Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Missing ntldr for laptop
I can not get my laptop to run for it says that the ntldr is missing and to restart computer
    Problem Solver:
  • 11 Answers
NTLDR is missing error on startup can be caused by
1) Failing Hardware (likely the HDD but can be some other things as well)
2) System File Damage (either configuration or missing file)
possibly due to a virus or malware
You may be able to repair the problem within the XP recovery console, but things like this usually happen for a reason... Sometimes random things cause this but there is usually a reason.
going into the XP recovery console from your XP CD will allow you to check your files and make repairs.
Although copying NTLDR directly may work, running
FIXBOOT
CHKDSK /R
may repair more things too
If I were you, I would let a repair professional do a full hardware diagnostic on your machine to make sure your hard drive isn't on it's way out. Continuing to use damaged hardware may result in difficuilt/pricey data recovery.
I know Geek Squad can take care of this if you take a trip out there but go with who you feel comfortable with.
Any more questions, email marc.menzies@gmail.com
Posted on May 01, 2008
    Problem Solver:
  • 14 Answers
YOU HAVING THE PRODUCT CD OF XP...
YOU CAN SETUP BIOS BOOTING AS 1ST BOOT CD-ROM AND 2ND BOOT HDD
AND SAVE AND EXIT
YOU CAN RUN SETUP AS NORMALLY AND THERE IS RUNNED SETUP AND IT WILL ASK 3OPTIONS ARE..
DO YOU WANT TO FRESH INSTALL PRESS ESC
2ND IS REPAIR OPTION PRESS R
3RD OPTION ESC FROM SETUP
USE 2ND OPTION RUN AS REPAIR OPTION AND IT WILL ASK WHICH DRIVE DID U INSTALL OPERATING SYSTEM AND ANSWER THAT DRIVE..
AND GIVE ADMINISTRATOR PASSWORD
AND CHECK WHICH DRIVE CD AS SELECTED FOR EXAMPLE IT WAS IN (G:\) MEANS AND TYPE THIS COMMAND..
G:\DIR
G:\COPY NTLDR C:\
(OR)
G:\COPY NTLDR C:\WINDOWS
IT WILL COPIED AND RUN AS OK CONDITION
Posted on Apr 30, 2008
    Scholar:
  • 160 Answers
For solving the problem do the following:
If the NTLDR is showing the problem is that the DLL flies of the OS is corrupted.  It may need to install the OS again and see that the system is not swithched off directly without shutdown.
Let me know if your problem is solved and rate me as FIXYA!
NTLDR Missing or what?
You would have deleted the small kb file which contains the information of NTLDR from C: drive , Just download hire boot from net and boot it the first option in that you will see FIX NTLDR
Jan 21, 2014 | Dell Computers & Internet
I have an Acer Aspire 3630 and when I turn it on, it comes up with a message saying "NTLDR is missing Press any key to restart". Does anyone have any idea of how to fix this, I do not have any CDs etc
It has to do with your operating system. The NT loader file is missing that's why it won't boot. You can download NTLDR or the best way is to reformat you laptop.
Sep 15, 2012 | Computers & Internet
When i switch my computer on, windows profession window appears and say press ctrl+alt_delete to begin, I do that but nothing happens. My laptop i'm using is a Dell Latitude D630
Step 1 - Remove non bootable media
Remove any floppy disks, CD's or USB sticks from your computer and restart.
If NTLDR is missing error appears again, Do the Next Step.
Ensure you boot the system from the CD. The system will then boot into the Windows XP Setup.
At the welcome screen press 'R' to enter the Recovery Console
At the recovery console, select your Windows XP installation and enter your Administrator password if requested
At the command prompt issue the following commands and press ENTER after each command:
fixboot
fixmbr
Remove your Windows XP CD and restart the computer
If the NTLDR is missing error appears again after reboot, Try the Next Step.
It is sometimes necessary to run or re-run the Windows XP Setup repair process
If it did not solve your issue re-insert your Windows XP CD and run Windows Setup again
Good Luck!!!!
