Question about HP Pavilion dv6000z Notebook
My power comes on my laptop but screen is dark
Can you get info off hard drive if screen is dark?
    Genius:
  • 1,027 Answers
First, Plug in an external monitor.
Press <FN> <F4> to toggle between lcd and external monitor to see if it will light an external display.
if that does not work...check your numbers on the bottom against this list. HP knows of flaws on the DV6000X. I loaned a friend a laptop so he could send his in for repair. If the number matches your laptop you are eligible for free repair.
Posted on Apr 30, 2008
Could my hard drive be then reason for the blue screen, the screen is a dark blue and the icons are light blue
no you have icons which indicate the hard drive is working
try changing the back ground color of the screen or resetting the personalization of the screen
Jan 07, 2018 | The Computers & Internet
Dark screen
Have you tried turning of the Laptop, removing the battery, pressing the power button for 15 sec and then put it all back together and turn it on. I find this helps with a lot of issues.
to back up your drive you can remove the hard drive and plug it into a docking station like the "Hytec All in One".
Mar 20, 2014 | Acer Computers & Internet
HP 2000 POWER BTN FLSAHES DARK SCREEN
Try removing the power supply, battery, hard drive and RAM. Plug in the power supply and press power. If the screen recovers, add the RAM followed by hard drive. If it stops working at any point, that is the issue. If it still doesn't work, I suspect a GPU issue. (Possible overheating). If it now works, maybe a bad connection.
Dec 30, 2013 | Computers & Internet
Dell 620 dark screen blinking cursor
You hard drive is missing from the system. Or, just does not recognize it. The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB... Remove the hard drive and reseat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Nov 10, 2012 | Computers & Internet
How to copy my computer info to the external drive
if you mean all the system components and files,you should use cloning software...but if the info you mean,click start>then click run>type dxdiag>then click the "save all information" and place it to destop>then copy and paste to your external drive...
don't forget to rate...gudluck..
Feb 12, 2011 | SimpleTech Signature Mini 320GB External...
Hp pavillion tx2000 all lights are on - hard
That's a very common issue with that model, You will have to reflow the GPU with a heatgun. You can find more info from http://www.msbin.com if needed.
Oct 15, 2009 | HP Pavilion dv6000z Notebook
I have a dark screen on my laptop with just the
Either your hard drive is bad and needs to be replaced, or you have corrupt windows files. You can try running a repair by booting from the windows CD, or just simply re-install windows, but you will lose all data if you reinstall.
If you can't boot into safe mode then you have serious problems with the files on your hard drive, so try one of the 3 things and it should get fixed.(Try the repair first)
Sep 11, 2009 | Acer Aspire 4720 Notebook
IR Problem
needs new hard drive, new reinstalation of vista or xp. the problem is it passes Bios but it doesnt load the operating system, it passed the video graphic permission.
can you replace hard drive yourself?
Jul 30, 2009 | Dell Latitude D600 Notebook
Sounds like start, but screen stays dark,
Not even beeping? Hard to tell from such little info. HDD doesn't work, CPU stays cold, that would indicate a motherboard problem, but then it would beep most of the times. It can be a a problem with your screen, but that doesn't add upp with the HDD, and the CPU staying cool (bye the way, how do you know that?)
I think you should take it to someone who can take a closer look on it.
Jun 11, 2009 | Computers & Internet
Laptop screen goes dark after booting .
your issue with your laptop is a faulty ccfl BackLight Inverter, the display uses the backlight to illuminate the lcd screen, the inverter is used to illuminate the cold cathode light in the back of ther lcd theirs countless places to laern about it on google.
They are cheap to replace google your model with inverter at the end..
They are not too hard to replace
Nov 21, 2008 | Dell Latitude CP (0001849d-38380-968-p06e)...
HP Pavilion dv6000z Notebook Logo
102 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
