Question about Nintendo DS Lite Console
Broken nintendo ds
I droped it and ever since it wont turn on but when i conect the charger the orange light goes on but i try to turn it on and it just dosent do anything. I hear a noise inside the ds light , like if somthing broke when i droped it was like 3 or 4 feet feet high from where it fell from. so what can i do ? where can i get it fixed and or checked? my name is Jorge.
    Champion:
  • 268 Answers
You've knocked the power cable see if you can find a gaming repair shop
Posted on May 03, 2008
  • Darren Beswick
    Darren Beswick May 04, 2008
    Hey Jorge
    If you go to the place where you bought it they will be able to get it sent off for repairs in no time, takes about 10working days for return, you should check your local market places for gaming repair shops, but if you do get it sent off, chances are you wont get charged for it, depending on how long you have had it, hope i was of any help
  • 53 Answers
Try calling nintendo they might fix it but i do not know what they charge
Posted on May 02, 2008
When the charger is pluged in the light comes on
Hi...
Either the battery is no good or the charger is broken..Do you know someone else with the same unit that you can try?
Apr 19, 2010 | Nintendo DS Lite
My ds lite won't charge.. the orange light appeared blinked
We had this problem with a brand new DS Lite...turns out it was a bad charger. If you have access to another charger, try that first. Good luck!
Apr 03, 2010 | Nintendo DS Lite Console
When i power on my ds lite my green light turns on then turns rite bcak off and when I attach the charger it does the same thing.... What/s wrong with it?
Does the orange light come on when you plug it in? If it does, then it is a failure of either the DS's BIOS or its Memory. If the orange light doesn't come on, then the AC adapter is broken.
You can get a new adapter fairly easily, but it isn't worth trying to fix a BIOS or hardware issue.
If it's a fairly new DS, contact Nintendo's Customer Service, and see if they'll replace it.
Sep 19, 2009 | Nintendo DS Lite Console
Putin in charger orange light flashes then goes off an doesnt cha
Your DS is either fully charged or the battery got damaged/wet. When you play the DS, is the light red or flash red? If it does, then the problem is with your battery. http://www.nintendo.com/consumer/repair/dslite_repair_home.jsp
Click on your country, then "System and Game Problems," then "Power and Battery Charging Problems."
Hope this helped.
Apr 15, 2009 | Nintendo DS Lite Console
I droped my nintendo ds
Yikes! Looks like your luck on dropping your system has run out. You might get lucky one more time. Open the battery compartment, remove the battery, and then put it back in and close the compartment. You may have knocked it loose.
Jan 03, 2009 | Nintendo DS Lite Console
Nintendo ds wont charge
cheekiemunke,
First of all, your DS Lite is charging both ways.....with power on and without power on.
You have for almost 99% sure a blown fuse F2 on the systemboard.
If you can solder you can try to replace it with a new one but be adviced, it is tricky if you don't have the skills with soldering SMD components and it can send your DS lite to the trash.
So my advice is find someone that repair DS Lites or order a fuse on eBay and try it yourself.
Regards
John
Nov 27, 2008 | Nintendo DS Console
Ds lite ac wall charger
When you first get the DS it will have a bit if charge on it but only a few hours worth. When the DS charges it usally comes up with a orange/red ish light then that goes out about a few hours later when its charged. ad if you want to chek if it is charging correcly turn the DS on whilst it is charging and the little battery simble in the top right corner should show the battery carging.
Nov 30, 2007 | Nintendo DS Lite Console
Not charging
Quite honestly...
I know that this is probably not the answer you guys want to hear about this issue...
You're going to have to contact Nintendo and make good on your warranty on this one. Just tell them that the unit is no longer charging and that you 'don't know why'. They should have no real problem replacing it for you.
This is most likely an internal electronics issue that no expert here is going to be able to advise on.
Unfortunately the internet still isn't good enough that we can do solder jobs over our internet connections. :P
=THIS IS NOT A PROPOSED FIX. DO NOT RATE ME FOR IT=
Otherwise, if you wish to persist in trying to fix your problem, the only thing that I can tell you is to either try using someone else's charger adapter, buy a new adapter OR use an adapter that works and hold it at different positions in the DS Lite to see if any position will charge it. If you are succesful at charging it in this manner then the port you plug the charger into may be loosened.
===DO NOT RATE ME FOR THIS POST. IF YOU GIVE ME A POOR RATING FOR THIS POST I WILL DISPUTE IT WITH THE FIXYA STAFF AND ASK THAT IT BE REMOVED. I AM NOT ATTEMPTING TO SOLVE YOUR PROBLEM BUT AM GIVING YOU ADVICE ON WHAT YOUR BEST BET IS. I WILL however accept a GOOD rating if it is given - naturally. LOL===
Regards,
Cyryl
Nov 03, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
