Question about RCA R52WH73 Projection Television
RCA52WH73 color issue
I have a month old, (replaced by RCA for bad tube in original RCA52WH73), RCA52WH73. It appears that the red tube has gone out but I don't know. Everything has a green tint to it and I cannot fix it by adjusting the color. I'm wondering if I there is a way that I can check and see if it is a tube or maybe a fuse somewhere. The set has a convergance option which I have done twice since I noticed the green, to no avail.
  • gamblin461 Apr 30, 2008
    It also had the infamous "loud pitched squeal" in the back, when turned on that I no longer hear since the green tint.....
    Problem Solver:
  • 10 Answers
Time to contact RCA again. Either you have been unlucky enough to have a second tube fail or you have had a color driver ic fail. Either way time to contact RCA for another replacement.
Posted on Jul 02, 2008
Green picture only
The projection TV has 3 guns RED GREEN BLUE. In your case the red and the blue guns are gone. So you are getting the green color screen. You got to replace the picture tube.
Jul 25, 2009 | RCA TruFlat 27F520T 27" TV
17 yr. old 35" RCA loses color intermittently. Picture & sound ok
Three guns Red Blue and Green in the picture tube of an old CRT set. If one of the guns goes out it effects that color. Sounds like one of the guns inside of the tube is going out, To costly to replace for such an old antilog set that will have to have a convertor box next month anyway.
Jan 12, 2009 | RCA 15L500TD 15 in. TV/DVD Combo
No color on tv screen
Repalce your tubes they are bad Red,blue,and the Green.
Dec 19, 2008 | RCA Televison & Video
Rca 62" PROJECTION FLATSCREEN - COLOR PROBLEM/FLICKERING SCREEN
Sounds like the red picture tube could be shorting internally which would cause the "all red" condition. In which case you'd have to replace the red tube. Are there horizontal (slightly slanted) lines through the picture as well when this is happening and a very very bright screen? If so it's most likely the tube.
Oct 06, 2008 | RCA F36645 TV
Toshiba colours gone wrong
Yes it is repairable. One of two things is wrong. The color wheel is going bad or the DMD board is going bad. These are the most common repairs needed for a Toshiba. I hope this will help.
Mar 23, 2008 | Televison & Video
Screen Green Tint
Turn down your color and see if the screen has a normal black & white screen. If it doesn't then the CRT is bad (picture tube). If it is black & White then you have a either lost your red or blue.That problem will be in your video driver circuit of which a service center can handle.
Feb 18, 2008 | RCA 20V500T 20" TV
I have a 10 year old 52 inch
This might be a bad focus block/g2 block sometimes they go bad, they arent real easy to change out, but can be done.
Jul 09, 2007 | RCA P52960 52" Rear Projection Television
Poor color issues.
try adjusting the convergence. good luck and happy valentine!
Feb 14, 2007 | Sony KP-53S65 53" Rear Projection...
RCA 25: television
Sounds to me like a bad picture tube with circle rainbow like colors.Good luck.
Sep 03, 2006 | RCA F25423 25" TV
Screen colour missing
this problem could be a few things. first if you know how touse a volt metter go to the crt pcb on the end of the picture tube. Try to measer the voltage on the collector of the red drive transistor. If when the red color goes away and the voltage shoots way up past 150 or so volts then the red drive is disapearing from the video jungle ic or through one of the componets from it. If the voltage drops way low like less then 65 to 75 volts or less then theres a cold solder connection between the b+ feed resistor that suppys the b+ to the drive transistor the driver power supply sourse.. In an extremely rare case would the Picture tube be at fault but certainly could be. Good Luck OOps almost forgot it could als be a bad connection on the crt socket as well..
Apr 05, 2006 | RCA 27F530T 27" TV
RCA R52WH73 Projection Television Logo
51 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
