Question about Dymo LabelWriter 400 Thermal Printer
Dymo labeler All of a sudden, I cannot save address to the address book, everything freezes up and I keep getting 'unresponsive" program messages etc. What should I do?
  • imstuffedfur Apr 30, 2008
    where is the solution?
  • dianegr Aug 09, 2008
    "All of a sudden, I cannot save address to the address book, everything
    What should I do?"
    This is the same problem I have. Any solution? Thanks.
Rquired solved paper vit B.Tech
thanks
Posted on Apr 30, 2008
Address book
Where's the address file located. You need to have full rights (Read, Write, File Scan, Modify, Delete, etc) to the Address file. Right-click on the file name, select Properties, view the rights you have to the file.
Apr 14, 2014 | Dymo LabelWriter 400 Thermal Printer
How do i transport the address book from old computer windows xp to new computer vista
The easiest way would be to identify the location and the file your Dymo printer uses to store its address. Copy the File to a USB memory stick, copy the File on the USB stick to your your new computer, and when you start up your Dymo printing utility open the copied file as your default address library.
The problem you may run into can be caused by different versions of the Dymo printing utility. You may be forced (using the Dymo printing utility) to export the address book on the XP computer and then import the address book on the Vista computer. The picture below outlines this procedure using Dymo printing utility v.8
Also, if you have created any custom label designs you will want to transfer them as well
Jan 17, 2014 | Dymo LabelWriter 310 Printer
Dymo LabelWriter 450 Twin Turbo - Until recently worked fine from both sides. Suddenly, no longer printing from left - prints half a label, then stops, then error message says Out of Paper, the blue light...
See if it still happens using a fresh label roll. From the Dymo 450 User Guide the common causes of poor print quality issues.
Poor print quality is most frequently caused by one of the following:
• An old roll of labels
• Labels made by a manufacturer other than DYMO
• Labels where the thermal coating has been compromised
• A dirty print head
First, make sure you are using DYMO-branded labels. Do not use third-party labels because the thermal coating on other labels has a different sensitivity than DYMO-branded labels. Also, the perforated holes between the labels made by other manufacturers are frequently not detectable by LabelWriter printers.
If the print quality becomes faint, small dots of white appear scattered through the printed characters, or light and dark patches of printing appear, you are probably using a faulty roll of labels. Try using a different roll from a fresh box. If the second roll prints correctly, the problem is with the first roll of labels.
Another possibility is that the LabelWriter print head needs cleaning. Every LabelWriter printer comes with a cleaning card. See "Caring for Your Printer" on page 17 for information about the
LabelWriter cleaning card.
Sep 13, 2013 | Dymo LabelWriter 400 Turbo Thermal Printer
How do I import addresses from excel to my Dymo LabelWriter 4XL Thermal Label Printer?
You first need to install DYMO Label. If you already have installed it, click Address Book > Import to import addresses.
^CM
Sep 05, 2013 | Zebra TLP 2844-Z Thermal Label Printer
Windows vista and dymo labelwriter 450
Here is how to upgrade the software:
1. disconnect the printer and make sure you log in as an administrator. If you need to, back up your contacts: Address Book > Export;
2. uninstall everything that says DYMO (Start > Control Panel > Uninstall) and re-start the computer (back up whatever should be saved);
3. install the latest Windows updates;
4. install DYMO Label 8.5.0: see the download link below(I suggest right-clicking the downloaded file and running it as administrator);
5. connect the printer directly to the computer only when prompted;
7. only use DYMO-made rolls - black stripes on the back, the logo and article number should be there.
tinyurl.com/dymolabel850pc
Also, please go to Start > Devices and printers > right-click the printer > Printer properties > Ports > clear Enable bidirectional support > OK.
^CM
Jan 07, 2013 | Dymo ® LabelWriter® 450 Series PC...
What if you plugged in drive for labelwriter 450 before you downloaded software?
Here is how to install the software:
^CM
Jun 05, 2012 | Dymo ® LabelWriter® 450 Series PC...
This is the error message when openning the Dymo Software on Server 2008. We have openned this same softare successfully on other 2008 Severs. Exception EPrinter in module Labels.DLL at 0000643E6
http://global.dymo.com/enGB/Troubleshooting/LabelWriter_320.html
From this site.
    • The error message: "Exception Eprinter in module LABELS.DLL at ...." is displayed.
      or
      The error message: "Access violation at address ... in module DYMOLBL.EXE" is displayedA. This problem can occur when DLS 7.x was installed over DLS 6.x, without first uninstalling DLS 6.x.
