First off, is it showing any source of power? If no lights are turning on, check to make sure the battery has a good connection to the pins. Most likely it is a pinched wire inside the case. You will have to reopen the case and move the wires around to make sure they are no longer pinched. Unfortunately, you may have damaged circuitry. If you attempted to power on the phone before rice drying it, then most likely you did, and thats why it will not power on. I suggest rice drying it, after about two days, place the device on a charger. If the red light does not come on after a few hours of charging, the phone is dead, sorry.
1 fuse 1 relay 1 fuel pump that realy hates when you run it out of gas. open gas door remove cap have someone listen to hear pump "whine" when you turn key on . give fuel tank a good whack
this may work 1 time (seen many no starts that when tow truck brings them in i go out and driveinto shop then wont go again)
you gotta drop tank to test for power grey wire to pump
have you tried pressing the button that opens the trunk... It is usually in the glove compartment or sometimes it is a lever to the left of the drivers seat
You need the USB Dock, not the DCU cable, the cable won't work with what you need, Then go to the support section of Sony Ericsson and upgrade the phone (new firmware) that should unlock it. .
I am having the same problem - it won't hold a charge. Red light shows it is charging, but nothing.
It may be the battery. I just called S.E. and they said it may be the battery.
I ended up getting a new phone since batteries cost almost as much as a new phone.
