I am trying to replace a belt on an amana washing machine and i do not know how to get the belt onto the motor pulley. there isn't room above or below. the shaft from the motor goes through the center of the pulley. help!
  • 487 Answers
If i am not mistaken the motor is hooked up with 2 bolts . Remove one of them and losen the other so you have a little room to move the motor. As soon as the belt is on you can tention it again and replace the bolts
Posted on Apr 30, 2008
Need to replace the main belt on the bottom of the washer. The belt goes around the drive pulley directly below the electric motor which is accessible from the front bottom access panel. The belt goes...
Unplug the motor wiring, remove the bolts holding the motor bracket (4 I think) remove the hoses from the pump and lift the motor and pump out. Remove the 3 screws on the pump and separate from the motor. Put the belt on the pulley and replace the pump. Slide the motor and pump back in with the belt attached, but don't put the 4 bolts on until you put the belt over the tub pulley. Then put them in and plug the wiring back onto the motor. That should do it!
Nov 20, 2010 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
I don't know how to get the belt on the small pulley
If the design of this unit is the water pump is in the front directly below the motor, you have to install one of the pump plastic legs between the belt. when installing new belt. There are torex screws holding the pump onto the motor. This is assuming your belt burnt off or broke and you are replacing the belt. The small idler pulley can be worked on by running the belt on the big pulley when reinstalling the motor Try not to stretch the spring for the idler pulley,
hope this helps
May 27, 2010 | Amana DLW330RA Top Load Washer
Install belt on Amana top load washing machine
Use the correct sized belt!!
Loosen the Motor mounting Bolts. ( Do not take it off ) Now the motor assembly can be moved towards the opposite large pulley.
Replace the belt in this position and slide the motor to it's original position. You adjust it in such away so that, the belt is not too tight or loose!
Apr 05, 2010 | Amana ALW895 Top Load Washer
I need to replace the belt
You shouldn't have to remove the pump to replace the belt. The motor mount can be loosened and the motor moved so the belt will fit over all pulleys without removing the components.
Loosen motor, move it in, install belt, move motor out to correct belt tension, tighten motor mounts.
May 28, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Belt amana washer replace mod lw6501w2
I have a similar amana top load washer and just changed the belt. Here are the steps I used to change the belt:
1) Unplug the washer
2) Slide the washer away from the wall about 12"
3) Remove two screws from the bottom of the front panel, slide the front panel down (there are 2 metal tabs that slide into slots on the top of the front panel - observe how they slide into/out of the slots). Set the panel aside.
4) Remove the electrical connector (upper left of motor). Press down on the top of the plastic connector - this will undo the catch hook holding the connection in place). Observe how the belt is routed before proceeding.
5) Remove 4 bolts holding the motor in place. You can remove the motor - even with the water pump and hoses in place - they will flex.
6) Remove the water pump from the motor. There are 3 torx - head screws to remove. Note: You will need a star shaped (torx) head driver (Looks like a screwdriver but with a "star" head on it. The one I used measured just under 3/16 in diameter.
7) carefully remove the water pump. - remove the old belt from main pulley under washer drum and also from the water pump. Insert the new belt - be sure to put the tension pulley on the outside of the belt.
8) Reinstall the water pump to the motor. Reinstall the motor. Route the belt correctly in the water pump body area first - them slide the belt around the left side of the main drum pulley - rotate the pulley counter-clockwise and the pulley will tug the belt onto the pulley. Once in place - check bolts and belt - then reattach the electrical connector (remember to press the plastic lever on top of the plastic connector before sliding it in place). Reattach front panel - slide the top of the panel onto the metal tabs - then attach screws at the bottom.
Feb 23, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Replacing belt
Put The Belt On The Motor First Then Put What You Can Get Of The Belt On The Other Pulley And Turn It. It Will Give You The Anchorage Needed To Put The Belt Back In Position. If This Doesn't Help Let Me Know And I Will Further Assist You.
Sincerely,
Michael Scott
Feb 10, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Zanussi Aqualux washing machine
the belt is a tight fit so you need some strength
remove top. loop belt over the motor pulley and start belt onto drum pulley. turn drum pulley and belt will work its way on. there is just enough room to do this
Oct 08, 2008 | Zanussi F1045W Front Load Washer
How do I replace the belt that makes the drum spin on a Hotpoint Ultima WF860 ?
The belt goes around the drum and onto the motor pulley. No need to loosen anything. Put tension on the belt and fit it onto the motor pulley by gently turning the motor and pushing the belt onto the pulley at the same time.
Oct 28, 2007 | Hotpoint Ultima WF860 Front Load Washer
Changing belt on washing machine, that broke
to change the belt you need to remove the pump attatched to the motor. the pump is held on by either spring clamps or in older models, torx (star) screws. I believe the size for the torx screws is #20. slip the belt over the motor pulley and around the tension pulley and finally around the transmission. reinstall the pump and you're good to go.
Aug 18, 2007 | Amana ALW540RA Top Load Washer
Washing Machines Logo
49 people viewed this question
Top Washing Machines Experts
