Question about Vizio P2 42 in. HD-Ready Plasma Television
Vizio 50" plasma
My plasma just turn off and will not turn on again no picture no sound just shows is on but it does not do anything
  • 1 more comment
  • ozzo341
    ozzo341 May 03, 2008
    yes, there was a pop and it turn off after that and after unpluging for 24 hours it sounds like it is going to turn on, it shows flashes but it just goes dead again.
  • ozzo341
    yes there is a green led on but it does not show anything no sound, i have tried everything like u and nothing.
    thanks
  • ozzo341
    thanks, i did that already and still nothing
  • 3,037 Answers
Was there a pop noise before this happened or is there anything flashing at all?
The power supply in these sets have had bad electrolytic capacitors which short and actually blow their top because of increased pressure. Only part of the switching power supply is now running so you may see a power light but nothing else. I am not sure what Vizio would charge to replace the cap or supply. If this is the problem the capacitors will be fairly cheap and depending on your skills, the labor may be too but capacitors are dangerous and only a qualified person should replace them.
Please let me know if you see anything else that may help figure out what is wrong, thanks
Posted on May 02, 2008
  • Benjamin Patri
    Benjamin Patri May 03, 2008
    Since there was a pop, then I believe your capacitors need to be replaced. Only do it yourself if you know how dangerous they are and how to handle them correctly. Only an experienced person should replace them. They shouldn't cost too much and can be obtained at a local Radio Shack. If you have any questions, feel free to ask, thanks
  • Benjamin Patri
    Benjamin Patri May 06, 2008
    Please don't forget to rate this solution as that is one of the biggest
    aspects of how this website works and in order to receive any credit in
    helping you, I need to be rated.
    Otherwise, let me know if you have further questions and I would be glad to help.
    Thank you
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 52 Answers
By "shows it's on", do you mean that there's a green led on, or something?
That happens on my HDTV. I think it means it's in standby mode. To fix it, I just press the "source select" or "video" button on my remote/tv, and it turns on.
Brad
    Guru:
  • 1,894 Answers
Leave it pulged out from power for few hours and then try it
  • dewan nafees ahmed May 02, 2008
    so that it can make a reset..
  • dewan nafees ahmed May 04, 2008
    huf.. i think the problem is with the power board sir.. am sure with it.. its due to some faulty component in the board..
    wi am i saying tat?
    bcz after u leave it for 24 hrs and turn on.. it seems to come on and then it again goes off.. bcz circuit goes stable after a long time.. but again when the component is strained it goes off..
    so if u r comfortable with tech things then u can open the set and look for faulty components..
    good luck
Vizio 50" Plasma VP50HDTV20A comes on with sound but screen shows rainbow colours before pictures comes and picture is blurry when on and not in full color. All the inputs have the same display.
If this is an old Plasma TV that you picked up somewhere, it may just be too old. Plasma screens degrade over time.
New plasma TV's are not common anymore, so I am assuming this one has been around for awile.
If it is new, take it back to where you bought it.
Apr 10, 2017 | Vizio Computers & Internet
My Vizio p50hdtv herd spark, and TV went black, no picture no sound
Check and replace the main power regulator board as card basis. It has damaged.
Oct 11, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio has sound but no picture, 50 inch
I have the P50HDTV20A. When I turn mine on I get sound but no picture but if I leave it on for about 15-20 mins and then turn off then back on it will have picture and sound. It seems as though as something has to warm up so the picture will come on.
Mar 27, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
50" Vizio sound but no picture
those plasma hove a lot of problems with the y-sus board signal board take you meter check cops ics. was it flashing black and white before you replaced the boards
Feb 19, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
VP50HDTV10A
hi i have a 50" plasma HP50TV10A and just show half of the tv picture horizontal
Jun 18, 2009 | Vizio VP50 10A 50 in. Plasma TV
Plasma does stay powered on
Your sustainer board is probably bad. You need to get the Y & Z sustainer boards replace then it should be okay.
Feb 08, 2009 | Vizio VP50 10A 50 in. Plasma TV
Vizio 50" Plasma HD
just purchased 2/7/08 Model # VIZIO JV50P HDTV 10A followed instructions to install cables but when turned not allowing me to do initial set up. Can't access menu from remote either PLEASE ADVISE. ....MO
Jan 12, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
VIZIO 50" PLASMA
Wow. This is more comon than I thought. My 50" Vizio plasma just went out as will after a loud pop noise. Power button is still lit. Sound continue to come through but no picture. I will dig into it and see if I can find a appropriate solution.
Feb 14, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio P2 42 in. HD-Ready Plasma Television Logo
114 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
