Question about Brother SE-270D Computerized Sewing Machine
Brother 2003D jammed
Was embroidering and the machine jammed.  Said safety device was engaged.  No jammed thread or bent needle.  Did take apart the bobbin area and blow out lint.  Was able to start again, only for it to happen again.  any ideas
  • 1 more comment
  • pjfc8989 Apr 30, 2008
    It was in the up position.  I was not able to turn the flywheel by hand either.
  • sue lynch May 11, 2010
    did the needle jam down in the fabric or in the up posittion?
  • Anonymous Mar 27, 2014
    I have cleared the bobbin carrier but the machine is still jammed
    Problem Solver:
  • 6 Answers
I am not familiar with the brother safety device myself. however things i would check might be to first check the manual for the machine. if not available try to turn the machine off if it is electronic in hope that it would reset itself. i would also totally unthread the machine and change the needle. embroidery machines need to have needles changed more often due to their high speeds.What type of fabric were you sewing on? Some of the newer machines are just not made to sew on very heavy fabrics and this might be causing something in side to spring. Try to stitch on a lighter fabric with a stabilizer under it
Posted on Apr 30, 2008
Safety device been activated. baby lock elegant 2
When a safety issue has been activated, it generally means that it should be taken to a technician. In other words, the machine has a fault that prevents it from functioning for the safety of the user.
Dec 26, 2016 | Baby Lock Sewing Machines
Machine locked up with needle down in the machine
If you can, try to remove the needleplate and the bobbin case from the machine. Once the bobbin case is removed, the needle should be free.
Embroidery Problems Brother Sewing Machine
Dec 05, 2015 | Brother PE-500 Embroidery Machine
Why does thread gather in bobbin area and jam machine
Completely unthread the top and bobbin threads. Clean any lint build up out of the bobbin race assembly using the little brush and some canned air. Check that the needle is inserted correctly...with the flat side towards the back. Then carefully rethread the top and the bobbin threads. Make sure the bobbin is inserted correctly...if it's backwards the machine won't sew properly.
Jun 30, 2014 | Brother PE770 Computerized Sewing Machine
Messages about safe device activated & press the needle position button
The noise is because the machine is trying to raise or lower a needle and can't move. Several things to check. Did the needle break and jam in the bottom thread? Is the needle bent or jam? Did the thread jam in the bobbin area? I had a 'knot' of thread build up on the bottom and it hooked itself into the metal clip on the bobbin so that the needle couldn't raise. If thread jams in the bottom carefully cut the threads until you can free the hoop and material. Then check to make sure all pieces of thread and fuzz has been removed in the bobbin case. If it happens again check to see if the bobbin case or the throat plate is scratched or bent. If you are stitching Free Standing Lace on this machine or a piece with over 20,000 stitches I recommend starting with a new full bobbin and a new needle. As you get toward the bottom of the bobbin, thread seems to have a high likelihood of tangling or looping.
Nov 27, 2013 | Brother PE770 Computerized Sewing Machine
I have a janome 11000. it jammed while embroidering a project. The underneath was rats nest and my needle bent and gouged up my bobbin case...Replaced the case and now the machine makes a clicking noise...
sometimes when a needle gets bent, it can cause the sewing machine to need a adjustment by a technican.
sometimes a jam can be caused by the thread coming off the thread take up lever
or the bobbin is turned the wrong way in the bobbin case
or the bobbin was not thread correctly
Sep 12, 2013 | Sewing Machines
I have a Brother NV4000D and it has been a nightmare. It has been in the shop 36 times and Brother will not help me. Here is my problem. I just receivedmy machine back from Brother int. They have had
I'm going to suggest something. Take your machine to a friends across town and plug it in. See if you still have this issue.
I've had power problems before that all but killed some electronics. And certainly make you and others think you are crazy... You may need to put a power conditioner between the machine an the wall.
Nov 17, 2012 | Sewing Machines
Needle broke while embroidering. I replaced the needle, but now it is jamming and will barely move.
Maybe you have broken threads under the needle plate, Can you lift the needle plate and clean?
Dec 08, 2010 | Brother XL-3500
Check if thread is entangled, needle is bent
The machine act's as if the motor gets hot and quit's. Once it cool's off, it will work again.
Apr 10, 2008 | Baby Lock Ellure
Thread adjustment
Sounds like the bobbin tension is loose. Look at this website on their "repair" page where it explains how to adjust the bottom(bobbin) tension.
www.sewusa.com
Mar 05, 2008 | Brother SE-270D Computerized Sewing...
Brother ult disney machine
Marty, it happened to me! I figured it out, if you need help, feel free to email me, it is the bobbin carriage was not put it--not the bobbin spool, but the whole carriage. feel free to email me and I can walk you through it! I just saved myself a trip to the repair! :)
pyles_brandi@yahoo.com
Dec 17, 2007 | Brother SE-270D Computerized Sewing...
Brother SE-270D Computerized Sewing Machine Logo
231 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
