Error code 010-333. thermistor heating up. I have replaced new Fuser Assy installed this also has come up with same error code 010-333 straight on What other related error link with it For Xerox Document Centre II C3000 photocopier.
  • Anonymous Mar 31, 2009
    hi iam using xrox work centre 7232 erro code 101-333
    President:
  • 2,072 Answers
Are you sure it is a Xerox model and not Canon?
I can not find a Xerox c3000 no matter where I look.
Posted on Apr 30, 2008
How do i fix the error code 6000 in kyocera 3060?
C6000 : Fuser heater break.
Fuser thermistor 1 detected less than
40°C/104°F for 10 s during warm-up and ready in.
Defective fuser heater M or S.
-Replace the fuser heater M or S.
Installation defectiveness on fuser thermistor 1.
-Check the mounting state of the fuser thermistor 1. If any problem is found, repair it.
Defective fuser thermostat.
-Replace the fuser thermostat.
Defective PWB.
-Replace the power source PWB or engine PWB and check for correct operation.
After parts replacement (fusing unit), you need to clear the fuser error code by going in the tech mode (10871087) and then U163.
Dec 19, 2015 | Kyocera Office Equipment & Supplies
Dell 1600n low heat error
Remove the fuser lamp and put it back in place, it is not heating properly.
Apr 02, 2008 | Dell 1600n All-In-One Laser Printer
Error E000
Since you listed error code E000, I assume you are talking about a Canon copier. The fuser assembly failed to heat up and the code needs to be reset in service mode. If the code cannot be reset , you need a new fuser or parts for the fuser unit. Always list the Brand and model to receive the most complete answer.
Sep 03, 2014 | Office Equipment & Supplies
What is error code #02-000 on Samsung SCX4623F and how can I fix it?
Dear
Its related to the fuser assy. Pl. check the fuser thermostat and heating lamp. for if its open replace it, check the thermistor resistance if it open replace it, Check SMPS.
Thanks.
Oct 05, 2010 | Samsung SCX4623F Laser All-in-One Printer
MY COPIER (KYOCERA 1635) DISPLAS ERROR C6050. HOW
C6050 Abnormally low fuser unit thermistor temperature The fuser temperature remains below 90°C/194°F for 1 s. Poor contact in the thermistor connector terminals. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Broken fuser thermistor wire. Measure the resistance. If it is ∞ ω, replace the fuser thermistor. Fuser thermistor installed incorrectly. Check and reinstall if necessary. Fuser thermostat triggered. Check for continuity. If none, replace the fuser thermostat. Fuser heater M or S installed incorrectly. Check and reinstall if necessary. Broken fuser heater M or S wire. Check for continuity. If none, replace the fuser heater M or S. Code Contents Remarks Causes Check procedures/corrective measures
Apr 09, 2010 | Copystar CS-1620 Copier
Fuser error 924.01
924 .01
Open thermistor check
failure. Fuser page
count between 0 and
99,999.
• Noisy thermistor signal.
• Intermittent connection.
• Thermistor cable not connected or
thermistor actually open.
Go to “924.xx—Hot fuser
service check” on page 2-91.
Error Code 923.xx, 924.xx, and 925.xx may display for a hot fuser failure.
CAUTION: .The fuser may be hot, use caution before removing or servicing.
CAUTION: There is a danger from hazardous voltage in the area of the printer where you are
working. Unplug the printer before you begin, or use caution if the printer must receive power in
order to perform the task.
Service tip: Set the Fuser Temperature to NORMAL before starting this service check. In Diagnostics mode, In
Diagnostics mode, select EP SETUP, and Fuser Temp.
1 Fuser assembly
Fuser to system board
cable
Check the thermistor cable for correct installation to J5 on the fuser
card. If installed correctly, check for correct installation of J10 on the
system board. If all cables are installed correctly, go to step 2.
2 Fuser top cover assembly
(thermistor/thermistor cable
assembly)
Turn the printer off and disconnect the thermistor cable from J5 on
the fuser board. Measure the resistance between the two pins on the
thermistor cable, if the resistance measures infinity (open circuit),
replace the fuser top cover assembly.
3 Fuser to system board
cable.
System board
Fuser assembly
Reconnect the thermistor cable to J5 on the fuser board. Disconnect
the fuser to system board cable from J10 on the system board and
measure the resistance between J10-3 and J10-4 on the cable. If the
resistance measures infinity (open circuit) check the continuity of
pins 3 and 4 of the cable. If correct, replace the fuser assembly. See
“Fuser assembly removal” on page 4-26. If incorrect, replace the
fuser to system board cable.
Note: If the error code still displays, replace the system board. See
“System board and inner shield removal” on page 4-76.
Most likely just replace the fuser (part of usage kit)
Enter Diagnostic mode:
1. Press and hold (Down Arrow) and (Up Arrow).
2. Turn on the printer.
3. Release the buttons when Performing Self Test displays.
Mar 29, 2010 | IBM Infoprint 1572 Laser Printer
ERROR SC545
This error code indicates a fuser unit malfunction. Most likely it will at least need new thermistors. Thermistors read the temperature of the fusing rollers. This code means the thermistors thought the unit was too hot. For this reason I am hesitant to give you the service mode reset procedure as you could do further damage.
Good Luck
Nov 27, 2009 | Ricoh Aficio 2022 Black and White Copier
Dell 1815dn error code "open heat error?
Disassemble fuser and inspect thermistor, thermostat and heat lamp. Replace broken part.
Oct 29, 2009 | Dell 1815dn All-In-One Laser Printer
"Low Heat Error"
Thats probably the best way to solve the solution. Sometimes if there is a thermistor that is causing the problem that can be serviceable in the fuser unit, that can be replaced instead of purchasing a whole new fuser assembly. It's less expensive replacing the thermistor.
Jul 16, 2008 | Samsung CLP-600N Laser Printer
Error code e002
Refers to a problem in the fuser assy. Could be a blown thermistor or lamp. Remove fuser assy & check continuity on thermistor & lamps. Lamps must be disconnected to test. Error will have to be reset in service mode after replacing bad component.
Jun 02, 2008 | Canon NP 6551 Black and White Copier
1,627 people viewed this question
jasbo
jasbo
