Question about EliteGroup ECS GeForce6100SM-M (1.0) Socket AM2/ MCP61S/ SATA2/ A&V&L/ MATX Motherboard
Beeping from motherboard ECS Geforce 6100sm-m
I install everything except the SATA dvd-r. when i tried to boot it up it just beeps continuously. What can the problem be? Hope you can help me. thank you
  • crakon Dec 12, 2008
    i have tried changing the the memory and still have the same problem, the memory i used was brand new and i have tested it in another pc, ddr2 667 1024mb, please could you give some other suggestions for this constant beeping and not loading anything on the screen.
    thankyou...................russ
    Genius:
  • 1,027 Answers
BEEPS on boot is normally RAM memory problem.
Posted on Apr 30, 2008
My pc is hanging and when restart dont show disply and beeping ecs geforce 6100sm-m2
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM and Cmos battery are securely seated
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
if faulty can affect your picture screen
a computer needs its connections to continue its cycle and to have and end to function
the beeps are post pre operating system searching for some hardware it could be RAM cd/dvd hard drive or motherboard all of these must have secure connections for the computer to work
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure make sure the connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs all electric current and computer data to travel to and through every working device and have an end to work properly click start right click on my computer so any faulty leads will end up with a computer error
if you need more help with this post a reply
hope this helps you
Aug 29, 2011 | EliteGroup ECS GeForce6100SM-M (1.0)...
After downloading drivers from ECS site for geforce 6100 sm-m i still do not have ethernet adapter. Also other pci bridge device is missing. In XP
since your not able to install the drivers..
Broadcom AC131 10/100 driver is the same as nforce 430/410
http://www.nvidia.com/object/nforce_nf4_430_410_winxp32_8.26.html
or
http://www.broadcom.com/support/ethernet_nic/downloaddrivers.php
then try installing Uniblue DriverScanner or Driver Genius Professional Edition so you can get all the other drivers for you motherboard
you can also try to update your bios only for ecs 6100sm-m mobo
http://drivers.softpedia.com/get/BIOS/ECS/ECS-GeForce6100SM-M-V10-10A-BIOS-070906.shtml
hope this helps..
Dec 31, 2009 | EliteGroup GeForce 6100SM-M Motherboard
Can cpu multiplier be set on ecs 6100sm-m mo bo?
Yes, I use AMD's program called Overdrive.
Be warned that increasing the mulipler also increase the voltage, don't go to high or you will have a smoked processor.
Apr 17, 2009 | EliteGroup GeForce 6100SM-M Motherboard
Cannot Install 2 GIG Memory Upgrade
you got the DDR 2 RAM right? and wont boot you say means you don have even the power on in the CPU or no display?
Jun 16, 2008 | EliteGroup GeForce 6100SM-M Motherboard
ECS 6100sm-m
Download WD's software to test & setup drive. Try windows install again.
WD's link; http://support.wdc.com/download/index.asp?cxml=n
Mike
Apr 25, 2008 | EliteGroup GeForce 6100SM-M Motherboard
EliteGroup GeForce 6100Sm-M Problem
4 things can cause this MB to do as you mention.
Bad CPU or the MB is not sensing the CPU fan and is protecting CPU from overheating.
Bad or inconpatible memory, If multiple sticks use only 1 at a time, This MB is known for having problems with both slots filled most of the time bios resaves can fix this but just set up with 1 first.
Reset the bios, Make sure the reset jumper is set back correctly.
Make sure it post without any extra harware hooked up first then add them.
The beeps are a old style of signaling the problem, You can find charts online that will tell you what the beeps mean long and short.
Nov 27, 2007 | EliteGroup GeForce 6100SM-M Motherboard
GeForce 6100SM-M Motherboard (no Audio )
I down loaded Realtek HD audio drivers from
http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=685&DetailName=Driver&DetailDesc=GeForce6100SM-M(V1.0/1.0A)&CategoryID=1&MenuID=75&LanID=0
Oct 24, 2007 | EliteGroup GeForce 6100SM-M Motherboard
EliteGroup ECS GeForce6100SM-M (1.0) Socket AM2/ MCP61S/ SATA2/ A&V&L/ MATX Motherboard Logo
629 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
