Question about Brother HL 1440 Laser Printer
Drum light on after installing new drum - Brother HL 1440 Laser Printer
  • 4 more comments
  • innofa May 08, 2008
    Drum light is still on even though I have already installed a new one. I have taken out the drum and re installed.
  • barb59 May 28, 2008
    I have a brother HL 5250 and I just had the same problem.
    How do I stop this???
  • Terri07 Jun 02, 2008
    My drum light is still blinking after new installation. I thought it was a faulty drum, replaced it and light is still blinking. I've seen this problem posted quite a few times on this site, but I haven't seen an answer yet.
  • songdancer Jul 17, 2008
    Brother's webpage says to reset the drum counter. On some models this is done by opening up the front door, pressing the GO button until all 4 lights are lit, then releasing the GO button. To find the way to reset your particular model, go to www.Brother.com and search for your printer number. Then search for the term "drum."
    Printer drums typically cost almost as much as a new laser printer...so might as well buy a new one.
    Unfortunately, I did all of the above, and my printer still won't work. So I still don't know what is going on. (Brother HL 5240)
  • Anonymous Feb 01, 2009
    I have the same proble
  • dee6 May 11, 2010
    I have the same exact problem, but the fix by JDtiv did not work for me. Any other ideas?
As posted by Songdancer - this solution worked for my HL-1440 to reset the drum light
"Brother's webpage says to reset the drum counter. On some models this is done by opening up the front door, pressing the GO button until all 4 lights are lit, then releasing the GO button"
Posted on Nov 06, 2008
I have a brother HL-1440 . I opened the front of the printer got my pen and pressed the go button held it for 5 seconds till all the light were lit released it and BINGO DRUM light off. Closed the printer all watched all my previous cr@p come pouring out.
Posted on Jan 07, 2009
  • nomoish Jan 07, 2009
    I didnt have to change the drum "YET"
Following this approach worked for me:
1. Turn the printer off.
2. Hold in the circular button on the front panel of the printer.
3. Turn the printer back on.
4. When the DRUM light is lit by itself let go of the button.
5.Press and hold in the circular button on the front panel again. Once the Alarm light comes on, let go of the button.
After step 5, the printer should print a test page, and the drum indicator should turn off.
Posted on Aug 13, 2008
    Problem Solver:
  • 14 Answers
I did get the drum light to go off, and without replacing the drum.
Here is what I did:
  1. Opened up the front door to the printer.
  2. Pulled out the drum unit.
  3. Blow off drum unit with canned air (might as well clean it up while it is out.)
  4. Press the green GO button and held it for 5 seconds or until all the lights came on.
  5. Closed front door.
It took a couple of tries, but it did work, and I am still printing with the same drum. When the print quality gets too bad, then I'll get a new printer, since drums cost as much as printers.
The printers are pre-set to have the drum light come on after so many prints. Therefore, toner cartridges and drums may quit working, even when they have life left in them.
    President:
  • 2,072 Answers
What is the make and model. They all reset differently.
Thank you
Posted on Apr 30, 2008
I went onto the brother website. For the MFC 8460N you can do the following:
1) Open the front cover.
2) Press the clear/back key.
3) Press 1 to reset.
4) Close the front cover, pressing firmly on each side until they click into place.
This worked for our office machine.
4 Suggested Answers
jaylex
  • 417 Answers
SOURCE: Brother HL-5240 drum light flashing
Normally clearing the drum count the machine has to be on open front cover as if to change the drum press and hold the button in for about 10 second then release and shut the door. This should reset the count if not please get back to me and I'll check the service manual to see if anything in that.
Thanks J
Posted on Feb 04, 2008
SOURCE: drum and toner led blinking
I have the same problems with you guys, and none of the solutions above work.
I solved Brother HL-2040 with the following tricks
1. Use the link below to process steps 1-4 and stop.
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002500/000017/faq002517_001.html?reg=us&c=us&lang=en&prod=hl2040_all&Cat=11
2. Use screw driver to remove 3 screws on one side of the toner
3. From the small separate part after removed it from the toner, there is a small white adjustment (plastic), use your finger adjust to the opposite side. Put it back to the toner, and screw them back as original.
4. Follow the remain steps from the link above,
Your toner indicator should be turn OFF
Regards
Vu
Posted on Jan 12, 2009
komguy
  • 2306 Answers
SOURCE: Error light and Drum light are blinking. Do I
Blinking says to replace drum soon, when it's on solid, it's time for a new drum...
Posted on Aug 04, 2009
I have a brother HL_2140 laser printer I just changed the ink cartage and now the Drum light is flashing on and off and it wont print?
