Question about Compaq 56K Modem
Printer cable I just bought a HP Deskjet printer this afternoon. Having not installed a printer before, I can not seem to find where I connect the USB cable device into the back of my modem. I have a HP monitor, but a Compaq modem. Does Compaq not have a printer connection?? HELP!!!
  • 975 Answers
Your HP printer connects to an USB slot on your computer, not on your modem , now if your printer FAXES then you connect a phone cable to your MODEM . HOPE THIS HELPS ,please rate this solution AJ
Posted on Apr 30, 2008
Tip
EZ steps to install HP printer in Windows 7 without Installation software
  1. Make sure that the USB cable is not connected to the product. If the USB cable is connected to the product, disconnect it.
  2. From the Windows taskbar, click the Windows icon, and then click Devices and Printers. The Devices and Printers window opens.
  3. Click Add a printer. The Add Printer window opens.
  4. Click Add a local printer.
  5. Click Use an existing port.
  6. Click the Use an existing port drop-down list, select LPT1: (Printer Port), and then click Next.
  7. Under Manufacturer in the Install the printer driver window, click HP.
  8. Under Printers, select approriate drive from below list provided and then click Next.
  9. In the message window, click Finished.
  10. Connect the USB cable to the product, and connect the USB cable to the computer. A Device driver software was not successfully installed window opens.
  11. Click Close to close the window.
  12. In the Devices and Printers window, right-click the name of the product and then click Printer Properties. The Printer Properties window opens.
  13. Click the Ports tab.
  14. Click the drop down menu, and then change the port from LPT1 to USB or DOT4.
  15. Click OK.
  16. In the Properties dialog box, click the General tab.
  17. Click Print Test Page.
Determine the appropriate compatible driver
Deskjet 3320, 3325, 3420 and 3520 -------------Deskjet 3600 *
Photosmart 7600 series------------------------------ Deskjet 5600
Deskjet 5850 ---------------------------------------------Deskjet 5600
Photosmart 130, 145, 230 and 245 ---------------Photosmart 330 *
Photosmart 7350 and 7550 --------------------------Deskjet 5550
Deskjet 6122 and 6127 --------------------------------Deskjet 990c *
Deskjet 3820 -----------------------------------------------Deskjet 970cse *
Deskjet 656 ------------------------------------------------Deskjet 660c *
Business Inkjet 1100d ---------------------------------Business Inkjet 1000
Business Inkjet 1100dtn ------------------------------Business Inkjet 1000
Deskjet 9300 ----------------------------------------------Deskjet 1220c *
Deskjet 9650, 9670, 9680, 9680gp---------------- Deskjet 9800
* Available only through Windows Update.
(Happy Printing)
Regards
Rizwan
on Jan 29, 2010 | Office Equipment & Supplies
I have an hp desk jet 3322 printer no cd need to install and configure can u help?
What Operating System do you have? If you have 2000 or XP here are the drivers:
Drivers for XP or 2000
Drivers for Vista + WIndows7
The alternative driver is Deskjet 3600
Or
HP itself for Drivers for Vista + Windows7
Installation
Also note once you get the driver if you are using a USB cable to connect it to the PC, that you install it like this:
1. Make sure the USB cable is not connected to the PC but connected to the Printer
2. Install the driver
3. When prompted then plug the USB cable into the USB port on the PC to complete the installation process.
Mar 16, 2010 | HP DeskJet 3322 InkJet Printer
I have a hp deskjet 610c printer and would like to print
helloo....cable join with computer..n go file menu..then print then select ur printer n get print...........
Feb 27, 2010 | HP DeskJet 610c InkJet Printer
Cant install my hp deskjet 3325 printer to the windows 7
At this time, a full feature Windows 7 driver solution is not available for your product.
Follow the below steps to install your printer in Windows 7.
  2. From the Windows taskbar, click the Windows icon, and then click Devices and Printers . The Devices and Printers window opens.
  3. Click Add a printer . The Add Printer window opens.
  4. Click Add a local printer .
  5. Click Use an existing port .
  6. Click the Use an existing port drop-down list, select LPT1: (Printer Port) , and then click Next .
  7. Under Manufacturer in the Install the printer driver window, click HP .
  8. Under Printers , select Deskjet 3600 and then click Next .
  9. In the message window, click Finished .
  12. In the Devices and Printers window, right-click the name of the product and then click Printer Properties . The Printer Properties window opens.
  14. Click the drop down menu, and then change the port from LPT1 to USB or DOT4 .
  15. Click OK .
  17. Click Print Test Page .
Regards,
Rizwan
Jan 29, 2010 | HP DeskJet 3325 InkJet Printer
My father bought me a new printer. The printer is a HP Deskjet D1460 and my laptop cannot recognize the printer. My OS is vizta
  1. Verify your USB ports are working properly by plugging any other devise. Eg. Pen Drive.
  2. You have to 1st install the software and then plug the printer, If you plug the printer before install software it wont detect sometime.
  3. Then If you are using a lengthy cable to connect printer, Try with a shorter cable. Some HP printers does not support long cables
Dec 17, 2009 | HP LaserJet 1300 Printer
I just bought a hp deskjet f4280. when i click hp solution centre a message (no device have been detected. hp solution centre will close now.) displays i have tried everything nothing seems to work
*** UNPLUG THE USB CABLE********
just insert the disk and then click on add a device
dollow the instruction
plug in the usb when asked
and if the printer detection goes fine and the installation is successfully completed
the issue will be resolved
Nov 01, 2009 | HP DeskJet F4280 All In One Printer InkJet
Where do I connect the usb cable from my printer to the pc.?
First thing to do install the driver CD of the printer, After the installer searches for the hardware or your printer, plug the printer to the power outlet as well as to the USB port of your PC as shown below, and power on the printer, wait until the installation completed successfully.6278244.jpg
Oct 21, 2009 | HP Deskjet 3845 InkJet Printer
HP Deskjet 930C USB connection
Yes but you may have to re-install the software for the camera. If so,
Normal 0 Try disconnecting the Camera from the USB port and reinstall the CD software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
Jan 12, 2009 | HP DeskJet 930c InkJet Printer
Problem with hp deskjet 3920
If your printer connects to your PC with a USB cable, there is a specific sequence. Some setup programs want the USB cable connected after the driver is installed, others want it connected first. Try reinstalling the driver and pay close attention to the setup instructions.
Sep 12, 2017 | Office Equipment & Supplies
Compaq 56K Modem Logo
99 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
