Question about Meade ETX-90 (48x90 mm)
One of the gears in the Azimuth motor got a flat spot because the worm gear was adjusted too tight. It is a 24 tooth nylon straight gear, very small- only about 1 cm across, but if this gear isn't working then the azimuth motor makes a good doorstop!! Who knows where to get replacement parts for these badly designed telescopes?
  • 1,689 Answers
Below is the contact information for Meade parts. They are the only reliable source unless you know a local dealer that you can trust.
Jerry G.
Meade Instruments Corporation
6001 Oak Canyon
Irvine, CA 92618
(800) 626-3233 (U.S.A. Only)
Fax: (949) 451-1460
Posted on Apr 30, 2008
There are no adjustments for this machine. Chances are that the plastic gear that is driven by the worm gear has a spot that is worn down and when worm gear hits this spot, it does not drive . Replacing gear is the only remedy. Good luck.
Jul 13, 2013 | Fellowes MS-460Ci Shredder
I have a KitchenAid stand mixer model KT2651X. It recently ground down the worm gear follower, which I purchased a new one along with a new worm gear because this is not the first time it ground down that...
It is not a good idea to modify anything in the unit to make part(s)
designed for another model fit. The KT and KP models have different
part numbers for the motor. I still don't understand why do you have to
change motor in the first place, just because the Worm Gear Follower
has to be replaced. Something is telling me, you have just purchased
the wrong part (Follower). The KT2651x is similar to the KP26xxx
latest models and the Worm Gear does not come with the Follower.
(i.e. they are 2 different distinct parts)
Jul 20, 2011 | KitchenAid Food Mixers
Model 139.53930DM I adjusted the chain and now door only goes up 12" (too tight?)
The chain might be to tight but I think you should check for broken door springs or a bad drive gear. The gear is white nylon and is just in front of the motor. The chain should sag just a bit.
Sep 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Trying too move automatic seat forward again/ only left side move
the seat adjustment motor which is mounted in the foward part of the lower shroud of the seat has two drive worm gears which are made of a heavy coiled spring if either one of these become loose or the drive portion becomes damaged that side of the seat wont drive in either direction
Apr 01, 2009 | 2004 Infiniti G35 Sport Coupe
Hobart A200 Worm Gear Shredding Brass Gear
no there are no adjustments . you must have bent the case just a little , i dont see any good news for you , sorry . i have worked on hobart mixers for years and you should get 5-10 years out of that gear
Jan 15, 2009 | Hobart A200 Stand Mixer
Garage door will not open or close
I had the same problem, mine was just the white Sprocket assembly, it stands straight up, there is another one which is the Worm gear, mine was fine. I read on some other post, when you take off the panel, and if you see a lot of white dust (shredded white plastic) then its the gear. Went to Sears warehouse, had the part in stock and replaced it myself. Had to just unbolt the Sprocket assembly from inside (3 bolts), pull out from the top, a little hassel, but got it done. Follow the instructions and you will be fine. Remember after greasing up the sprocket like it says too, take the time to use some silcone spray on the springs and rollers, a lot of people forget to do this, even me...
Dec 20, 2008 | Sears Craftsman LiftMaster Chamberlain...
Azimuth motor gearing problem
Sounds like it could be that the worm gear is not meshing
Look here for guidelines in the internals
Oct 15, 2008 | Meade ETX-125EC (500 x 127mm) Telescope
Chamberlain Power Drive 1/2 HP - motor runs but does not move chain
I have the same problem. I just removed the cover and discovered a nylon gear had been worn out. I found lots of shavings inside the cover. The nylon gear is beneath the exterior chain gear. I am looking for information on how to replace it, if I can find the part. If you decide to look at yours, unplug the power and remove the sheet metal screws securing the bottom portion of the cener cover to the front and back covers. Then just remove the upper screws from the center cover. Good luck.
Oct 08, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
I also purchased a used Meade ETX-70, only to find it had the same problem with the rotation axis motor running but no movement. After removing the bottom cover, I found the motor w/worm gear would not contact the main rotation gear. I solved the problem but purchasing a small 3/8x3/4x.032 spring that I had to custom fit to hold the motor w/worm gear against the rotation gear. Take caution not to have the spring apply to much pressure or it will cause to much drag.
To gain access, remove the bottom round cover(it will just pop off).
Then use a small .05 allen wrench to remove the set screw in the horizonal chrome lock. The chrome lock fits over a 1/2" bolt. By removing this bolt you will remove the washer/bearing assembly. After removing this, you will see a nylon nut, use a 11/16 socket to remove. Becareful, it is a fine thread and you don't want to cross thread it!
After you remove this, you will be able to remove the bottom housing, which will expose the motor and gear. You should be able to see what I am referring and where to place the spring.
If you can make it this far, then you should be able to install the spring. I used a little small dab of Gorilla glue to hold it in place, since the spring will have enough constant tension to keep it from moving.
I'm not sure if this was a design flaw, but I got no help from the Techs at Meade, only that they would upgrade to a ETX-80 for $149.99 plus shipping.
Hope this helps.......
Aug 12, 2008 | Meade ETX-70 (240 x 70mm) Telescope
Meade ETX-90 (48x90 mm) Logo
186 people viewed this question
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Level 1 Expert
Greg Cann
Greg Cann
Are you a Meade Optic Expert? Answer questions, earn points and help others
