SOURCE: camera will not keep date settings
I suggest u to contact the service people and they will change the internal battery to keep update with time and date. Every camera has internal small battery so has to change regularly
SOURCE: The date and time will
The world of compact digital cameras is fast and furious blink and you'll miss the new model. These pocket point and shooters are cram packed full of features that most people neglect to utilize. So it's uncommon for the problem you describe to occur however it's simple and fairly inexpensive to repair. What you need is to replace the camera's internal battery which holds the custom functions and date time settings after the camera has been shut off. Normal internal battery life is greater then five years and a lot of my cameras go ten years before replacement. A camera store not your big box type but one that actually sells cameras and does film and print processing. I don't know where you are to even suggest someone. However at the bottom of the camera where you would place the memory card and batteries there is another slot for the internal battery. This link half way down the page will show the open battery door and where the internal battery is located.
http://www.digitalcamerareview.com/default.asp?newsID=2981&review=canon+powershot+a710+is
There has been few complaints or problem with this camera except for the very weak internal flash.
Testimonial: "Just in time for the holiday's!!! Thank-you so much. Merry Christmas!"
SOURCE: Every time I switch on
The camera's clock battery has worn out. Unfortunately, on most Canon SD series, this battery is not user serviceable. Recommend contacting Canon to see if they'll replace it, hopefully at a reasonable cost. 1-800-OK-CANON
