Question about HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook
Hp pavilion dv2000 notebook will not boot up
Black screen with all lights on
having similar issue - stops at HP screen won't boot anyfurther - had similar prob with our dell, took out battery and just ran on power and it seemed to boot - this time, hopefully it will now be ok....dell said it was faulty/old battery when our other notebook was going through this, and it was but our HP isn't even 6mths old!!
  • 4 more comments
  • pseudonym7 Jul 10, 2008
    Same problem. Tried the remove battery. Press on switch for 30 sec. Use AC only. No joy. :-(
  • Kandavel D Aug 01, 2008
    I have start up problem with my HP Pavilion DV2000 Model, Windows vista installed to it...
    Problem Description:
    Pressing the power button at first time doesn't work properly....but if i try continiously it boots up some time... so the problem is unpredictable...
    Would do please suggest me...to clear up with this problem...
    Thanks,
    KD
  • MANISH2K76 Aug 10, 2008
    I HAVE USED A MMC CARD FOR STORING SOME DATE INTO IT. AFTER THAT MY HP PAVILION DV9310CA NOTEBOOK PC HAVING SOME PROBLEM DURING BOOTUP PROCESS. ALL LIGHTS ARE ON BUT NO DISPLAY GOING ON. WHENEVER MMC CARD READER LIGHT ON THE COMPUTER NOT BOOTING UP AND IF LIGHT IS OFF THE COMPUTER BOOT FREELY. PLEASE HELP ME
  • fxgfgx Aug 30, 2008
    have the same exact problem, I think mine is due to 2 things.
    1 - propable upgarade of ram to 2GB.
    2- cleaning with the dust remover spray whilst the machine was on.
    Overheating i guess is the last guess.
    Ive had a tOSHIBA/SONY/ACER/COMPAQ LAPTOPS BUT NEVER THIS KIND OF ******* PROBLEM BAST--- HP.
  • chacmool29 Aug 30, 2008
    lights on, no video lcd/external, I will contact hp hopping I got free repair due to a MOBO/BIOS failure.
  • Anonymous Feb 14, 2009
    HP Pavilion dv2621 Lights on but will not boot in. Last night changed ROM board and it worked, but tonight it has same problem --- Will not boot in
    Problem Solver:
  • 12 Answers
Problem with HP Notebook Or Laptops? Follow the links.
For Software problems you can visit a link by just Click Here .
For Hardware problems with this Notebook you can Click Here
Posted on Jul 23, 2010
  • 21 Answers
On the HP Pavilion DV2000, the real issue is caused by an ill fitting heatsink/fan combo. This assembly fits across the CPU and the video chip. As it does NOT sit properly on the video chip, this IC overheats and melts the solder that holds it to the motherboard, thereby opening the circuit, resulting in the same condition that happens when you unplug your video card on a desktop computer. To repair this is not hard to understand BUT requires quite a bit of physical skill as you need to resolder the micro traces on this surface mount device, then using a copper shim of an appropriate thickness (we are talking foil thin here) and GOOD heat sink compound on both sides of the copper shim, not the **** heat transfer pads HP uses, between the video chip and the heat sink and again, Good heat sink compound (think artic silver or better, this is CRITICAL) on the cpu, reassemble. THEN you need to go to HP and get the bios update and flash the bios. This is extremely important! the update keeps the cooling fan on full speed at all times preventing heat buildup which was the main cause of the failure to begin with. The copper foil I've successfully used is .0003" thick and a royal pain in the **** to find but is generally available from hobby shops on special order. Do NOT use aluminum foil! It will tend to oxidize after time and create a heat barrier and is too thick!
Posted on Feb 16, 2010
Ok, so a friend was having some problems with there laptop and I found the problem was the bios needed to be undated and was not. That really messed it up apparently and had many annoying side effects on the computer. If you have an HP and you are having this problem you may want to look at the following link to see if you can get yours fixed for free. This solved my problem hope it solves yours.
Posted on Jul 23, 2008
I am a tech and I am working on this one, I beleave the problem is on the Motherboard connection to the Bios meaning that I think the connection is getting corroided and not making a good connection but this is a gues after reading all the blogs, I have flashed the bios, replaced the ram, installed a new battery, did the f9 and f10 bios reset and unpluged everything and pluged it back in and still it only boots 1 out of five times. And look it can't be the ram connection because if it was the computer would fail in the OS and the bios is what tells the computer to function so if it won't boot at all it is ether a bios issue or a MB issue end of story what stinks is this is a manufacturering problem and should have been recalled by hp **** instead they will fix it for $289.00 witch is the price of a new MB + install and they won't tell you what the actual problem is! some won should sue.
