Question about Hobart A200 Stand Mixer
Motor runs but beaters won't turn and gears will not engage or change speed
I bought a used Hobart H200 qand it was working fine when suddenly I turned it on and there was the motor running and no beater action. I tried changing gears and no dice! It's as if the transmission is shot or something snapped or came loose inside the trans case.
When I opened the case, I found a load of greas that I am afraid to remove and can't see anything. I am concerned about cost to repair, If anyone has a cheap solution and a way to buy new trans grease and how much is needed, I would appreciate your input
  • sundance66 May 01, 2008
    Thought I would need a tech!
    Thanks for confirming that it is not a DIY job.
    Any idea how $$ this can be?
    We have an older smaller mixer which sounds like an old tank, but it works. If the cost is over $100, we may have to wait on the repair.
    Thanks again.
    Sundance
    Genius:
  • 1,673 Answers
Most likely there is a broken shaft, seized bearing, or a stripped gear.
The service tech will unassemble everything and replace the necessary warn or broken parts. He will re-assemble everything, check for proper gear lash and bushing clearances, and re-pack new grease.
Jerry G.
Posted on Apr 30, 2008
  • Jerry Greenberg
    Jerry Greenberg May 02, 2008
    I would not have any idea of the cost, unless I know the exact parts that were defective and then did the research to find the prices. What you can count on is that the average repair can take about 1 to 2 hours for most all of these appliances. If you know the average hour rate for your area you will have an idea of the labour cost.
    Most of the time, the parts are not expensive in relation to the labour.
    Jerry G.
MY Hobart Hl200 is working with only 2 speeds when it used to work with 4 speeds.
hello! the speed select switch is defective...It is located behind the timer control board...Part # is...00-874831
Guru.............saailer
Mar 16, 2010 | Hobart HL200C Mixer
Hobart D340 mixer will not hit 3rd gear
Check that the gear on the shaft that the clutch gear engages with does nort have a sheared key.
Feb 12, 2010 | Hobart D340-6007 Mixer
The motor works fine and you can hear it engage as you change it from speed to speed but the the beaters do not turn
This sound like the worm gear has failed: http://kitchenaidmixerspares.co.uk/Home/tabid/36/p/Mixer-Part---Worm-Gear-and-Bracket-240309-2/ProductID/103/CategoryID/17/Default.aspx
You will need to take the mixer apart to confirm this.
Jan 23, 2010 | KitchenAid K45SS Classic Stand Mixer
Beater mechanizim runs very slow and will not change speed
It sounds like you sheared a key in the transmission.Does any gears work?were you using 1st gear for dough?
Jan 15, 2009 | Hobart D300 Stand Mixer
Hobart A-200 First Gear is Having Trouble
If the mixers are older the dive key shaft,spring or key are broken,if they are newer the key is sheared.Also check the nuts near the beater shaft and make sure there not too tight.
Nov 13, 2008 | Hobart A200 Stand Mixer
How to disassemble Black & Decker MX50 PowerPro Mixer
You can remove the handle-back by gently prying the rear clips down and away. But the problem is the power boost button; it has a fork that goes down the left side and snaps over a micro-switch. You need to get that off since there is not room for all 3 buttons (eject, variable speed, and boost) to slide through the handle. A small probe inserted from the top and pushing on the left side to the rear might do it. Or just pry the boost switch upwards; that's how I got mine apart. My problem was the boost microswitch was bad and provided a poor connection. As a result, the beater only ran intermittently on regular switch positions. I solved it by bypassing the boost micro switch. The beater now only runs on the regular speeds but that's fine by me.
Nov 10, 2008 | Black & Decker MX50 PowerPro® Mixer
Hobart A200
When you say lag and catch up. This may not be a issue. I have seen this with dough and a spiral hooks on all sizes of Hobarts the hook and dough get in a position to push the hook forward and the drive gears catch back up the hook. in fist gear on the 20 quart this is common for sure. but its normal. if you have a real slip from a sheared key it will not take long to where you can hold the planetary shaft with your hand and stop it. another slip that might be possible is if your mixer has the first generation worm shaft gear Assembly. when it is worn out it will slip you. this is the shaft that drives directly off the motor. you can tell if it's first Gen by it has a large spring on it. the tow later versions are all keyed to the shaft no chance to slip unless a key shears.
Michael
Oct 24, 2008 | Hobart A200 Stand Mixer
Hobart 140 Qt Mixer 4 speed. needs the oil changed? what kind of oil to use?
You can use a heavy weight gear oil or call the local hobart branch for it.To remove oil----Look under the mixer where the beater shaft is in the back and you will see a three quarter inch nut,remove this nut and drain the oil then put nut back in.To fill the unit remove the top cover screws and remove the top,you will see a long hexagon nut in length,remove this and grab a funnel then add the oil---be patient it takes time to fill as the oil is heavy.
Jul 24, 2008 | Hobart H600 Stand Mixer
Hobart A200 Stand Mixer Logo
208 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