      Solution:
      Delete the file Dymolbl.ENG.
      DLS will still work, however, all default settings will be incorrect.
      The settings will need to be set correctly.
      On the DLS menubar, click Preferences and set the preferences as desired.
      The default values are:
      Default label file folder should be set to "C:\Documents and Settings\All Users\Shared Documents\DYMO Label\Label Files"
      Default address book folder should be set to "C:\Documents and Settings\All Users\Shared Documents\DYMO Label\Address Books"
      Default clipart folder should be set to "C:\Documents and Settings\All Users\Shared Documents\DYMO Label\Clipart"
      B. An incorrect printer has been selected in the DYMO software.
      Solution:
      1. Start the DYMO Software.
      2. Click on File and point to Change printer.
      3. Click the LabelWriter model connected to the PC (e.g. Dymo Turbo)
      C. Occasionally, double-clicking the print command button in the list manager is not handled properly by the software.
      Solution:
      Single-click the print command button.
      D. An incorrect driver has been installed.
      Solution:
      Run the DYMO Driver Uninstaller
      Restart the PC and install the correct driver.
      To remove and reinstall the printer driver:
      1. On the Windows taskbar, click Start, point to Settings and click Printers (& Faxes).
      The printers window is displayed.
      2. Double-click the LabelWriter icon and delete any documents waiting to be printed.
      3. Close all programs.
      4. On the Windows taskbar, right-click on Start and click Explore.
      Windows Explorer is started.
      5. Double-click the file C:/Program Files/DYMO Label/Support Files/LW Remove.exe
      6. Unplug the LabelWriter's USB connection from the back of pc and click OK.
      7. Choose Select all and then remove.
      Once the driver has disappeared from the printers dialog box, click Close.
      Restart the PC.
      8. When Windows has restarted, on the Windows taskbar, click Start, point to Programs, point to DYMO Label and click Uninstall DYMO Label.
      9. Reconnect the LabelWriter to the computer and reinstall both driver and software.
Jun 16, 2009 | Dymo LabelWriter 400 Turbo Thermal Printer
Dymo letratag QX50 has "ERROR 6"
THE MAGNET TYPE OF MATTERAL IS NOT THE ORIGINAL PRODUCT OF ASSEMBLING THE PRODUCT AND IT CAUSES THIS THIS
YOU MAY READ THE SAME INFORMATION AND SEE IF IT IS ANYHELP TO YOU
ADDRESS BAR TYPE: DYMO LETRATAG QX50 ERROR 6
ENTER
ROD
Feb 12, 2009 | Dymo LetraTag QX50 Thermal Label Printer
I need to print address labels using the customer list from qiuck book and the dymo 300 label maker
Hi there, maybe I can help
In my older version of QB I can extract this info in: File/ Mail merge/ and select Customers/ Venders etc. in a sroll down box.
This exports to a .TXT file which then can be used with your Word processing program of your label maker.
Let me know if this helped
Jan 05, 2009 | Computers & Internet
Dymo Twin Turbo Labelwriter not printing stamps
This is the response from dymo stamp. I did as they said and am now printing stamps again.
We have seen this cause problems with the .NET framework Microsoft uses and Dymo Stamp uses. Follow these steps to correct it Step 1: Download Microsoft Windows Installer CleanUp Utility
1. Visit:
http://download.microsoft.com/download/E/9/D/E9D80355-7AB4-45B8-80E8-983A48D5E1BD/msicuu2.exe
2. Save the file on the Desktop.
3. Please double click the msicuu2.exe file to install it on the computer.
Step 2: Remove .NET Framework
1. Click Start -> (All) Programs->Windows Installer Clean Up.
2. Please locate and remove Any .NET Framework 2.0 software.
After that, please perform the following suggestions to reinstall .NET
Framework 2.0 and its updates. Step 3: Reinstall .NET Framework Version 2.0 SP 1
Please download and install the following
Microsoft .NET Framework 2.0 Service Pack 1 (x86
http://download.microsoft.com/download/0/8/c/08c19fa4-4c4f-4ffb-9d6c-150906578c9e/NetFx20SP1_x86.exe
Note: When the "File Download" window appears, please click Save, and follow
the directions to save the file on the Desktop. After downloading all the
setup files, please double-click on each one to install them.
Apr 15, 2008 | Dymo LabelWriter Thermal Printer
Dymo LabelWriter 400 Thermal Printer Logo
269 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Ed Mac
Jax Planet
Jax Planet
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
