When i plug any usb device to the system it freezes
    Scholar:
  • 115 Answers
There are two way connect the usb device in the cpu that means front and back side of the cpu. Most of the front usb are not connect well. So you can connect it to the back side of the cpu.
If the problem comes again when connect it to the back panel of the cpu again it freeze. then you can reintall the usb device driver.that you got form the motherboard cd.
Posted on Apr 30, 2008
Eject usb device freezes system
Uninstall the USB drivers from device manager and reboot pc and then re install - should fix the issue - also go to safely remove devices option before disconnecting the device
Oct 17, 2013 | ASUS Computers & Internet
My pandigital tablet dont wanna charge
USB Connections
All tablets connect to your computer using a USB cable.
Once connected, the device should charge as long as the computer recognizes it.
Look for manufacturer-specific software to launch once you plug your tablet into your computer; if this software fails to launch, it's likely that your computer hasn't detected the device and won't charge it.
Try a second USB cable, if available, or plug the USB cable into a different port.
If the device doesn't charge in either port, replace the USB cable.
AC Adapters
Some tablets are sold with an accompanying AC power adapter, though these accessories are often optional.
Try plugging your tablet into its AC power connector in the event that its USB cable isn't functioning.
Also check different wall outlets in case the outlet you are plugging your tablet into is defective.
If the device fails to charge in different outlets, the AC adapter may be faulty.
Reboot Like any device with an operating system a computer, a mobile phone or an MP3 player tablet computers can freeze from time to time.
When a computer freezes, you can reboot or restart it to get the operating system working properly again.
This is true of tablets too, but rebooting these systems can be a little tricky.
Check the manufacturer's website for specific instructions to restart your system.
Putting the tablet to sleep and waking it up doesn't clear its memory look instead for the buttons for a "reset," which are different for every brand.
This may clear up any recent malfunctions, like freezing apps or charging issues.
Restore
Just like a computer, tablets sometimes need to be restored to their original state to overcome technical issues like charging problems.
Again, the process of restoring your tablet to its factory default differs from model to model and from brand to brand.
Check the manual or the manufacturer's website for specific instructions, but as a general rule: plug the tablet into your computer using the provided USB cable.
Wait for the appropriate software to load and then look for a "Restore" option.
Follow the onscreen prompts to restore the device.
Aug 05, 2013 | Tablets & eReaders
Pc freezes plugging in usb devices - ipod & memory stick
i have had a similar problem before. if you touch the usb port w/ finger before yopu put in usb device does it still lock up comp. if not there is a grounding problem with port. you computer will not see it ever. check wireing to port and to riser on mother board. or add on pci card.
Jun 24, 2009 | Electronics - Others
Nascar Cisnet Laptop NCL3006 freezes after I plug in a USB device
sounds like a faulty USB driver - i recommend uninstalling all USB drivers and using drivermax.com to get the correct ones. Your computer may have automatically updated your drivers incorrectly without you knowing.
Hope i could help
CBZ
Comment if you need more assistance
Apr 28, 2009 | ZT Group Cisnet T2060 Notebook Computer
System freeze
The issue was resolved by uninstalling SP3. I uninstalled SP3 and the USB PCI card and rebooted. When SP2 reinstalled the device it installed the corect driver (5.1.2600.2180) and everything is now functional. Have no idea why the correct driver was not in XP SP3.
Jan 24, 2009 | SYBA (SD-NECU2-3E1I) (SD-NECU2-3E1I) USB...
USB Connections
when you put a device on the usb slot the system will detect and check what is the device then after it identifies the device it will load the necessary drivers for it. it is possible that the system is loading a corrupt driver to drive the usb device resulting to a system halt. it could be a driver related in storage devices such as thumb drives that is causing the problem.
try to update the usb drivers using the update driver option on your device manager on usb controller.
Sep 14, 2008 | ASUS P4PE Motherboard
System freeze
Which driver are you using now that you have 'converted' firewire to USB? The USB driver or the Firewire driver. I suspect none would work, as the Firewire driver os looking on the FW bus/layer, and the USB there. The devices may not communicate at all in the same way to either interface.
May 02, 2008 | Behringer F-CONTROL AUDIO FCA202 External...
Problem plugging adaptor into cardbus usb port
sounds like its not supported by the NEC Cardbus
Feb 21, 2008 | Computers & Internet
USB Ports crashing system
If you have done a system restore you have probably restored your problem with limewire also, although what it is that's related I don't know, it's more than likely a dial up or connection problem that is causing limewire to freeze yur system. Check your usb ports in device manager see if there is an exclamation mark or a cross, then refer to this solution for further checks. http://www.fixya.com/support/t125452-another_device_installation_underway
Nov 29, 2006 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