Posted on Jun 20, 2008
I CAN SOLVE THIS PROBLEM BY CHANGEIN OF VGA CHIP AND IT WILL COST 600DHS ONLY OTHER WISE COMPANY HP IS CHANGING THE MAINBOARD
Posted on Feb 08, 2009
  • Scott Schoemann
    Scott Schoemann Jan 13, 2015
    there is no "chip" to change since HP does not sell them, and the original vga chip also has integrated I/O fuctions that control the throughtput of the hard drive and cd/dvd... this joker is simply resolderting the original chip
The solution I found that worked is:
(BLACK SCREEN ALL LIGHTS BLUE)
Press start up button for five seconds (ALL LIGHTS GO OUT)
Press start up button with single quick touch (ALL LIGHTS COME ON)
You will get BOOT UP screen
Press F10 (probably will say please wait)
BIOS screen comes up
Press F9 and YES (accept)
Press F10 and Yes (accept)
Should start up PC automatically
Posted on May 03, 2008
Laptop is having trouble booting up.
HP Limited Warranty Service Enhancement - HP Customer Care (United ... If you own an HP Pavilion dv2000, HP Pavilion dv6000, HP Pavilion dv9000 or Compaq .... Willthere be a future BIOS release that does not make my notebook fan remain ... Black Screen Error Messages that may Occur During Startup or Boot ...
h10025.www1.hp.com/ewfrf/wc/document?docname...lc=en...
Apr 05, 2010 | HP 417035-001 - HP Pavilion dv2000 Series...
My HP Pavilion dv2000 turns on, but screen is black
If the laptop appears to boot up but the LCD screen is black, then the problem is a back-light fault caused by either a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to determine the fault and fix :-
http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Mar 14, 2010 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Hp pavilion dv2000 lights switch on but boot or
Hi
Thank you for your query
Please try the folowing
1) Remove ALL wires and then press and hold the power button in for approx 20 seconds
2) Plug everything back in and then rerty
This may sort the issue out however from what you are descrbing, if there is no boot or display it is highly likely the motherboard and/or the CPU is faulty
I would recommend that you book the PC into a reputable PC repair shop if the above does not work
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again
Feb 15, 2010 | HP 417035-001 - HP Pavilion dv2000 Series...
Got a HP DV2000 boot then freezes
It seems that the problem is with the display chipset ( assuming its with Nvidia chipset model).
If you are not a technical person, take out the mother board and do a reflow of the chipset with a blower or else take it to a qualified service person or authorised service center.
Nov 09, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
HP dv2000-webcam displays black,lights on.
Common issue on this model. The problem is the GPU. Check out www.msbin.com you can reflow the GPU with that DIY guide.
Oct 04, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Remove yoru battery off and try powering on with the power cable plugged in.
Mar 28, 2009 | HP Pavilion dv2000t Notebook
Now, try this: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us&dlc=en&product=1842189&lang=en
Mar 25, 2009 | HP Pavilion dv2000t Notebook
HP Pavilion dv2000 Screen Flicker
Please replace the screen for optimal performance.
Do rate this.
Feb 25, 2009 | HP Pavilion dv6000z Notebook
hi,
i m in Hong Kong. The stupid HP repair center charged US 90 just for inspection!!!!! They they said the whole motherboard had to be replaced, thts additional US 630 dollars, the thing is just 1.5 yr old. They also said i don get to keep the broken mother board after replacement. This is simply irresponsible, unethical, sleazy and UNJUST!!
Thanks. right now the computer is fixed for US70. when i hv time, i'll open it up and see if i can figure it out how it was fixed. The shop suggested tht the computer wont last too long. This is such bad quality for HP... Sorry, i hv to do the following for other victims to find this easily:
(can some creative netizen bring this to the public light to pressure HP to do the ethical things??)
bad quality HP. hong kong HP pavilion dv2000 series manufacture problem. HP unethical.
Sep 21, 2008 | Computers & Internet
DV9205eu display problem
HP has identified a hardware issue with certain HP Pavilion dv2000/dv6000/dv9000 and Compaq Presario V3000/V6000 series notebook PCs, and has also released a new BIOS for these notebook PCs, version F.39 for dv2000/V3000, and version F.3D for dv6000/dv9000/V6000.
Click HERE to update your BIOS
May 03, 2008 | HP Pavilion dv9000z Notebook
HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook Logo
3,705 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
