Question about Kenmore 56562 / 56564 / 565 / 6656569 Side by Side Refrigerator
Food gets spoiled too soon
I have Kenmore Side By Side Refrigerator. Model: 56562400. The refrigerator section is set to 35 F. The section feels cold enough (Also checked with thermometer, it shows the inside temperature as 35 degrees F, but the food gets spoiled too soon. The freezer section is set to 0F and works fine. Please advise.
  • 487 Answers
The problem is gas build up in your fridge
use arm and hammer baking soda boxes for the fridge.
that will help a lot
Posted on Apr 30, 2008
What are the perfect temperatures settings for the refrigerator section and the freezer section??
PERFECT no such thing . preferred would be a better term . freezer has to be below 0 15 degrees usually and fridge around 35 to 40 . not freezing but not too warm or food will spoil
Jan 10, 2016 | Kenmore Refrigerators
Why is my kenmore freezer cold, but refrigerator not even when set at highest temp?
Hello Donna;
My name is peter. I am a retired field service refrigeration technician.
You have not provided your unit model number, which is located in your fresh food section on a label, on the side wall near the top.
You only have one cooling source, and that is your freezer. Your freezer feeds your fresh food section. This is through a direct air vent.
Reach into your fresh food section where the air vent from the freezer goes into the fresh food section. Do you feel cool air? Probably not.
So, either the air vent is frozen up with ice which you can clear with a hair dryer, or you have a automatic air vent motor/ sensor assembly that is bad.
Give me more information and I will help you.
Jan 21, 2015 | Kenmore Refrigerators
The refrigerator side has sweat running down the side of wall next to the freezer forming water in the bottom. the temperture goes between 41% to 48%. the food spoils. what is wrong?
Without a model number, I could only guess that the automatic damper door that lets cold air in from the freezer section is broken, frozen shut, or just not operational. The refrigerator receives it's cold air from the freezer section. If the freezer is operating correctly, I would asume the damper door is not functioning. Pleazer Appliance...
Jun 06, 2014 | GE Monogram Side by Side Refrigerator
The refrigerator side of my Maytag, model MZD2766GE, is warm. The freezer is working fine. I feel cold air coming out by the crispers at the bottom but no cold air coming out at the top. HELP...Single...
If sounds like the top cold air tube is frosted up. If you remove the rear shield over the evaporator coil you will see the tube opening. If you use a hair dryer (not of the hottest setting) and blow hot air down the tube you should be able to clear it.
Jan 31, 2012 | Maytag MZD2766GES Side by Side...
I have an older side by side kenmore and the fridge wont go lower than 50.. I am afraid my food is going to spoil
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 16, 2010 | Kenmore 44393 Side by Side Refrigerator
Food at bottom of fridge freezes
Bad cold control switch.
The cold control switch should open when the set temperature has been reached. If the control does not open and turn the compressor off, it will continue to run and freeze items in the refrigerator section.
If the control is not closing, the compressor and all fans will stop operating. Check the control for continuity. If you don't feel comfortable checking this yourself, get a repair person out to check it out.
Hope this helps.
Aug 07, 2009 | Kenmore Refrigerators
Each side won't get cold. food starts to spoil
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control
Jul 13, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Need help on my kenmore refrigerator
hjave you cleaned the coils underneith lately, also when your doing the check toi see if the fan in thje back is working.
Jan 25, 2009 | Kenmore 53642 / 53644 Side by Side...
Kenmore 56562 / 56564 / 565 / 6656569 Side by Side Refrigerator Logo
157 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