Sep 20, 2011 | Computers & Internet
When i try to start up my laptop, i get a black screen that says "NTLDR" is missing" and "press Ctrl+Alt+Del to restart" when I restart it, the same screen just reappears. I've also tried pressing F11 to...
The file can be copied from different computer using the same operating system and same version..It can only be done if you can hook up your hardisk from that computer and make it as slave...go to search file and search for the NTLDR file and its directory. copy the file and save it to the same directory of your hardisk slave. If file copying is successful, disconnect your hardisk from that computer and connect it to your laptop, then try to boot.
If that did not work, you can repair your missing file by running your windows installer. Make your cd rom as first booting device and run the setup of windows, when prompted, press F8.. follow some instructions. After searching previous windows system press R key to repair the system.. The set up will restart your unit once its complete.
i hope i help you with this...
much appreciated if you rate this solution..thnaks.
May 29, 2010 | Gateway 7330GZ Notebook
Ntldr is missing.... when i start my computer, it only shows NTLDR is missing press ctrl+Alt+Del to restart (this is on windows XP) please help... thanks
First check to see if you have a floppy disk in your floppy drive, if so remove it.
Second check if you have a CD disk in the CD/DVD drive, if so remove it.
If there are no disc in the drives, then the ntldr file is missing or corrupted and needs to be replaced. Please follow these instructions :-
Feb 04, 2010 | Compaq Presario R3000 Notebook
NTLDR is missing
Reference number: CH000465
NTLDR is Missing. Issue:NTLDR is Missing.
Related errors:
Below are the full error messages that may be seen when the computer is booting.
NTLDR is Missing
Boot: Couldn't find NTLDR
Please insert another disk
NTLDR is missing
Press Ctrl Alt Del to Restart
Cause:
  1. Computer is booting from a non-bootable source.
  2. Computer hard disk drive is not properly setup in BIOS.
  3. Corrupt NTLDR and/or NTDETECT.COM file.
  4. Misconfiguration with the boot.ini file.
  5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
  6. New hard disk drive being added.
  7. Corrupt boot sector / master boot record.
  8. Seriously corrupted version of Windows 2000 or Windows XP.
  9. Loose or Faulty IDE/EIDE hard disk drive cable.
You can go to these sites to view solutions (to much to post here) Very easy to understand:
http://www.computerhope.com/issues/ch000465.htm
May 22, 2009 | E-Machines eMachines Desktop PC
NTLDR is missing. Say's to restart, just goes back
folow this link
http://support.microsoft.com/kb/320397
Apr 05, 2009 | Acer Aspire One Netbook 8.9" Notebook
Recovery cd for acer aspire 3000
The "NTLDR is missing" error can sometimes occur when the boot.ini file is corrupt or missing but in your case it sounds like the HardDrive is the problem.
Try the Following:
Start>Run>Type "Cmd" and enter>Type "dir c:" and enter>Type "chkdsk" and enter. Your computer might promote you to chkdsk later Press "Y" and restart you computer
The Acer Aspire series usually have a eRecovery manager than ables you to burn 2 recovery disk which you should have done when you first got the laptop. Since you haven't done that you'll have to buy new recovery CD/DVD
http://www.user-guides.co.uk/asp/product.asp?product=1241&ph=search&keywords=Acer,Aspire,Recovery,CD&recor=1&SearchFor=any&PT_ID=100
OR you can try the following.
Start>All Programs>Accessories>System Tools>System Restore. Choose a restore point that goes back to before your NTLDR problem started.
Please Rate, Thanks.
Jan 08, 2009 | Acer Aspire 3000 Notebook
Computer crashed and will not restore.
if u tried installing windows from a CD onto the HDD and it still says missing ntldr. seems like a Bad hard-drive.
you can restart by pressing control-alt-delete.
then, try booting from windows CD and repairing the windows installation. if it gives u file copy errors.then, it is a HDD failure. get a new HDD.
Mar 30, 2008 | Acer Aspire 5100 Notebook
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
90 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
