When filling my F&Paykel washer the water is not a constant flow, it is filling in 'spurts', ie stop/start/stop/start etc...... I have tried cold, hot & warm water, all combinations of temp are producing the same action. It is a Smart Drive 085 5kg machine.
  • Anonymous Mar 23, 2014
    when washer is filling with water temp of water is not hot
  • 172 Answers
You most likely have a smart water temp sensor on your machine. It makes sure you have the proper water temp to dissolve your detergent. Even when set to cold, it will add some hot water. It sounds like your machine is working properly. If you feel you are haveing a problem check the water temperatures in your owners manual and then check them with a thermomater in the washer. If they are not correct you may have a bad temperature sensor. Good Luck and I hope this helped. Mca0824@aol.com
Posted on Apr 30, 2008
Ge load size selector broken
You can buy this part, suggest you go online and purchase it. Contact this website: Appliance Parts Accessories Repair Help
May 19, 2017 | GE Profile WPRE6100G Top Load Washer
Fisher & Paykel ecosmart GWL11 fill problem
Your diverter valve is cloged with lint and not fully closed and is letting wash water go down the drain.
Feb 22, 2012 | Fisher and Paykel GWL11 Top Load Washer
Starts and stops
A failed inlet valve is not uncommon in F&P machines. The hot valve is different to the cold one, so don't exchange them. Not a big job for a tech to do in-laundry. Good luck....Nomess
Jun 11, 2010 | Fisher and Paykel Fisher & Paykel Washer
Fisher & paykel washer GW703 only letting water in spurts. takes forever to fill.
Hi just read your posting. Sounds like you have an out of balance switch problem.This is the most likely cause on the information you have posted. 80% of the time it is the switch and about 20% of the time it is the rotor sensor which is attached to the motor.Just a question or two. Does your machine stop during filling and light up a series of lights and it starts to beep.If it does ,from left to right is it the 3rd and 6th or 1st and 7th etc please reply and I can guide you throe what action needs to be taken.
Jun 05, 2010 | Fisher and Paykel GWL11 Top Load Washer
My washer does not advance. When I push start..it
it can be one of the other:
fill level switch
timer
motor
well i could not pull up the wiring diagram but you can try replacing the less expensive of the three... the water fill/level switch
hope this was helpful
Apr 07, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher & paykel GW 703-U water flow and the engine sounded choked
sounds like out of balance switch is faulty. does the water start stop start stop then machine beeps. if it does it is most likely out of balance switch.please reply 4 more help
Mar 12, 2010 | Fisher and Paykel GWL11 Top Load Washer
MW512 filling in spurts then goes to error.
it nneds a new Outer blance switch , cheap nd easy to fix
Jan 23, 2010 | Fisher and Paykel Fisher & Paykel Washer
My washer won't stop filling up with water!
This is a faulty water valve assembly. replace asap if possible. the embedded water pressure sensor is damaged.
May 29, 2009 | Fisher and Paykel WA37T26G Top Load Washer
Fisher&Paykel Intuitive Eco 'Help, I need water'
If the water is coming into the machine in spurts, you may have a problem with the out of balance switch but it's very difficult to determine by your description & also without knowing the model number. The manufacturers call center is open 24/7 if you want to call them - you can get a number for a repair guy too from them.
Sep 15, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washer
If your washer does not stop filling, you have a problem with your inlet water valve at the rear top of the machine. You simply have to replace this.
Nov 30, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
310 people viewed this question
Top Washing Machines Experts
