Question about Panasonic PT-AE900U Multimedia Projector
Diagnosis and cost to fix your projector
Was the technician able to get rid of the vertical lines and what was the cost? thanks.
NO POWER
Posted on Jul 07, 2008
Vertical lines appears on screen from switch on. how can I solve this problem. Thank you.Ed
Your LCD light valve (LCD wafer) is failing and will need to be replaced. This may, however, cost as much as replacing the entire projector.
May 20, 2015 | Acer X110 Projector Svga Dlp 3D, Eco,...
How can I fix green vertical lines in the background of my projector?
I can see by your name that you are trying to fix the entire box .I would have to say that it has probably cost you almost as much for parts then a new one would cost.
Jul 22, 2014 | Boxlight XP-58z Multimedia Projector
I have vertical lines on my display - how do I get rid of them?
try loosening the screws that hold the lamp in, there is a possible short in the encasement.
Jun 07, 2010 | Dell M209X Ultra Mobile Projector ...
Vertical lines
Hi burton29
This is a common Mainboard failure with all makes and models of Projectors.
Will unfortunately either have to be replaced or repaired by a certified technician.
Thanks for using Fixya
May 13, 2008 | Panasonic PT-AE900U Multimedia Projector
Vertical lines on display
Well, in most cases it means you have a faulty lcd or flex cable.
cost is anywhere from $40-$125 to fix
http://horizonwirelessonline.com
Jan 16, 2008 | Nokia 1600 Cellular Phone
White vertical line in the center of projected image
I have a Dell 2400MP projector that had the same problem of vertical white lines appearing over the screen.
This may seem like a simple solution, and I don't know if this will work for you, but the way I solved the problem was simply to press the bottom side of the projector, until the white lines disappear . Until now, the problem has yet to resurface.
Here's some simple steps:
1. Turn on projector
2. Connect projector to computer
3. Focus projector
4. If white vertical line appears, firmly press underside body of projector
5. See if vertical white line disappears
6. If not, try slowly pressing other parts of the body of the projector and see if white lines disappear.
7. If solution doesn't work, you may need to send it to the service center.
Hope this solution works for you.
Best Regards,
Ghazali Ridzwan
http://www.ghazaliridzwan.com
Nov 28, 2007 | ASK Proxima Proxima DP2000S Data Video...
Bad lines on Infocus IN24 images
Hi Dan
The only way to get rid of this is to either have the Mianboard repaired or replaced.
If the Projector is stil under warranty - it will cover it.
If not - It is quite expensive !
Hope this helps you.
Nov 24, 2007 | Office Equipment & Supplies
Vertical line
Hi there
The only way of fixing this is replacing or repairing the Mainboard.
This is a common Mainboard failure on Projectors
Nov 07, 2007 | Optoma H30 Multimedia Projector
Vertical Lines on the projector screen
When the vertical lines are displaying, open the projectors menu (by pushing the "menu" button). If the vertical lines affect the menu, it's a problem with the controller board and will need to be repaired. If the menu is NOT affected, it's probably a loose or damaged cable (Cable part# SP-DVI-A-R).
Oct 15, 2007 | InFocus LP70+ Multimedia Projector
Panasonic PT-AE900U Multimedia Projector Logo
195 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
