Question about Viking 24 in. Professional Series VUD040 Stainless Steel (Premium) Built-in Dishwasher
Viking Dishwasher I have a Viking dishwasher and it will not fill with water. It will, however, drain water. Thanks.
  • 205 Answers
Probable cause is either a bad fill valve, common with these, or just some debris in the fill valve inlet screen, also common. If you are handy you can take apart the fill valve and check the screen but often one needs to replace the whole valve, about an $80 part + labor. Double check your valve under the sink and make sure it is on completely.
Posted on Jul 21, 2008
2 Suggested Answers
  • 4 Answers
SOURCE: Viking Dishwasher won't fill with water
NEED TO CHANGE THE ELECTRIC TAP IN THE BACK OF THE DISHWASHER.
THE TAP IS WHAT THE WATER HOSE CONECTS TO AT THE BACK OF THE MACHINE.
Posted on Oct 14, 2008
Standing water Viking dishwasher
try removing the panel on the front at bottom & remove the drain hose & let it drain try putting a bowl under it. u might have a clogged pump .
Aug 10, 2012 | Viking DFUD142 Built-in Dishwasher
My Viking Dishwasher is about 7 years old and it does not fill with water
The water that fills your dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with your dishwasher's filling ability.
Nov 20, 2010 | Viking DFUD04 Built-in Dishwasher
My bosch dishwasher isn't cleaning the dishes lately
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump.
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Dec 08, 2009 | Bosch SHU9915UC Dishwasher
Westinghouse SB907 - Water draining out right after filling up
The drain hose has to have a loop in it. In other words as the drain hose exits the dishwasher, it must go up at least 18 inches before it goes down into the drain. If not, the water will siphon out of the machine.
Apr 17, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Oct 14, 2008 | Viking 24 in. Professional Series VUD141...
UNIT FILLS AND PUMPS OUT CONTINUALLY BUT WILL NOT WASH OR CYCLE
you may have a defective pressure switch, this is located on the back of the well, access from the rear of the unit. It black with an orange sticker, from the rear it is slightly to the right of the well, but not as far round as the drain pump.
Mar 13, 2008 | Viking 24 in. Professional Series VUD141...
Washer
If I'm not mistaken, these dishwashers are built by Asko for Viking. If thats the case then you probably have a bad circulation pump. Under Asko's warranty (not sure if Viking is the same) these pumps are covered parts and labor for 3 years from installation date, and 5 years for the part only. The pump is accesed from the back of the machine,so you have to pull out the dishwasher. Then you remove the lower plate in the rear and the motor at the very back center is the pump. You remove it by turning it about a 1/4 turn either clockwise or counter clockwise, depending on the style, then place the new one in and turn it to lock it in place, being careful that the sealing oring stays in place or youll get a leak. The part will probably cost you around $150 unless viking marks theirs up more than Asko. Good Luck!
Nov 22, 2006 | Viking 24 in. Professional Series VUD040...
Viking 24 in. Professional Series VUD040 Stainless Steel (Premium) Built-in Dishwasher Logo
474 people viewed this question
Top Viking Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Lloyd Carter
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
