Trying to hhook up my laptop to my tv and am not getting it to come up
  • 1 more comment
  • greekzzz Jun 21, 2008
    enabled external monitor but still not getting anything to come up
  • chaywoo Jun 25, 2008
    Hi! I tried hooking up the laptop vga cable to a dvi adaptor to video 1 input (dvi) I have tried multipul resolutions, and I cant get anything to come up on the tv screen. The computer is able to identify the hitachi and model# but it seems the tv cant figure out there is a signal coming in on the dvi and it says ypbpr.. is there different dvi plugs? I noticed the dvi adapter didnt seem to want to plug all the way into the tv dvi receiver, but I jammed it on there and screwed in the two side screws, although one side screw would not go in until I slightly loosened the other side screw, is there something screwy going on here? no dvi connector is NOT upside down)
    Thanks!
    Chris
    uhoh, just pulled out the plug and realized that the dvi connector has 4 more pins surrounding the spade terminal, and the tv input dvi does not have those 4 pin openings, so can I just get another vga to dvi adaptor with less pins? thank you.
    Chris
    Brigadier General:
  • 6,966 Answers
There could be several ways that the laptop be hooked up to a TV. It could be through RCA composite video, S-Video, VGA (15pins) and/or DVI. You simply need to check which is available at your laptop and match that port/connector to that of what the TV has. Of course an appropriate cable is also required.
In most instances, it would require that the laptop's Screen Resolution and Screen Refresh Rate be lowered down to match the maximum capacity of the TV.
Additionally, it would be needed to press on the Fn + F? keys of the laptop to cycle through the different settings such as: laptop's display only, laptop & TV displays and TV display only. The F? key would be one in your laptop designated to engaged/enable external monitor (TV). Normally, it would have a monitor icon.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Apr 30, 2008
VGA CONNECTION TO A SAMSUNG TV NO SIGNAL
have you tryed re,tuneing your tv to see if it finds your vga cable.
or try going into your av menu on your tv and it should give you a list of ext1 or ext2 and so on.or try hdmi 1.hdmi 2,and so on.
May 23, 2014 | Samsung N Computers & Internet
Viewsonic n3246w manual
I have had this problem before and all you have to do is click on the sound button on the task bar (bottom Left) and click 'mixer', make sure that the sound is coming to the TV and if it is still not working try moving the HDMI cable in a circle while it is still connected to the TV and the laptop/computer. Hopefully it should then make sound but if the problem still persists try restarting the laptop/computer and/or TV. The cable might be broken so if the steps above to not work try getting a new HDMI cable and make sure it is plugged in properly into the TV and the laptop/computer. Hope this helps.
- Nathan
Apr 18, 2014 | Computers & Internet
Connected my laptop to sony wega tv using hdmi but get no sound on tv
HDMI is prone to this--If you connected with the set (TV) on you may have caused this issue.
In our shop we get a lot of this and if a box was being used (cable HDMI) the box needs to be rebooted.
I would at least try unplugging the TV from power--wait and try to boot it up again(set with power disconnected and then powered again will try).
Restart the laptop, with the cables (HDMI) REMOVED AND THEN INSTALLED AGAIN BEFORE YOU APPLY POWER TO THE SET.
This may or may not help but is worth trying.
Failing this it may be a setting in the laptop or a mismatch between the two units.
Apr 02, 2012 | Sony Grand WEGA KF-42SX300 42" LCD TV
INPUT MODE WITHOUT REMOTE
Hi
If you cannot reach the AV input mode by scrolling through the channel up down, nor is there is a source or TV/AV button on the set it self, then the news is bad I am sorry. You will need the remote to get AV inputs on this set.
You can get a new remote for the set from here for $1995. Plus postage. Note that it has the TV/AV button.
Happy to answer any questions you may have.
regards robotek
Apr 13, 2010 | Orion STV2763 27" TV
Connect HP Pavilion dv2000 laptop to Panasonic Viera 42'' plasma
If you get your wallpaper to show on your TV, then you should be almost there.
  • Try to right-click somewhere in the desktop, choose "Properties" and go to the Settings tab. (Now you should be able to see both monitors.)
  • Click on the "Identify" tab to see which one is your TV.
  • See if "Extend my Windows Desktop onto this monitor" is checked.
  • Try to find a resolution that works with your TV by changing the values for the screen resolution.
Jan 03, 2009 | HP Pavilion dv2000t Notebook
Computer TV output (RCA) - no colour
I had the same problem and nothing worked for me until I changed laptop settings to NTSC_M
So, briefly what I have: S-Video to S-Video cable, laptop (Thinkpad R51, Windows XP, with Intel(R) extreme graphics controler ) and TV set (Samsung, quite old one). The problem was that after connecting my laptop S-Video (4 pin) with S-Video (4 pin) of my TV, I had black and white (no colour) picture.
Solution is the folowing:
- connect your laptop and TV (both S-video 4 pins)
- mouse right click on your laptop desktop screen
- in the popup menu select: 'Graphics Properties'
- "Output to"
- select "TV"
- properties "NTSC_M"
keep in mind that if your are not connected to TV, Graphics Properties don't show TV as an option. So, that was very confusing for me, as I saw similar solution somewhere but was not able to find NTSC_M settings on my laptop
Good luck
Dec 15, 2008 | Computers & Internet
Connect LG 42LY95 LCD to Toshiba Laptop
Hiran
can you use the vga source from your laptop to the pc input on the LG a standard vga monitor cable will do then set your laptop to output the vga signal
Scott
Mar 22, 2008 | Televison & Video
Getting m laptop on the tv screen
You should go to toshibas site. And download the User Manual if possible. this will usually be in Adobe Acrobat format.
Some laptops ( Not all ) have a certain key for example F7 Or F8 that when you start your laptop. you can press fn And F7 To switch between lcd and vga. or fn And F8 LCD-TV.
Alternatively is to re-install your operating system and hopefully this should put the system back to it,s factory default values.
Finally is to enter the bios setup, and change the initial display settings in there.
Hope this helps resolve your problem.
Mike.
Feb 17, 2008 | Computers & Internet
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
Electro Med Services...
