Question about HP Officejet 4355 All-In-One InkJet Printer
Printer installation I have printer with I don't have hardware for installation, can i install on line n how I have to do? will u help me step by step I'm do realy goon in that?
  • Anonymous May 04, 2008
    i lost the installation cd
  • 975 Answers
Go to www.hp.com , enter on product num. officejet 4335 , and follow the steps from there to download the installation program , please rate this solution , thanks
Posted on Apr 30, 2008
Can some one call me. I have a new printer. Help
How may I assist you?
For first-time install, I would suggest you install the printer driver first before doing anything else with the printer. If you have the install disc, just insert it into your computer hard drive and simply follow the instructions on your computer screen. The software comes with a step-by-step instructions on how to setup the printer itself.
If you don't have the install disc, please visit the Lexmark website to download and install the Lexmark X2600 Series printer driver on your computer.
I hope this information has been helpful.
Sep 03, 2011 | Lexmark X2600 InkJet Printer
I accidently deleted my printer and don't know how to re-install it. I am a novice so please help.my printer isa Epson Stylus Photo RX420
Hi ebonyatnight ,
If you have accidentally deleted your printer there is no need to panic as it could be resintalled very easily , please follow the below steps :-
  1. Unplug the printer from your pc , and restart your pc.
  2. After your system boots up , plug in your printer in the USB or ethernet port as per your printer's cable.
  3. You will find a message as new hardware found , and it will ask you for the driver's location for this hardware.
  4. Now you need to install the driver using the driver cd that came along with the printer when you bought it.
  5. Insert the driver cd and it could probably have an autorun function for the printer to be installed which would make things easy for you.
  6. In case there is not such a function , then you just need to select the cd drive in the add new hardware wizard's location for driver option and select ok , so that it will search for the driver files automatically.
Hope this helps ...:)
May 10, 2011 | Office Equipment & Supplies
When installing the software it comes up with,,, "can not find device"
Don’t connect the printer usb cable first
1st you install the driver disc which is come along with the printer and when the software prompt you to connect the cable then plug the usb cable and follow the instruction.
Also I suggest you to change the usb port and the cable also still if you facing the problem follow these steps, right click on my computer and go to properties then hardware in that click on device manger and check there is any other device is listed if it is there just remove it and click for scan for hardware changes when he prompt for driver reinstall the driver cd.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 22, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
I cannot seem to install my printer ... can you help?? I have an HP Pavilion desktop a 1620n and my printer is an hp psc 2175 all-in-one printer* copier* scanner
if you already install the driver
kindly uninstall the printer driver and software restart the system and don’t connect the usb cable 1st install the driver cd and when it prompt you for connect the usb cable then connect it and follow the instruction. It will resolve your problem.
Feb 03, 2010 | HP PSC 2175 All-In-One InkJet Printer
Unable to load drivers of samsung 1640
make sure in system windows installer service is running.to check it is running or not ,in run window type services.msc and the go to windows installer option .if it is stop then restart it and then try again.
to install the printer follow this steps,
Dec 10, 2009 | Samsung ML-1640 Monochrome Laser Printer
MY LEXMARK X550 PRINTER WILL NOT INSTALL. I HAVE
Nov 17, 2009 | Lexmark X2550 All-In-One Printer
I DO NOT THE CD TO INSTALL PRINTER PROGRAM WHAT CAN IDO
hi friend,
the following are the steps to install a printer without cd
step 1
Place the computer and printer next to each other and make sure that all the wires are connected to both the printer and the computer.
  • Step 2 Turn the computer on and wait for it to boot up.
  • Step 3 Plug the printer into the wall and then take the USB cord that is attached to the printer and plug it into the appropriate port on the computer.
  • Step 4 Turn the printer on.
  • Step 5 Click on "Start menu" and go to the "Control panel".
  • Step 6 Find "Printers and hardware" box and click on it.
  • Step 7 Take mouse and click "Add printer".
  • Step 8 When you see "Welcome to the add printer wizard," hit "Next."
  • Step 9 Click "Automatically detect and install plug and play printer" on the add printer wizard page. Click "Next."
  • Step 10 Installing the printer will begin if the network can automatically detect it. Otherwise, the message unable to detect will pop up and you will be prompted to install the printer manually. Click "Next."
  • Step 11 Select printer port. Use the recommended port for best set up options. Click "Next."
  • Step 12 Pick manufacturer and printer. Click "Next."
  • Step 13 Type a name or confirm name if it appears in the box and set printer as default printer if wish. Click "Next."
  • Step 14 Print a test page to be sure printer is set up and on line. Click "Next."
  • Step 15 Receive a successful completion of installation of printer message. Click "Finish"
  • hope this helps u
    thank u for using fixya
    please rate me..................
    regards
    sivaranjini
    Sep 14, 2009 | Lexmark X1150 All-In-One InkJet Printer
    How do install the service center without a disk
    hi friend,
    Instructions
    1. Step 1 Place the computer and printer next to each other and make sure that all the wires are connected to both the printer and the computer.
    2. Step 2 Turn the computer on and wait for it to boot up.
    3. Step 3 Plug the printer into the wall and then take the USB cord that is attached to the printer and plug it into the appropriate port on the computer.
    4. Step 4 Turn the printer on.
    5. Step 5 Click on "Start menu" and go to the "Control panel".
    6. Step 6 Find "Printers and hardware" box and click on it.
    7. Step 7 Take mouse and click "Add printer".
    8. Step 8 When you see "Welcome to the add printer wizard," hit "Next."
    9. Step 9 Click "Automatically detect and install plug and play printer" on the add printer wizard page. Click "Next."
    10. Step 10 Installing the printer will begin if the network can automatically detect it. Otherwise, the message unable to detect will pop up and you will be prompted to install the printer manually. Click "Next."
    11. Step 11 Select printer port. Use the recommended port for best set up options. Click "Next."
    12. Step 12 Pick manufacturer and printer. Click "Next."
    13. Step 13 Type a name or confirm name if it appears in the box and set printer as default printer if wish. Click "Next."
    14. Step 14 Print a test page to be sure printer is set up and on line. Click "Next."
    15. Step 15 Receive a successful completion of installation of printer message. Click "Finish."
    regards,
    sivaranjini
    Aug 10, 2009 | Lexmark X2600 InkJet Printer
    Installing in progress, cannot install anything while programs are being installed
    unplug printer from your pc then restart the pc. then connect the cable to pc then if your printer found u get new hardware found wizard then insert your cd into rom then clik on "yes this time only"in new hardware found wizard.then it automatic get driver from cd.also u can manually install driver with browse the folder.
    Sep 20, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
    Scaner is not working of hp3055 color laserjet printer
    Step 1:. Check Hardware Driver Installed Properly
    - My Computer-Properties-Hardware-Device Manager
    - If Yellow mark in printer and Scanner field, the Printer
    driver not installed properly.
    - So reinstall Printer Software
    Step 2: If Scanner Option only not working,
    - Go to Scanner Settings(Start-Programs.....)
    - Choose Correct Scanner Name.
    Or
    - Press the Scanner button in hp 3055
    - If Hardware driver was installed correctly, its automatically
    deduct on your PC
    Jul 02, 2008 | HP Color LaserJet 2600n Printer
    HP Officejet 4355 All-In-One InkJet Printer Logo
    Seeker5211
    Seeker5211
    mukhtar21 shaikh
    mukhtar21 shaikh
