If you have a rubber smell that means that the belt is burning through. Several problems can be the case.
1 bearing of the drum ( check if it turns freely if so the bearing is ok)\
2 the belt is worn and need to be replaced.
3 carbon brushes in motor are worn
4 bearing in motor is gone
open the backside of the machine and check belt.
think that is your problem
Thanks, I will try it out this weekend.
IMY WASHER STOPPED SPINNING, BUT WAS STILL RUNNING. I WALKED INTO THE ROOM AND SMELLED RUBBER BURNING. I PLAYED WITH THE ON/OFF KNOB, AND WAS ABLE TO GET IT TO START BACK SPINNING, BUT IT HAS STOPPED AGAIN FOR GOOD. WATER RUNS IN AND DRAINS OUT WITH NO PROBLEM.
