Question about Kitchen Ranges
I have a Westinghouse Freestyle Multi-Function Wall Oven - 667. How do I set the clock?
Ok. I actually just kept pressing the buttons until numbers started scrolling up and down. Once the numbers appeared without the bell symbol you are then setting the clock time.
thanks
Posted on Apr 30, 2008
How to adjust flame on Westinghouse freestyle gas oven
The flame is regulated by the thermostat you don't say if it's too high or too low. Suggest you buy an oven thermometer available for a few dollars at most homeware shops, compare the temperatures then you will see if the thermostat is working or not.
Apr 22, 2014 | Cooktops
My Westinghouse multi function oven has an A flashing on the clock and no number of combinations can turn it off the oven wont work while its there
Try unplugging it for a couple of minutes. Assuming there's no major problems with it, that should reset it.
Feb 17, 2013 | Ovens
Manual for a Westinghouse oven 667.
The manual you are looking for is over here:
http://manuals.appliancesonline.com.au/westinghouse-electric-wall-ovens/westinghouse_electric_wall_ovens_manual.pdf
The manual includes multiple ovens including yours.
Mar 28, 2012 | Ovens
Westinghouse oven GWH 476 SLP Multifunction. The pilot cones on but not igniting ? no gas getting through
Hi RMSINN,
Believe it or not, the clock has to be set before the oven will light.
To set the clock, instead of using function names for buttons, we'll just call them buttons 1 through 6 going from left to right.
Push buttons 1 and 2 at the same time. You're now in clock setting mode. Push buttons 5 and 6 to make the clock go minus and plus.
Cheers
SG
Sep 21, 2010 | Ovens
I have a Westinghouse 678 freestyle.the element remains on. It may be due to the setting of the clock or timer. i do not have a manual to regulate either as this was not left by the previous owner. could...
I also have the same oven, it turns itself on at random at heats up, also is the oven door easy to remove for cleaning, I dont have a manual either
Jun 29, 2010 | Ovens
What does F- mean on my jenn air expressions electric wall oven? If it means what I think, then this is the 4th failure in 10 years. This just can't be right!
Common fault codes:
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
Display Condition Remedy
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
May 22, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Need an instruction manual for Westinghouse freestyle 745 wall oven, preferably in PDF, having trouble setting the clock. Can you help please?
instructions-manuals.com/search.php?...WESTINGHOUSE%20FREESTYLE...FREESTYLE%20920%20DISHWASHER
safemanuals.com/index_upload.php
www.manualsnguides.com/search.php?...WESTINGHOUSE%20FREESTYLE......
You can copy and paste any of the above links in your internet address bar under a new tab to bring you to your manual
Nov 12, 2009 | Ovens
Instruction manual for Westinghouse wall oven
Obtained info from retailer
Jun 22, 2009 | Ovens
Westinghouse Freestyle 476 Cooktop Oven
After getting an electrician out, apparently the time needs to be set on the oven. As we're in a rental & don't have a manual/ couldn't download one, we got it to work after holding the first two buttons in (the timer buton + the one that looks like a hot pot) along with the + button at the far right, which made the tim tick on, so it could be set.
The oven works now! : )
Aug 20, 2008 | Ovens
Setting clock on Westinghouse WST3501 microwave oven
Normally you would press Clock, enter the desired numbers, then hit Clock or Start. Try it with door open and with door closed.
Otherwise, contact Westinghouse Small Kitchen Appliances at 800-947-3745 or see http://www.saltoninc.com/contact/contact.html
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 10, 2007 | Westinghouse WST3504 Microwave Oven
Kitchen Ranges Logo
629 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
