Plasma Monitor PDP-614MX turns itself off - Televison & Video
  • 2 more comments
  • meldner Apr 30, 2008
    Pioneer Plasma Display PDP-614MX is a 61" TV Monitor. Friend tells me its either the board or the panel - the latter would be very expensive
    Great trick that gave a little life to the monitor - now it shuts off after a few seconds - previously shut off was immediate. There is also some reddish screen picture for a second or so. No menu. By repeating the exercise sometimes the monitor goes into a few cycles of shut-off & turn-on.
    What next?
    This re-setting to factory defaults seems beyond my skill. I have built PCs and Servers with up to 8 CPU complexity but the
    "External Control Manual
    RS-232C Configuration
    for PDP-614MX"
    appears to require at least a special cable (?)plus special training (?)
    Anybody near Truckee, California (Lake Tahoe area) that I can contact?
    Pioneer Plasma Display PDP-614MX is a 61" TV Monitor. Friend tells me its either the board or the panel - and the latter would be very expensive.
    Comment by meldner, posted on Apr 30, 2008
    Holding down power button for 30 sec. when unplugged: Great trick that gave a little life to the monitor - now it shuts off after a few seconds - previously shut off was immediate. There is also some reddish screen picture for a second or so. No menu. By repeating the exercise sometimes the monitor goes into a few cycles of shut-off & turn-on.
    What next?
    Re-setting to factory defaults seems beyond my skill. I have built PCs and Servers with up to 8 CPU complexity but the
    for PDP-614MX"
    Genius:
  • 1,665 Answers
Have an experienced to inspect electrolytic capacitors over 100 V at power supply area or better replace them.
Posted on Apr 30, 2008
    Genius:
  • 1,142 Answers
May i know the model and the make of the product in details so that it can help me resolving the issue is a more prompt manner
  • 2 more comments
  • Maanita Chadha
    Maanita Chadha Apr 30, 2008
    shut the power down completely. leave the monitor turned off and unplug the power cable, do a flea power by pushing the power button kept pushed for atleast 30 seconds when the power cable is not connected to the monitor this will release the static power from the monitor and when ull turn the unit on it will work without problems.
  • Maanita Chadha
    update me with the status then ill give you other tips
  • Maanita Chadha
    Reset the monitor to the factory default
    http://www.pioneerelectronics.com/pio/pe...
  • Maanita Chadha
How do i connect head phones to pioneer pdp 5071pu TV
This model has no headphone out put. In the rear panel there are two monitor audio outputs which could drive headphones, but I think the volume output to a possible monitor matches the tv loudspeaker output, and may not turn off the audio separately.
Mar 09, 2014 | Pioneer PDP-5020FD 50 in. Plasma HDTV
Where can I buy a Pioneer PDA - 5002 Video Card?
Contact the nearest authorized service center for Pioneer.
Nov 03, 2012 | Pioneer PureVision PDP-433CMX 43 in....
Problem with picture on HP Plasma TV
hello!
This is known problem with PDP displays. That means: one of X-buffers has bad connection to the PDP(plasma display). Or, in some cases, depend on PDP type, it could be panel itself at fault. You need to open your set carefully and get an access to X-buffers. Usually, at the very bottom of PDP, covered with aluminum heat sinks. By turning set on, while face down, start tapping slightly with isolated handle of medium size screwdriver. Observe, when line(s) vanished. That's where connection(ribbon cable) between PDP and X-buffer is compromised.
In some PDPs, those integrated into panel itself and nothing you can do, except to live with that or replace panel. Hope, you end up just reconnecting ribbons. Anyway, you must have very good technician background to do so.
good luck,
Alex.
Feb 16, 2012 | Televison & Video
I have a Pioneer PDP-5030HD plasma and the plasma display does not turn on. The standby/on power indicator light on plasma display is blinking red (after turning it on with my remote, it turns green for a...
First check batteries in the remote are charged.Try pushing one of the channel selection numbers on the remote as it may be the off/on on your remote is stuck or has died completely. if this does not fix the problem try unplugging the set from the wall wait 5 mins (approx) and re plug into wall socket and try turning on .
Oct 25, 2017 | Pioneer PureVision PDP-5030HD 50 in....
Pioneer PDP-42A3HD - TV turns itself off...is
Here is the link for the manual - c ould be a remote set up issue or this could be puffed caps in the power supply - have a qualified tech check that out
http://tv.manualsonline.com/search.html?q=PDP-42A3HD&submit.x=49&submit.y=15
Jul 03, 2010 | Pioneer PDP-42A3HD 42 in. Plasma...
61 inch pioneer plasma audio hook up?
I checked on Pioneer's site and couldn't find literature for this model, but did find the product information sheet for a model PDP-614MX. It may be similar, but no promises. This model has no audio output available, but does accept several audio inputs. It shows speaker terminals on the bottom and claims a 9-watt output for each channel. Speakers that mounted on the sides were available as an option.
This monster was originally designed for professional use (stores and such) as strictly an output display device. Probably the best solution would be to use this to display the video, and run the audio output from the source (DVD, satellite receiver, etc.) to a separate amplifier to drive your speakers.
Feb 07, 2009 | Pioneer PureVision PDP-610MX 61 in. Plasma...
No picture on Pioneer plasma
first of all check out the fuse that mostly get blowned out in this problems.if the fuse is perfect then it could be the faulty capacitor issue check out on the main board with the help of the multimeter and replace the faulty ones and it should work properly.
Dec 10, 2008 | Pioneer PureVision PDP-5030HD 50 in....
ESA plasma TV model pdp 4294lv1 does not work
my esa plasma tv model pdp 4294lv1 has sound and i can switch the tv channels, but the color is blurrier
Jul 22, 2008 | NEC - 42" Commercial Plasma Screen ****(no...
Televison & Video Logo
85 people viewed this question
Top Televison & Video Experts
