Question about Brother Disney PE-400D Computerized Sewing Machine
Card not not be used??
Every time I put my memory card into my PC8200 machine it says the card cannot be used. I don't know why this is happening I was using the machine , took the card out to add designs onto the card. when I put it back in the message come up "Card cannot be use" any one got any ideas as to what happened??
  • cordsgranny Apr 30, 2008
    It is the memory card. As far as I know there is no lock on it you just put it in the slot.
  • joei zul
    joei zul May 11, 2010
    what kind of card you have?
    checked if the card is locked.
    if it is you may need to unlocked it to use it.
  • 22 Answers
There are some memory card that has physical lock, you can see it on the card itself, but for some, you can check it if you put the card into your computer, and try right clicking on it, it would then tell you if it's lock or not.
Posted on Apr 30, 2008
How do I know if this is a Machine issue, a Memory card issue or an error in the design file?
Read the files back to computer to check they are there. Open folder by pressing it , should then show designs
Jun 23, 2015 | Janome Memorycraft 9700 Computerized...
Can I purchase blank memory cards for Janome 5700 machine? Alternatively, what software or digitising programes would I need to make my own designs to use with this machine?
I would like to buy a blank memory card for my 5700 or have you developed a converter for it so I can still use my machine but put new styles on it.
Please let me know how you can help me
Jun 23, 2011 | Janome Memory Craft 5700
Transfer designs to my blank memory card
You need a a Reader/Writer box with a blank Janome memory card (PCMCIA) and Cusomizer software. With that you can move your downloaded .sew designs into Customizer and on to the card via the Reader/Writer box provied that they are within the allowable size constraints.
Jul 19, 2009 | Janome Memory Craft 9000 Computerized...
How to use the memory card?
Sewing Machines Direct
Clwyd Court 2
Rhosddu Industrial Est Wrexham, LL11 4YL
Business hours:
9.00 a.m. to 5.00 p.m.Mon - Sat
11.00 a.m. to 5.00p.m. Sunday
these may be the best to ask
May 24, 2009 | Janome Memory Craft 10000
Will not accept memory card
I loaded a different pattern to the card and it worked. Guess it was just a problem with the first one I tried. Hopefully, it won't happen again.
Apr 17, 2009 | Baby Lock Esante
Having problem downloading patterns from disc to memory card have spent hours trying
Judy, you mention memory card so I am assuming you are refering to a Compact Flash card that you insert into a PCMCIA adaptor.
The card must be smaller than 512 MB, any larger and the machine won't acknowledge it. You need a type 1 card and compact flash card adaptor, a compact card reader/writer unless you have an integral multi card reader integrated into your computer. The card format must be FAT, the older computer file format. Insert the card into the adaptor and insert into your machine, wait for the warning screen to clear, if the machine asks "format card" hit yes on the machines display screen . If there is no offer to format the card use the SET icon on the display screen, you need embroidery mode, then arrow forward till you reach the Format options, select ATA card, hit yes, it will warn you card contents will be erased, hit OK. Just say yes to any new questions. Wait for the warning screen to dissapear, when it does you can eject the card adaptor, now insert the card alone into your digital media card reader which should be inserted via a USB connection to your computer, locate the drive your computer has allocated to the card and open it. You will see two types of folders, ORD which are for combined decorative stitches you might want to save, those you put together in the machine, and EMB folders, those are where the machine expects to find designs,11 of each.
Only use them to transfer designs between the machine and computer or vice versa, don't use them to store all your designs in, you will over tax your machines on board processor.
To pop designs into them, open your design CD, select the design you want to stitch, copy it, now open the card in your computer, open the first folder, number 5, I think, and Paste into that folder. Use only JEF formats, your machine wont read any other format.
Don't transfer designs into the machines built in folders, you will severely constrict the machines memory to the point where it wont be able to access enough memory to stitch your designs. Use the compact card as an external drive, which it is anyway, the machine will still stitch the design as if it were in its own memory. To access the card in the machine, select embroidery mode, then the card icon and finally if needed the file icon.
Hope this helps you
Mar 20, 2009 | Janome Memory Craft 10000
I have The problem about Janome Memory craft 9000
Do you have a Magic Box or Amazing Box? The only way I know how to rewrite your card is to insert it in the Box and it will ask you if you want to erase the card. I have the same machine and I believe your cards that you buy with designs already on them are non erasable. You have to buy a blank card to put your own designs on them.
Jan 16, 2009 | Janome Memory Craft 9000 Computerized...
Memory card
You will need to buy a Compact Flash (CF) card (up to 128MB is a good size, NOT more than 256MB), a card reader to attach to the PC also a PCMCIA carrier/adapter for the CF card to be inserted into your sewing machine if the CF card will not go directly in.
May 05, 2008 | Janome Memory Craft 9000 Computerized...
Memory Card 17
I believe only some of the '8000' cards can be used on the '9000' and this may not be one of them or it could be faulty.If you brought it from a retailer I suggest you return it explaining your problem, they may exchange or refund your money.These are 'old' cards now I believe apx 11-12 years.Hope you find a solution.good luck
Jan 26, 2008 | Janome Memory Craft 9000 Computerized...
Brother Disney PE-400D Computerized Sewing Machine Logo
85 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
