Question about Protron PLTV-32 Television
X-box 360 When i plug the hdtv jacks into comp 1 xbox plays perfect .but when i plug into component 2 i get a split screen.so my choice is to kepp unpugging it and change inputs.Or is there a better solution to this problem?
    Sniper:
  • 55 Answers
You can get a video selector which allows you to connect a number of hd sources to one component selection. Many Tv's of this type only allow you to use component one in HD the other component inputs will only synch with a non HD source like a 480p or 480i output
Posted on May 03, 2008
My xbox 360 causes my hdtv screen to crash and display colored static. It only does this on the 'optimal display' of 1680x1050. I plugged in my laptop on the hdmi and it worked perfectly. Is t
Try manually choosing lower resolutions in your xbox display settings. My Insignia HDTV does that when switching resolutions like on Hulu in between commercials and then back to the show but only for a second or so. Also does this when going from the loading screens to the game screens for a few seconds when playing the game Split/Second
Jan 10, 2013 | Microsoft Xbox 360 Console
How do I hook up Xbox 360 to the HDTV
Step 1:
Connect the audio/video input of the component cable into the "A/V" port located on the back of the xbox 360
Step 2:
Match the red, blue and green cables on the other end of the component cable to the corresponding component ports on your HDTV. If your HDTV has more than one set of component inputs, make note of which one you use.
Step 3:
Slide the switch on the component cable to "HDTV."
Step 4:
Turn on your HDTV. Set the video mode to the component port that will be used. HDTVs with multiple component ports will usually be labeled "Component 1," "Component 2" and so on
Step 5:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Choose the display setting (720p, 1080i and 1080p) that is best compatible with your HDTV. If you're not sure, try them all until you find the one that looks best.
Step 6:
Disconnect any previously connected A/V or component cables.
Step 7:
Connect the HDMI AV cable connector to the "HDMI AV" port on the Xbox 360.
Step 8:
Connect the other end to an available HDMI port on your HDTV. If your HDTV has more than one HDMI input, make note of which one you use.
Step 9:
Turn on your HDTV. Set the video mode to the HDMI port that will be used. HDTVs with multiple component ports will usually label them "HDMI 1," "HDMI 2" and so on.
Step 10:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Pick the display setting (720p, 1080i and 1080p) that looks best on your HDTV.
Dec 26, 2012 | Video Game Consoles & Games
How do i hook my XBOX-360 up to this tv and get 1080i resolution? Thanks, Mike
You should be able to get 1080i with the Input/DVI port or the component video in ports of the TV. I believe the easiest option will be to set the XBox A/V switch to HDTV and use a component video cable (red, green, blue) from the XBox component out to the TV Component In. (with the audio out going to your TV or speaker system). Turn on the X-box and the My Xbox > System Settings. Then Console Settings > Display and chose the 1080i.
Set the TV Net Command (remote) and the Device settings for the input jack in use (component 1/2). Adjust the A/V menu for the Display before playing long.
Wen you change inputs, you will see a status screen for the settings for the TV input.
I hope this helps.
Sep 14, 2010 | Mitsubishi WS-48513 48" Rear Projection...
How to split screen and play 2 games at once
It depends on if your tv is capable. If it is, then somewhere on you remote there will be a PIP button taht will allow you to do that and there should be another button that will allow you to pick the component for the second picture.
Oct 23, 2009 | Microsoft Xbox 360 Console
Cannont connect Ear Force X3 with my HDMI set up .
Is the problem that you're using a single HDMI cable to connect your Xbox to your TV? If so, this Turtle Beach article should help... ________________________________________
HDMI and Connecting Ear Force Xbox Headphones
The current Microsoft Xbox 360 series of gaming consoles allow the use of HDMI cables for simpler hookup to home theater systems and Hi-Definition televisions (HDTV).
The Xbox 360 Elite (the black one) comes with two additional cables, an HDMI cable and a separate AUDIO cable that provides a pair of RCA jacks (red and white) and an optical digital audio output (S/PDIF Out). With this cable package, you can easily connect any of our X-series headsets and an HDMI-connected television at the same time.
This Xbox 360 HDMI Cable package is available as an extra-cost option from Microsoft: http://www.xbox.com/en-US/hardware/x/xbox360hdmiavcable/
Here's a more in-depth explanation of the Xbox 360 HDMI Cable and how it works: http://support.microsoft.com/kb/937899?sd=xbox
[NOTE 1:] The standard Xbox models do not come equipped with this cable set. The HD cable they have obscures the HDMI connector, so that the two sockets cannot be used at the same time. If you only have this stock HD connector (component video, composite video, stereo analog audio and optical digital audio connectors), then you will not be able to use the HDMI connector at the same time.
