Question about Fisher DD603FCSS Dishwasher
I'm Not sure of the model number, Fisher & Paykell double draw dishwasher
My dishwasher flashes the f1 warning with a spanner underneath it all the time. Please advise what to do.
  • 5 more comments
  • Anonymous May 07, 2008
    I have the same problem as Lizzyanne. Any suggestions?
  • Anonymous May 26, 2008
    F1 fault code
  • illawarra Jun 03, 2008
    nautilus single draw model which flashes F1 and Q1 and does not finish it's cycle.
  • Anonymous Jul 03, 2008
    f1 flashing with a spanner underneath it
    flashing f1 with spanner
  • kidrunner Jul 07, 2008
    I have the single drawer dishwasher with the F1 flashing and beeping. I am not sure of the model number. What do I need to do to fix it?
  • acarom Aug 07, 2008
    f1 displayed, machine continues to beep.... what do i do to fix this problem?
  • 30 Answers
F1 fault means the flood switch on the base of the dishwashers has been activated.You would need to ring someone who repairs dishdraws.
You can remove the two kick plates on the bottom of the dishwasher.
Dry out the water in the base with a sponge.
only one draw will be leaking water??
This allows you to use the second draw until a serviceman shows up.
Dry the base out A.S.A.P, because you have a electronic board that sits on the base. cheers
Posted on Aug 27, 2008
My dishwasher's doing exactly the same thing. What was the solution?
Posted on May 07, 2008
188d603 double dishwasher.(F1 with a spanner)?
very common issue on these units, there is water in the base pan, below is a video that explains how to repair this yourself, let me know, click on dishwasher videos and then F1.
Mar 07, 2011 | Fisher and Paykel DG05 Gas Dryer
I have a nautilus dishwasher by fisher and pykel can't find any user guides Flashing F1 and has drained these dishwashers have a reset button?
This video explains how to repair a double and single drawer fisher and paykel dishwasher.
Jul 11, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
What does an F1 erroor message mean. I have a
F1 means "flood. there is a flood sensor underneath the drawer, and if there is any water under the drawer the control will show that error. Check the drain hose linkage for cracks. Remove drawer and dry the area underneath.
Jul 14, 2010 | Fisher and Paykel 24 in. DS-603 Built-in...
F1 flashing with a spanner showing
F1 code indicates a leak,you will find the water under bottom drawer.Might be the lid probably not sealing well. You have to seal it well properly to fix this error in your dishwasher.
Thank u !!
Jun 17, 2010 | Fisher and Paykel 24 in. DD-602 Built-in...
The unit flashes F1 with a spanner sign showing on both drawers
Refer your problem with fisher and paykel DD603 dishwasher. Please clarify how are you able to assess the motor is driving in top gear. Which lights are flashing?
Is this problem in both drawers or just one?
May 30, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
I have a single draw Fisher and Paykel dishwasher. I stupidly put washing up liquid in the dishwasher which resulted in a F1 problem. Water started leaking under the draw and onto my floor. I turned the...
ok , F1 means your flood switch has activated, which is underneath the drawer. now they show the F1 fault because of 2 reasons.1st there is still water underneath drawer causing switch to activate. 2nd your activator board which has the flood switch attached is faulty reading your posting it has been about 15 days since the fault happened. the water should have dryed around switch by now. if there is power to the unit and it is still coming up with F1 fault then possibly you have damaged the activator board. please reply and tell me if you have power on or off at the present time. to fix the problem it is alittle bit involved but i can guide you thru it when you reply .good luck
Apr 23, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
My dishwasher is showing signs of a spanner
I am slightly unsure if your double drawer dishwasher is the prefinished model (self standing with LCD display) or the integrated model with no LCD display.
The spanner symbol on the top drawer is telling you that a fault code is actuated. But I am not sure where this symbol is on your unit if it is built -in (integrated model).
You will have to check which red light (from the left) is coming on.
I assume there are 5 lights on the inside of drawer.
With the bottom drawer - again you will have to check which light from the left comes on sometimes as you mentioned.
If you have a user manual you should be able to tell what Fault code it is - something like F1 or F2 etc. Is it continuously beeping when the red light is on? How do you turn the beeps off?
The scrubbing bush symbol on bottom drawer may not be a problem. It appears the drawer is programmed to a particular option. But I am not sure where this symbol is showing if you do not have an LCD display panel. You can reset the option - possibly auto lock or auto power or dish cleaned (depending on your model) if you follow the user manual.
happy to take you through a possible cause of the problem if you post answers to my questions above.
Jan 18, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If turned off, they come back on after a few seconds,
Fisher and Paykel 24 in. DD-602 Built-in Dishwasher Both drawers are flashing and beeping, displaying Answer Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If... (More) Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If turned off, they come back on after a few seconds,
Sep 23, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
You will remove the draws and dry the under tray as it has a flood.warning sensor to detect water, this is due to lime.building up.around the tub top.seal and off as it causes leaks to run down into the tray
May 12, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
Fisher and paykel dishwasher
F1 is a flood code meaning excessive amounts of water have collected on the bottom catch basin.
If a flood condition is detected, both draws will activate the drain motors and flash F1.
Remove the bottom drawer by pulling the lock pins on each lower side corner. Slide down and remove front cover. Release the drawer slide clips and remove drawer then dry the catch basin.
There are three possible scenarios for this error code;
1. Defective lid motor(s)...Each drawer has two lid motors, attached to the cabinet on either side of the drawer, that pull the lid tight to the drawer when the cycle is started. (this was very common on early models)
2. Something too tall was placed in the drawer preventing the lid from closing completely.
3. (only seen this once) the drain hose developed a crack causing water to leak only when draining.
Jul 03, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher DD603FCSS Dishwasher Logo
333 people viewed this question
Top Fisher Dishwashers Experts
Tony Houde
Tony Houde
George Merkley
George Merkley
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Fisher Dishwasher Expert? Answer questions, earn points and help others
