Question about Dishwashers
Hi. I have a Dishlex global 300 series and it starts going through the cycle ok but after about 5 minutes it starts to fill up again and the eco light starts to flash and it won't stop filling up and draining. can you please help me.
The operating manual says under problem solver thatin such a situation it has an incorrect fill level or fill time and recommends then the need for a service agent.
Try holding the start and programme buttons down at the same time until the machine beeps. This will reset it in case it is just a computer problem.
Posted on Apr 30, 2008
4 Suggested Answers
SOURCE: Dishlex dishwasher global 300. Dishwasher
Some diswashers have a sump in the bottom with a float switch. If the water level overflows the float will activate the switch which will kill the machine and run the drain pump continuously.
Posted on Nov 05, 2008
  • 134 Answers
SOURCE: Pump motor runs continuously, ''Eco'' flashes continuously
Hi
soyunds like it flooded the base
You need to dry out the base of the machine thoroughly and it should re set
Posted on Feb 14, 2009
  • 713 Answers
SOURCE: Dishlex Global 300 starts to fill with water, then
ok this sounds like your water has stopped coming in or timed out b4 the pressure switch is activated. hold eco button down, u will hear a beep then a light will come up, keep pushing the button until u see the light.reply and tell me which light has come up, and i can help u fix the problem.
Posted on May 05, 2010
Dishlex global 300 : dishwasher dispenser won't
Hi just read your posting.The problem could be a faulty dispenser coil ,or the wires to it are faulty or the computer is faulty.Try selecting a normal eco wash and when you push the start button to start the machine hold the button in until the pre wash light turns off.This should make the dispenser activate straight after it fills.The only way to test which part is faulty is with an electrical meter.Have you or can you borrow one.If so then I can guide you step by step in finding the fault.please reply with additional information and I am sure I can help you further.Looking forward to your reply.
May 22, 2011 | Dishwashers
Hi there, we have had our dishlex 300 dishwasher switched off for a while and today I turned it on. I started a cycle and it stopped after a few minutes and then the Eco button started flashing. I opened...
Hi just read your posting.Now the reason these dishwashers flash ECO is because there is either water in the bottom tray or your drain pump is open circuit.Is the machine making a pumping noise when it is flashing the ECO light,or is it completely silent?Please reply on additional information and I am sure I can help you.Looking forward to your reply.
Sep 12, 2010 | Dishwashers
Apr 24, 2010 | Dishwashers
Dishlex Global 300. Eco light flashing and nothing happens.
could be the water inlet valve or solenoid
Jan 25, 2010 | Dishwashers
I have a dishlex Global 500 which runs for 3-5 minutes then displays nF
nf= not filling. check inlet vale, or fault will be with pressure switch. If you have poor water pressure, you may need to increase the fill time- insructions can be downloaded from:www.electrolux.com.au, click on "customer service", then "download manuals", then Dishwashers-semi integrated, electronic, then download Dishlex Global Part 1 and Part 2.
Information on setting fill time can be found at the back of Part 2, but Part 1 has a list of the fault codes
Aug 05, 2009 | Dishwashers
Dishlex 300 eco light
pump auto starts if overfull
sound like the machine is overfilling
check the level ,u may need to clear pressure line
or it may be bocked with gunk
if u dont know call for service
it shouldn't be a major.
Jun 16, 2009 | Dishwashers
Hi
Feb 14, 2009 | Electrolux 24 in. EDW5505EPS Stainless...
Dishlex dishwasher global 300. Dishwasher continues to drain with ECO light flashing. Service manual says it is due to an incorrect fill level or fill line.
Jul 01, 2008 | Dishwashers
Eco button keeps flashing, cycle not starting
If its a dishlex global then flood switch is activated.soak water up from flood pan middle front underneath.then it will restart.but you will probably find its leaking or over filling.hope this helps.
Mar 07, 2008 | Dishwashers
Dishwashers Logo
295 people viewed this question
Top Dishwashers Experts
