Question about Motorola Mobility RAZR V3
How to download
How to install theme from pc with the help of
usb ??
my usb cable recognizes my phone but it does not give me the option to do anything i have downloaded many things to try to get my pictures off of my phone and onto my pc but nothing helps. i dont have the software the phone came with but motorola said i can download the software off their website. But which one everyone i try does not seem to work..
  • miznewbooty2 Sep 24, 2008
    get my picture off my motorola phone
Uninstall all software drivers and programs you installed in your PC relating your phone and remove the "Motorola USB modem" from the device manager of the PC.
Then download and install Motorola's "Mobile Phone Tools". Look in google for download links. And follow the instructions in the connection assistant.
Posted on May 04, 2008
How can i put a themes in my nokia n95 8gb?
Hi
Before installing any software go to
Menu> App.Manager> Options> Settings> Software Installation
In Software Installation make it ALL. This change is important, otherwise you will get an Error message Certificate Error. Contact the application supplier while installing most freeware
Also, if you see that some old themes are giving the Expired Certificate error, simply change the date of your phone to year either 2005 or 2006 or 2007 (check all as each theme has a different expiry) before installing the theme. After installation you can change back to today's date.
Now, here is the way to install themes and other applications in your Nokia . I use the USB Cable to do the installations.
1. First install the Nokia PC Suite software on your computer from the CD which you recieved with your Nokia
2. After Nokia PC Suite is installed in your PC, connect the Nokia to the PC with the USB cable which was provided in the box.
3. When the USB cable is connected, Nokia PC Suite will recognise that a phone is connected. You will then see an option on your phone?s screen asking if you want to connect via PC Suite or Data Transfer. Choose PC Suite.
4. Now, simply download the .sis or .java files (themes & applications) to your computer and Right Click on it with your mouse. You will see an option saying Install With Nokia Application Installer
5. Click Yes on the PC, and then Yes & Continue on the Phone when you see the prompts.
6. The phone will then ask you if you want to Install the Theme or Application in the Phone Memory or Memory Card.
I strongly recommend Installing themes in the Phone Memory! This helps in avoiding complications later on when Uninstalling.
When I first bought the Nokia N95, I made a mistake which a lot of new S60 3rd Edition users make, that is, I installed the Themes in the Memory Card instead of the Phone Memory. This was a huge mistake!
There is a bug in the Operating System of all S60 3rd Edition phones, due to which, if the theme is installed in the Memory Card, it cannot be deleted or removed, as it then does not show up in the Application Manager.
Ever since that mistake, I have made sure to always install themes and softwares in the Phone Memory, instead of the memory card. Yes, it eats up space on the phone, but it's worth it, as then it is easily removed as well.
And that's it, the theme or application is now installed!
Thanks for using Fixya.
Mar 14, 2011 | Nokia N95 Cellular Phone
How to install E63 themes?
There are three ways that you can install your Nokia themes on your phone. One is through over the air downloads, in which case, you just go directly to the site with your chosen theme, click on the link, and follow the instructions on your phone.
If you're downloading the themes on your PC, there are two ways you can install it on your mobile phone. One is through the Nokia PC suite, and the other is through Bluetooth or data cable transfer. follow these instructions
Using Nokia PC Suite:
1. Connect your phone to your PC and turn on the Nokia PC Suite or wait for the application to start.
2. Click on the "Install Applications"
3. When a window appears, browse to where you have saved the downloaded themes using the left part of the window.
4. Select your chosen theme and then press the arrow in the middle of the window
5. Follow the instructions on your phone screen and you're done.
Bluetooth or Data transfer (only for N-series and newer phone versions)
1. Data transfer. Connect your phone via USB cable and select "data transfer" on the mode menu. When you connect your phone and it shows up as a removable disk, transfer the theme on your phone's storage card. You can install the theme by using the file manager and selecting the theme to install. 2. Bluetooth. If your friend has a theme on their phone, you can have them transfer it on your phone via Bluetooth transfer. The theme will appear on your messages and to install it, simply click on the transferred file on your messages and follow the prompts.
hope this helps...
Jan 21, 2011 | Nokia E63 Cell Phone
HOW TO DOWNLOAD THEMES
try downloading themes at www.zedge.net or www.mobile9.com (be sure to have your theme compatible to your phone). download your theme via USB directly to your cellphone or to your PC and transfer it to your cellphone via USB cable also. on your phone, go to file manager, select the theme name, click it and it will install automatically. try it.
Nov 03, 2010 | LG GD510 Cell Phone
Some many problems we cant get themes for our samsung metro 3310
are downloading straight to cell (you need a data plan from your carrier, go to download and games) this will cost $ depending the size of theme/games and time it takes to complete.....okay #2 this way is using a laptop/pc you will need a usb cable (to fit pc) to a mini usb (compatible to your cell), go to site you wish to download game / theme download to pc........then connect cell to pc via usb go to my computer open cell...copy / paste (make sure any games downloaded is placed in the games folder on cell, themes placed in themes..
try this site also
  • http://www.zedge.net/
Jul 07, 2010 | Samsung Tocco F480 - Pay Monthly Cellular...
Where can i find free themes for nokia 3110c .. can you pls. give me some sites where can i download themes.
Go to this Link and select "Wallpapers". Select the theme you want to install in your mobile.
You get two options to download that wallpaper. You can either download it to your computer and later can transfer it to your Nokia 3110 mobile via USB cable, or you can choose Mobile Web by which you will have to go to a link from your mobile and will have to enter a code and the respective wallpaper will be installed in your mobile.
Later you can apply it to your mobile phone.
Good luck and have a nice day.
Rating the solution is highly appreciated.
Jul 01, 2010 | Nokia 3110 Cellular Phone
Not installed MIDlet suits
try this site also
Jun 06, 2010 | Motorola Mobility L6 Cellular Phone
Themes and games
try this site also
Mar 31, 2010 | Motorola Mobility ZN300 Cell Phone
Motorola l6 connect to pc usng usb (no mobile phone tools cd)
Motorola L6 just like V3 and other older models isn't directly recognized by windows and because of this
you need a special software designed for Motorola phones called Mototools.
Mototools 6 runs on any windows version from Windows 98 to XP. You can download it by clicking here.
The installation process is simple and takes only a few minutes to setup. Once you've installed it connect your phone to your PC and open up Mototools which will act like a file manager between your PC and your phone.
If this works for you feel free to rate this solution. Also if you need more help feel free to post a followup comment.
Feb 07, 2009 | Computers & Internet
Themes download
You can download themes online or from the internet using your phone browser and download it straight to your phone. Second option is using a PC in downloading themes and transfer it to your phone with the use of a v9 data cable or any data cable which are compatible to your phone's port. You can also transfer themes from your PC using devices for wireless transfer...here are that devices: USB Infrared Adapter and USB Bluetooth Adapter...with the use of these devices, u can now download themes to your phone, good luck!
I hope I had solved your problem...and if I did, show your appreciation by rating...Thank you! It will be much appreciated...
Oct 01, 2008 | Motorola Mobility MOTORAZR2 V9 Cellular...
Motorola Mobility RAZR V3 Logo
76 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
