Question about Car Audio & Video
Car stero i need to know if the power plug .not the speaker plug. if all wires on that plug go to a 12 volt power source. mdevore@interlinc.net. thanks 1993 mercuy grand marque with amp
  • 1 more comment
  • turkey dog Apr 30, 2008
    any idea what color ground wire might be
    mabee blue with white stripe
    could it be the blue wire with white stripe ground
    Genius:
  • 3,587 Answers
Yes..that's where they go..the also may be a ground wire, that goes to a point on the chassis(like a mounted screw or bolt).
Posted on Apr 30, 2008
  • Patrick Michaels
    Patrick Michaels Apr 30, 2008
    be mindful of the polarity(red for positive, black for negative)..
  • Patrick Michaels
    that is possible, as long as the red/black go where they need to go..do you not have a diagram with this unit?
How do I make sure that my Pioneer in-dash is working before installation
If you have access to a car battery charger or other 12 volt battery source, you can twist the 12 volt memory and accessory wires together (yellow and red) and attach those to the positive voltage source. Connect the ground wire (black) to the negative source. This will allow you to turn on the unit. Now, you need to have a sound source, and at least one small speaker to test with. Use a CD (simplest) or USB stick with music, or bluetooth enabled phone, whichever will work with your radio to provide music. If you have a bookshelf stereo speaker, or even an old speaker from an alarm clock that should work fine. With your radio powered on, music playing, volume turned up to a moderate level, touch each of the radio's 4 speaker channel's wires to your speaker and make sure you hear sound. If you don't have a car battery charger handy, you can also use an electric drill battery but be sure you know which battery terminal is positive and which is negative before you connect your radio. Another source of 12 volt power may be any number of power adapters that plug into an AC outlet, but you will need to proceed with caution. Check the back of the outlet and note the DV power output, as well as the current output (measured in amperes, or denoted with "mA" or "A". You will need a few amps (not milliamps) to turn on the radio, and at least 12 volts. You'll have to cut and strip the wires, so it's important to know which is positive and which is negative before connecting your radio to the wires. Again, please exercise extreme caution. Do not short the wires together or connect them to your radio in reverse once the adapter is plugged in. Do not perform ANY wire work while the adapter is plugged into the wall.
Jan 06, 2018 | Pioneer Computers & Internet
Want to use removed 95 Nissan Maxima's radio unit and 2 rear speakers as a stand-alone system at home. How to apply +12 V to the radio unit and speakers? Which wires (out of plenty of them exposed) sh
red is normally power in and black is normally earth wire. Get a 12 volt dc transformer that plugs into the power outlet and get the plug jack socket from a electronic shop and solder the wires correctly (red to centre pole ) and it should work . You will need a high wattage transformer for this.
Nov 12, 2013 | 1995 Nissan Maxima
I want to install a aftermarket stero cd player in 1998 zx2 ford escort
Car stereo cd player are 12 volt you can connect polarity to battery line1 positive(+) and line 2 negative(-) need a fuse 2 ampere for line 1 protection for continue use and the speaker are left and right at the back or RCA jack red and white color or either.
Oct 21, 2012 | Ford Escort Cars & Trucks
I hooked up a JVC stero in my 1991 Nissan truck. Now the memory is wiped out for the radio + factory clock when I turn off the car. The radio will come back on, but no presets works.
Chances are that you do not have the constant 12 volt power of the vehicle connected to the memory wire of the stereo. The yellow memory wire of the stereo should be connected to the vehicles' battery. The red accessory wire of the stereo should connected to a switched 12 volt power source.
May 26, 2011 | JVC AM FM CD DET FACE CAR STEREO
The radio will no turn on. we have all the wires connected the power cord is plugged in but when we press and or hold the mode button nothing happens. its a new radio that we are installing that was bought...
If it is a new radio first make sure your power wire is actually hot. Use a multi meter. Also you may have a blown fuse in the fuse panel. Check that. Make sure it is grounded as well. Improper ground will make it not power on as well. For this radio Blue = Remote that you run to your amp or power antenna. Insulate it if you are not using either. Black is Ground. Red = Your accessory wire and should only get 12 volts when the key is turned on (switched 12 volt source.) Yellow is your continuous power source. Hook this to your battery or other suitable continuous 12 volt power source. It also has a 5 amp fuse inline. Make sure it did not blow. Replace it to be absolutely sure. Use another 5 amp fuse. Never go higher. The other wires are for speaker hook up. If you do all this and still no power. You may have a faulty radio. Good luck.
Mar 06, 2011 | Car Audio & Video
Can kicker 1000x1 amp detect if my speaker is bad and turn itself off?
The Kicker 1000x1 Amplifier does not turn off if their is an Open Line (blown sub) on the Speaker Terminals.
  1. Remove all Speaker Wiring from the Amplifier, leaving the Power, Ground, Remote, and RCA wires plugged in.
  2. If the Amplifier fails to turn on, check your Remote wire for power.
  3. If the Remote wire is powering up with the Head Unit (should be anywhere from 5-12 Volts), check your Power wire for +12 Volts, and check your Ground wire.
  4. If you are getting +12 Volts Power and your Remote wire is putting out 5-12 Volts but your Amplifier still won't turn on, it will need to be serviced.
Jul 24, 2010 | Kicker ZX10001 Car Audio Amplifier
NEED TO KNOW WIRING DIAGRAM FOR KE 1033 PIONEER
The wiring diagram for a KE 1033 is exactly the same as the KE 1900, both have only 8 wires coming out of their harness plug. Solution:
>Black>Ground>Wire #8
>Red>12 Volt ignition wire> Wire #7
>Green>Speaker Left Front Negative>Wire #6
>Green with Orange Stripe>Speaker Left Front Positve>Wire #5
>Grey>Speaker Right Front Negative>Wire #4
>Grey with Orange Stripe> Right Front Positive>Wire #3
>Orange>12 Volt Battery Wire> Wire #2
>Blue>Power Antenna> Wire #1
I hope this helps everyone.
Jul 17, 2010 | Pioneer Car Audio & Video
Wiring diagram for a Sony XR-C210 car stero
SONY XR-C210, XR-C214
1-GND
10-+12 VOLT BATTERY WIRE
16-Speaker RF-
5-Speaker RR+
11-+12 VOLT IGNITION WIRE
17-Speaker LF+
6-Speaker RR-
12-Power Antenna Turn On
18-Speaker LF-
8-Speaker LR+
13-TEL MUTE
9-Speaker LR-
15-Speaker RF+
Sep 13, 2009 | Sony Car Audio & Video
Need to know what color 12 volt supply
My manual for a 99 300M shows two sources of 12 volt power to the mirror positioning switch, One is from the battery, switch terminal 11 wire M1, PK (pink). The other is from the start-run 12 volt line, switch terminal 5, wire G5 DB/WT (dark blue, white stripe). If you send me your email address to af6im at arrl dot net I can send you a scanned copy of the diagram.
Jun 27, 2009 | 1999 Chrysler 300M
Clarion marine stereo M2455
Don't worry about the brown wires. They are for telephone mute.
The yellow is Memory (constant 12 volt, so battery is fine), but the red should go to a 12 volt source that turns on and off with the key.
Aug 05, 2008 | Clarion DB245 CD Player
Car Audio & Video Logo
61 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
