Question about Toshiba 50HP66 50 in. Plasma Television
Flashing boxes on screen
My toshiba tv is almost 2 years old. The last 4 months we've experienced flashing boxes that have characters, are solid, or opaque inside. The flashing boxes appear from top to bottom of the screen and are in the middle 1/3 of the screen. The boxes are small and rare about 40 or 50 vertically and 20-30 horizontally. The boxes happen to show up exactly in the same location the menu is located (if you were to turn on the tv menu). The boxes don't show up everytime, at first, but gradually show more and more and finally appear everytime we turn on the tv - but only when we turn on the tv. Also, the menu options turn into a bunch of english letters that don't spell a word, or omit letters within the word. SAT will become AT.
We use HDMI connections and have used both HDMI inputs to make sure it is not a bad connection. The symptoms so far have only happened with the input that accepts the satellite receiver signal. We have not experienced this problem with our HDMI DVD player. The satellite company says it is definetely not the satellite receiver, and the tv repair center hasn't been able to figure out (in 2 home visits and 2 shop visits) what is wrong either.
Please Help
    Master:
  • Toshiba Master
  • 708 Answers
Hdmi splitter and hdmi switcher are different,i bought a hdmi splitter and it works perfect,see details: Amazon com MALLCROWN 3D 1080P 4 Pport Hdmi Splitter with ac power adapter...
Posted on Nov 21, 2016
    Genius:
  • Toshiba Master
  • 1,673 Answers
Regardless of what the satellite company says, I would find a way to try another satellite reciever to start with. I have seen this from cable boxes and satellite recievers many times. I have also seen this with a bad LNB, distribution amplifier, or a bad active splitter, or a bad cable, or a bad connector.
There is a data loss somewhere, and the set is seeing what we call aliasing. This is a loss of data, and it shows as blocks.
It is possible for your set have internal aliasing if there is a fault on one of the processor boards. The only way you will easily know if the problem is external or internal to the set is to try another source.
From your description, if other sources work with the set, then this strongly rules out the set. To easily know if the fault is on the input that the sat reciever uses, if possible swap the position with the DVD player.
On the sat system, a defect in the reciever, the LNB, or any LNB splitters or a relay, or a bad connector, can also cause aliasing because of a signal loss.
Jerry G.
Posted on Apr 30, 2008
Hi! My toshiba 2100td tv is over 10 years old and last few years it's having weird problems. When it's turned completely off (not in standby) and when I turn it on, the screen blinks for a 10-
The real problem here is its age, a lot of these sets of that age critically needed parts are just no longer available.
I repair them but the real risk is someone fixed it, a few months later it develops another problem etc etc etc.
Ten years is now a days a long life for a TV.
Apr 16, 2012 | Televison & Video
Tv turned off by itself, red light came on. when i turned it back on if had a flashing green light the turned solid green, there was sound but no picture, it turned off again within 2 minutes of turning it...
Tv probally needed a new tv projection lamp.This tv has not been change it projection lamp like 1 1/2 or 2 years already?Tv been on and used it like 4 or 5 hours everyday?Yes,than the tv flashing or solid on green LED light is on have a word "LAMP" written on it tv bazel frame?Yes,tv 100% require a new tv projection lamp replacement.
Aug 31, 2011 | Mitsubishi WD-73737 73 in. HD-Ready TV
Toshiba regza 32hl67 losing its' picture and motion is slow
I have a toshiba regza 32hl67 LCD tv which is only 2 1/2 years old. The picture on this unit just started to go the other day (screen darkens but images are still visible and the motion/movement is very slow). I contacted Toshiba and they just said to unplug the tv for 3 minutes to reset the tv. This doesnt work. I am VERY upset with Toshiba, after paying $800 for a tv that only lasted 2 1/2 years. If anyone has had similar issues and know how to fix it, please let me know. Thanks
Apr 26, 2010 | Televison & Video
More of a Toshiba statement.
My 52 in regza has a vertical line on the right side as well just under 2 years old, out of warranty and to costly to repair, I paid $2500 as well. The TV has been on its stand since the day I bought it and has been moved once.
I have read of others who have this problem as well, just google toshiba regza red line, or vertical line
I Too will never buy Toshiba products and I will tell everyone I can about the **** LCD Toshiba
Jan 19, 2010 | Toshiba Regza 52XF550U 52 in. LCD HDTV
My 52inch xbr4 tv is 2 years old. Intermitently over past 2 months, when I first turned it on, I get thin vertical lines and double imaging especially over left half of screen. After a few minutes it would...
I have the same issue. Bought the TV 1/08 and it started showing those exact symptoms about 3-4 months ago. It generally progresses and gets worse. You can try to fix it as it's some kind of TAB connector issue, or keep calling Sony so that the 52" owners of the XBR4 and 5 series get the extended warranty just like the 46" owners received for the same series. If enough of us keep calling, they'll have to act.
Jan 18, 2010 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
No picture, siren type noise as restarting
My Toshiba dlp 62hm116 was used for 3 months then stored for 2 years, I turned it on yesterday and it makes a loud grinding noise which I think is probably from the exhaust fan area and the picture is black except white at both vertical sides. It worked fine the last time I used it 2 years ago. Any ideas?
Jan 13, 2010 | Toshiba 62HM95 62" DLP HDTV
Toshiba lcd series 6, 18 month old tv will not
consult manual for troubleshooting it could be that lamp in tv takes long time to cool down or that it is bad they usually last about 2-3 years depends on how you use your tv
Dec 31, 2009 | Toshiba Toahiba Satellite A70 A75 M35...
14 MONTH OLD TOSHIBA TURNS OFF BY ITSELF
I repair a lot of these and a average tv lasts like 3 years . It is not like the old days. I suspect the lamp or fans or therm protector.
I would call a local tv shop see what they charge for estimate it might be worth his estimate to find out what it is.
Thanks doctor video
May 27, 2008 | Toshiba 52HM95 52" HDTV Projection...
Aging 43H7143
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 24, 2007 | Toshiba 43H71 43" Rear Projection...
Toshiba 50HP66 50 in. Plasma Television Logo
199 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