That means you drum will finish soon, once the drum light become on you can not print, start looking for the new drum price and get it, once the drum light become on open the front door, take out the toner and drum, with the front door open press go button and keep it down until the 4 lights of the printer become on, release the button and install the new drum with the cartridge.
Aug 06, 2013 | Brother HL 2140 Laser Printer
Copy is too light after installing new toner and drum,
did you reset the drum counter after replacing the new drum? Open the front cover and press the option button... then just select reset drum counter...and press set...
Jun 02, 2010 | Brother MFC 9700 All-In-One Laser Printer
How do you replace the drum properly on a Brother HL-5240
Out with the old and in with the new, you remove the toner and drum together, remove the toner from the old drum by pressing the blue lever on the side, install the toner in the new drum, and re install in the printer. With the front door open press the go button til all lights flash and then close the door, the new drum is reset.
Nov 20, 2009 | Brother HL-5240 Laser Printer
Brother 5250dn drum light blinking; I think drum is ok because I put drum from another working printer and the drum light continued to blink.
The drum light is on due to a preset counter to notify you that the drum has reached the end of Normal Usage life expectancy. It doesn't mean that it has failed, yet...but soon. I would suggest having a new drum on hand for when print quality starts failing. Either new drum units have a reset fuse in them to clear the warning light, or there is a reset proceedure to use after installing the new drum unit.
Nov 06, 2009 | Brother HL 5250DN Laser Printer
Yeah, I have the HL-5250DN printer. The light
Hi there -
The reason the drum light keeps flashing is that you have to "reset" the machine after you've installed a new drum. To do this, I believe all you have to do is make sure the printer is on and then push and hold down the "GO" button a few seconds and then the flashing will stop. This will "reset" the printer to recognize you've installed a new drum. I'm going from memory on that, but I believe that's correct. It's a really simple solution. Good luck!
May 15, 2009 | Brother HL 5250DN Laser Printer
New drum and the copies are extremly light
Drum may be defective must be repalced.
When replacing drum, be sure to reset the drum counter for HL 5150D:
-Open the toner compartment door, and hold the go button for 5 seconds.
Nov 30, 2008 | Brother HL 5150D Laser Printer
Replacing Drum Catridge
Hello, Here are the steps involved in replacing the drum assembly as copied from a users manual:
DRUM CARTRIDGE REPLACEMENT
The useful life of the drum cartridge is approximately 18,000 copies. When the internal counter reaches approximately 17,000 copies, the drum replacement required indicator will light up indicating that replacement of the drum cartridge will be needed soon. When the indicator begins to blink, the unit will stop operating until the cartridge is replaced. Replace the drum cartridge at this time.
1 Remove the TD cartridge (Toner Cartridge). Hold the drum cartridge handle and
gently pull the cartridge out. Dispose of the old drum cartridge in accordance with local regulations.
3 Remove the new drum cartridge from the protective bag and remove the protective cover from the cartridge. Then gently install the new drum cartridge.
When closing the covers, be sure to close the front cover securely and then close the side cover. If the covers are closed in the wrong order, the covers may be damaged. Do not remove the protective cover on the drum portion (black paper) of
a new drum cartridge before use. The cover protects the drum against external light.
Do not touch the surface of the drum (green portion) of the cartridge. Doing so may cause smudges on the copies.
4 Gently install the TD cartridge. Close the front cover and then the side cover by pressing the round projections near the side cover open button. The drum
replacement required indicator will go out and the start indicator will light up.
Aug 15, 2008 | Sharp AL-1217 Copier
Drum light
Try the following: Remove the Toner and Drum
Turn printer on. Open the cover of the printer.
Press and hold the GO Button until the LEDs light up.
Release the GO button after all 4 LEDs are lit
Install the Drum and toner.
Jun 09, 2008 | Brother HL 1440 Laser Printer
Drum problem
http://welcome.solutions.brother.com/BSC/public/us/ca/en/model_top/monolaserpri/hl2030_all.html?reg=us&c=ca&lang=en&prod=hl2030_all
Make sure the printer is "ON" and the drum led to...
Open the front door, Push and hold the "GO" key for about 4 second, all leds are suppose to light...When alls leds light release "GO" key....
Now take the unit out of the printer ...
By pulling down the blue lever take the toner unit out of the drum unit...
And put it in the new drum unit...
reinstall the unit in the printer close front door and check that the drum led is "OFF "
Mar 26, 2008 | Brother HL-2030 Laser Printer
Brother HL 1440 Laser Printer Logo
595 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
