. Turn the Nokia off, wait 10 seconds, then turn back on and try again. It really does help sometimes. Let us know if this doesn't help.
Apr 01, 2009 | Motorola Mobility H500 Wireless Headset
If you have lost the pairing on your phone with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Motorola device and click add
6) You will be required to enter in a pass code which is standard ‘0000’.
7) If successful then the headset will start flashing BLUE every few seconds.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
Hope this helps
Chris (ziraffa)
Dec 26, 2008 | Motorola Mobility Bluetooth Hands Free...
I have a h500 cannot pair to my phone lg env
I just did this successfully. Trick was: (1) be sure your headset is fully charged and in the "ON" mode... to do this, you must hold down the power key (the one with the little phone receiver on it) on the H500 for 8 seconds or more or until the blue light is on steadily; (3) THEN go to the Settings & Tools menu on the enV, select #7 'Bluetooth Menu' and then select Add New Device. It will search for your headset automatically - note: the headset has to be powered on for this to work. Then 'pair' will appear as a menu option, select it, and it will pair automatically.
Nov 26, 2008 | Motorola Mobility H500 Headset
Cell samsung SGH-F250 with bluetooth motorola h500
You must activate the Bluetooth feature of your phone to be able to establish a Bluetooth connection
between your phone and your SuperTooth kit as well as with other Bluetooth devices.
Press Menu > Settings > Bluetooth > Activation > On.
Press Back as many times as needed to return to standby mode.
PAIRING TO THE CELLULAR PHONE (Not possible while charging the SuperTooth)
Pairing will create a link or connection between the two Bluetooth devices - the SuperTooth kit and your phone.
1. Bring the cellular phone at about 20 cm from the SuperTooth.
2. Turn off the SuperTooth and wait for about 4 seconds.
3. While pressing the Answer Button, turn ON the SuperTooth by sliding the Power Switch to the right. Keep the Answer Button pressed for approximately 10 seconds until you hear a distinctive tone and the Bluetooth indicator LED changes from blinking blue to alternately blinking of red and blue. The SuperTooth is now in pairing mode.
4. While the SuperTooth is at pairing mode, access the Bluetooth menu of your phone. Press Menu > Settings > Bluetooth > My devices > Search new device. The phone will then search for pairable devices until it displays them in the list.
5. Highlight SuperTooth then press Select.
6. Enter PIN “0000” then press Ok. (Wait until “Paired with …“ and “Connected” will be shown briefly.)
7. Press Back as many times as needed to return to standby mode. Pairing is successful if the alternating red/blue lights of Bluetooth Indicator stops and then change to plain blinking blue. Normally, the phone would also show briefly on its display if it’s already paired and connected to SuperTooth or if pairing with it failed.
The SuperTooth kit is now ready to use.
Nov 15, 2008 | Motorola Mobility H500 Wireless Headset
Communication problems with Motoroala H500
i have a h500 cannot pair with my phone lg env
Aug 01, 2008 | Motorola Mobility H500 Headset
How do i connect H500 to my phone
Hey guys. found it. Go to
then go to manuals
than click on the H500 Bluetooth.
It will walk you through step by step its pretty easy..
Or, you can do it easier.
- Press and hold the Power/Call buttom for 6-10 seconds, until there is a steady blue light
- when there is a steady blue light, go to your phone's Menu, then click on Bluetooth, than Handsfree, It will then start locating your bluetooth. In about 3-5 seconds it will pop up as H500.
-Connect to H500, or push Yes to Connect. (which ever way your phone tells you)
-It will then ask for a password. ALL PASSWORDS ARE THE SAME;AND CANNOT BE CHANGED.
- YOUR PASSWORD IS 0000. typle that in.
Congratulations! Your Now Connected.!
Good luck guys.
Any questions, im on here usually every other day
Feb 18, 2008 | Motorola Mobility H500 Wireless Headset
Press the all-in-one button for about 8 seconds until the light is constantly on, this puts it in pairing mode. then go to your device and initiate pairing. the device code is 0000.
When done the blue light should shut down, and your all set.
Nov 07, 2007 | Motorola Mobility H500 Wireless Headset
Motorola Mobility H500 Wireless Headset Logo
108 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