In order to use both sockets at the same time (HDMI and A/V) you'll need to purchase the Xbox 360 HDMI Cable package described above.
[NOTE 2:] The current Xbox 360 Elite Holiday Edition (Fall 2009) does not come with the HDMI Cable set.
___________________________________________________________________
Some companies make aftermarket HDMI cables for use with the Xbox 360, but these may not provide the dual RCA jacks that carry the 2- channel analog audio necessary for hookup of the anlog-only Ear Force X-series headsets. If this is what you have, you may need to find another way to connect your Ear Force X-series headset.
The TOSLINK digitally-connected X-series headsets can be always be connected using optical digital "Toslink" connections (and that's the best way to use them!).
The oldest white-and-gray Xbox 360 models DO NOT have an HDMI port. With this particular (obsolete) model, you cannot use HDMI connections, but you can use any of our X-series headsets.
Current Xbox 360 models all have separate HDMI and A/V ports ("sockets") on their back panels.
Here are some suggestions for alternative connection schemes:
XBOX 360 AUDIO PLAYS THROUGH TELEVISION SET:
For X4 and X41: Your best bet would be to connect the Xbox optical digital audio out to the X4 transmitter's optical digital input. Then connect the X4 optical digital output to the optical digital audio input on your HDTV or home theater amplifier.
[NOTE:] Some HDTV systems have an optical digital audio output that will not transmit Dolby Digital/DTS encoded digital audio, only stereo PCM audio will be passed. In this case, you must connect as above.
For X2, X3 and X31: You can use the Headphones jack or the Audio Out jacks on your TV to connect to the Audio In jack on the Transmitter.
For X1 and X11: You can use the Headphones jack or the Audio Out jacks on your TV (if available) to connect to the headset's analog Audio Input.
NOTE: Please make sure your TV has Audio Out jacks. Some TV's only have Audio In jacks.
Audio In jacks only accept incoming audio signal; they do not send audio signal out. If no audio signal is being sent to the headset, no sound will play from the headset.
You may need to purchase a suitable adapter cable in order to connect the TV audio output(s) to the Ear Force X-series headset's transmitter or Audio Input plug.
- Connect the HDMI cable so that the Xbox 360 plays its audio through the TV.
- For X1, adjust the Dashboard > Settings > System > Voice in the Xbox 360 so that the talkback and game sounds are played together (Play Through Speakers). - For X3, X31, X4 and X41, you should set this to Play Through Headset.
XBOX 360 AUDIO PLAYS THROUGH HOME THEATER RECEIVER (except X4 and X41): This is exactly the same as the above, except that you will use the receiver's Headphones output jack to connect to the Audio In on the Ear Force Xbox-compatible headset's Transmitter (X2, X3, X31) or the green Audio Input plug (X1).
- You may need to obtain a shielded audio cable with 1/4" stereo phone plug to 1/8" stereo mini-phone plug ends. The 1/4" phone plug goes to the receiver's Headphones jack, while the 1/8" mini-phone plug goes to the Audio In on the Ear Force Transmit- ter (X2, X3, X31) or Audio Input plug (X1).
- Adjust the Dashboard > Personal Settings in the Xbox 360 so that the talkback and game sounds are played together (Play Through Both). For X3 and X31, you may also set this to Play Through Headset.
Mar 13, 2009 | Voyetra Turtle Beach Turtle Beach Ear...
I need help xbox 360 black screen
OK, I think I can slove your problem.
There is a slide setting thing on your av cord that gives you the option of using TV or HDTV (look near the end of the cord that slides into the XBOX 360), You will see two choices for settings on the cord "TV" or "HDTV".
Just make sure that you have it on the correct setting. I had the smae problem. My XBOX 360 is not hooked up to HDTV, so for me it should stay on TV. But somehow when I took out the cord I accidently slide it to HDTV.
I simply slide it back to the "TV" Setting and in about 30 seconds it worked perfectly.
I hope this helps you.
Dec 27, 2008 | Microsoft Xbox 360 Console
Xbox and tv = no sound
Yes, those cables are quite common. Check any electronics retailer like Best Buy or Walmart.
Aug 25, 2008 | Microsoft Xbox 360 Console
Component video inputs 1 and 2 look very fuzzy, but DVD component doesn't, 720P
Hello, I am sorry for your issue. The audio inputs should not matter. It sounds like those inputs do have a problem. Please contact Onkyo at 800-2291687 option #3 so that we can troubleshoot with you and provide options. Thank you, Onkyo USA
Jul 06, 2017 | Onkyo TX-SR304 Receiver
My xbox 360 game keep getting scratched when i play
http://www.llamma.com/xbox360/news/Xbox-360-Game-Disc-Scratched.htm
Jan 14, 2008 | Microsoft Xbox 360 Console
Protron PLTV-32 Television Logo
60 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
