Jombo remote control
How do you seach for the code of tv /dvd and tv
  • lost info May 01, 2008
    I would like to know how to search for codes on my jumbo universal remote. thanks D.J.
    President:
  • 2,712 Answers
You can find the remote control codes for difrent brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on May 02, 2008
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved.
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
      (Positive Rating)
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
      (Positive Rating)
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated. (Negative Rating)
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
      (Negative
      Rating)
    If your issue is not still not resolved, do not
    IrishDruid
I have a jumbo remote and canter find the code for a dynex tv does anyone know
Click here to download the user manual to Jombo remote. Check whether there is any setup codes for Dynex in its code list. All details are in this manual.
Apr 16, 2012 | Sharp Televison & Video
Trying to find out how tostart automatic code seach for tv so I can set the code and use the remote for my old daewoo tv
Try Aim tOn the remote control, press TV once. Press and hold SET until the LED (red light) blinks twice, then release SET. Enter 9 - 9 - 1.
Aim the remote control at the TV and slowly alternate between pressing POWER and TV. Stop when the TV turns off (after pressing POWER).
Feb 19, 2011 | One For All URC4220 Remote Control
Need control code, to operate dvd samsung
Yes. I found the code. To operate Samsung HT-Z 310 with a remote control of Samsung TV, You have to turn off DvD, and then select Dvd on the remote(press the dvd button), press SET on YOU
remote control, input the CODE(020). For different Samsung dvd. you can try.codes from 000-to 080. The DVD button must blep three times. After that swich on Dvd. Enjoy....
May 04, 2009 | Samsung TV Remote Control
Total control codes urc 11-2082
code for autormatic seach total control urc 11-2082 b00
Apr 20, 2009 | Televison & Video
I have a phillips 5 unit controller with no code seach button what button do i press
If it did not come with codesearch button AND it was the original remote that cam ewith the V, just point the remote at the TV and press the power button for 10 seconds - it should program
I'm just going based on the information that you provided.
Philips has a 7-day-a-week helpline at 1-888-philips
Jun 14, 2008 | Philips Magnavox Learning Universal Remote
Pioneer XV-DV99 high definition DVD/Rewriter
Try one of these codes:
221, 222, 154, 160, 174, 180
Or use the Seach feature:
  • Manually turn on the device you wish to scan for (e.g. TV)
  • Perform Power Scan by pressing and holding (approximately 3 seconds)the desired DEVICE MODE button TV, VCR, CBL, DVD or SAT until the status indicator light begins to blink.
  • Press and release the PWR (power) button. The status indicator light will stop blinking and stay ON at this point.
  • Press and release slowly and patiently the blue UP ( ? ) button to scan forward through the code database. To scan backward through the code database, press and release the blue DOWN ( ? ) button. Each time you press the up or down arrow, the remote will try and turn off the device (TV, VCR etc) you originally selected.
  • When the device (TV,VCR etc.) responds by shutting off, press the ENTER button. This will store the code
  • in memory and you will see three blinks of the status indicator light to confirm the code input. Be patient, there are over 100 codes to search through.
Hope that fixed ya...
Geno
Mar 28, 2008 | Televison & Video
Televison & Video Logo
66 people viewed this question
Top Televison & Video Experts
Electro Med Services...
