Question about Toshiba 36A40 36" TV
RCA 36 I REALLY WAN TO FIX MY TV IT BLURRY CAN U HELP
  • bricklayer43 Jul 31, 2008
    RCA 36v430t picture especially words are blurry, also noticed arcing on something in the back.
  • zavalnitchi cornel May 11, 2010
    are you a repair man (woman)?
I got an RCA 27" TV from someone who had moved it to another room but found it was "blurry" after moving it. I brought it home and tried all the suggestions I had found online but it was still blurry. I looked at the back of the TV and found 2 tiny knobs on the right (from the back view) which I began to fiddle with while looking at the screen. It fixed the blurriness immediately! I now have a beautiful screen.
Posted on Dec 28, 2008
RCA 52" projection tv convergence problems,can i fix it?i try auto convergence? the model is P52920BL and is a 1998 i try the green centering blue & red convergence in the setup of the tv,and it goes back...
My RCA 52 rear projection TV has the letters getting blurry on top and bottom, Picture is OK but visually losing my eyesight staring at blurry numbers and letters.
Is this a bulb or simple fix ??
Mar 28, 2009 | RCA P52920BL 52" Rear Projection...
RCA projection tv is blue and fuzzy
may be convegence try turning down the blue screen and see that that does see if the picture clears...
Feb 04, 2009 | RCA Televison & Video
Rca projection tv is blurry
Hi, you need a tv tech, G2 focus block and pincushion circuit are what your describing, these are both related to the high voltage circuit but are 2 different circuits, definitely not a layperson repair, do yourself a favor and call a tech on this one, good luck, video-tek
Feb 03, 2009 | RCA P52926 52" Rear Projection Television
Find a large rifle and put it out of its misery. Bowing is either from a problem in the pincushion correction circuit or the convergence circuit. Blurry picture or poor color rendition is most likely bad CRTs ( picture tubes)
michtech
Feb 03, 2009 | RCA D52W19 52" Rear Projection Television
RCA r56wh78 rear projection screen is blurry
if you have little knowledge about electronics, you have to open the back of your tv and adjust the focus adjustment located at the back of the flyback transformer the large black colored like hard plastic... and if it is still not working replace the CRT socket....
Aug 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Blurry picture with arcing
this is the the fly back transformer ,replace it or if you are not a repair man ,please contact the nearest repair shop.(risk of shock hazard -high voltage!!!).
Jul 31, 2008 | Toshiba 36A40 36" TV
Buzzing noise
Fly back transformer will cause a buzzing sound like this. Really up to you how bad it bothers you it can be fixed but it will cost a couple hundred dollars. If you can solder you can put it in yourself but the flyyback will still cost a little bit of money.
Josh
Feb 28, 2008 | RCA F36650 36" TV
Picture blurry
What was replaced by the repair shop? The blurriness may be out of focus. If so, the focus is controled by the flyback transformer. That connects to the picture tube at the top (anode cap).
C-Dog
Feb 13, 2008 | RCA F36450 36" TV
TV WON'T COME ON
All the reports are showing the same problem the TV is in shutdown mode.
Something is wrong and it is refusing to start it makes a chirping or clicking sound. Solution is that it needs to be repaired nothing you can do unless you want to try replacing the motherboard yourself.
Dec 05, 2007 | RCA 24V511T 24" TV
Blurry tv
Sounds like theres a leaky capacitor in the screen drive circuit. I have seen this problem also be a gassy crt but was able to clean off the grids of the CRT with a crt/rejuvinator. It happens because of low emmissions in the tube and when white is on thats a mix of all the colors, so the tube works harder. I bet when you whatch a movie and the scene changes suddenly to a white or brite scene the pic looks a little washed out. If this is not the case then I aggree with the Pravin and try it on another TV just to be sure .. This is not a repair for a consumer to do, though however it is only a three year old set you stated, so there should be life left in the tube, so im kinda thinking a capacitor is bad. Seek out a yechnician to check this out for you as a TV is not a place to see it you can fix it or to exoeeriment with. Good Luck
Jul 26, 2006 | Toshiba 36A40 36" TV
Toshiba 36A40 36" TV Logo
159 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
