My HP photosmart C 5200 printer did print photos but stopped.It gives the message that the paper needs to be changed. but I'm using photo paper which is what I've been using.Also the tray that the paper is in seems to be jammed.How does one open it without damageing the printer? Also get the message that the paper needs to be aligned which it does'nt do.
  • Anonymous Aug 18, 2008
    clean rollers
  • Anonymous Sep 01, 2008
    My HP photosmart 5200 all- in- one series does not have a manual nor instructions on how to edit photos for reprinting. I had a scanner that put all the instructions on the monitor with many options for editing. There are a few instructions on the little 2" x 1-1/2" viewer? or whatever it's called. but nothing adequate. Am I missing something?
  • 975 Answers
Theres a back door to check and clean the rollers .
Posted on Apr 30, 2008
Will the hp photosmart printer use 8x10 photo paper?
You will have to check the equipment driver itself. While attempting to print, try changing the page size (go to page setup). This will give you an idea.
Sep 07, 2014 | HP PHOTOSMART 7520 E-ALL-IN-ONE
I am trying to print a 4x6 on my HP C4280 all in one printer. I have changed the settings, I keep getting an inky mess. Do I need to use a certain type of photo paper? I have tried changing the...
I use HP Premium Photo paper, 4x6 with tab. Also, there is Photo ink cartridges available for this printer.
http://tinyurl.com/photoink
Also, use the HP Photosmart Essentials program to print the photos.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Apr 01, 2011 | HP Photosmart C4280 Aio Printer
Hi...I have a problem with my HP Photosmart C7280...can you help ? the error message "Photo tray problem" keeps coming up, telling me to "lift the output tray, push the photo tray all the...
Photo tray problem
' Lift the output tray up and verify that the photo tray
' is pushed in until it stops, then lower output all the
' way down. Press OK button on the printer to
'continue printing
HP Photosmart C7280 All-in-One Printer
1. Turn off printer.
2. Pull out paper tray and photo tray
3. Remove output duplexer (on back of printer)
4. Open input sheet feeder (on top of printer)
5. Open cartridge access door. (Basically lift up control panel and scanner section of the printer)
6. Turn on printer (Power button on now raised control panel)
7. Printer may display message "Performing printer alignment - Do not interrupt"
8. Wait for a few minutes until printer stops making all setup noises.
9. Close cartridge access door, close input sheet feeder, replace output duplexer, insert paper trays
10. Do a test print. All should be fine.
Mar 11, 2011 | Office Equipment & Supplies
Wont print 4 x 6 photos. message place paper face down. It is face down ands I've tried both ways. no success. same message each time
Go to the setup section in the menu of your printer and select the kind of paper you are using to print ("everyday photo", "photo semigloss", etc.)
Jun 05, 2010 | HP Photosmart C6180 All-In-One InkJet...
Printing 4x6 photos with photosmart express - prints only 4x5 image on 4x6 paper
Hi
the photo printing settings will need to be changed on the PC to either the correct paper size or change the paper size to match the size of the print out
Apr 10, 2010 | HP Photosmart C6100 All-In-One Printer
HP Photosmart C5280 doesn't print photo
my steven
u need to chek setting of pritner in pc when u do pritner command it's show pritner propaty this is capple of options like in cd pritner on photo 4x6 also give all setting u have to chek this setting it's help u
Jan 09, 2009 | HP Photosmart C5280 InkJet Printer
HP Photosmart C5180 (wont accept photo paper but will normal paper)
Load the printer with the slick glossy paper face down. See if it will print.
Jun 06, 2017 | HP Photosmart C5180 All-In-One InkJet...
Mac Leopard OS: Can't print from photo tray
Here's the trick. It took me an hour to figure this puzzle out myself. DO NOT select the Print icon at the bottom of iPhoto. Do NOT select Print from the File menu. DO select EXPORT from the File menu. Select the HP Photosmart Mac tab Select HP Photosmart Print.app from the app selector. Click the Export button. HP Photosmart Print.app will load with a new print dialog box. Make all necessary selections. This is where you can select the Photo Tray as the tray for the printer to take paper from. This solved MY problem! Let us know if this helps you!
Randy
Apr 14, 2008 | HP Photosmart C5180 All-In-One InkJet...
602 people viewed this question
jasbo
jasbo
