Question about Kicker Solo-Baric L5 Car Subwoofer
12" l5 no sound
I have 2 12" L5 and they just stoped working. I hooked them up to my friends amp and still no sound even though his sub works just fine. what wrong?
  • ste b May 17, 2008
    I have a L5 solo
    baric 10" and i have being using it for a while and it just stoped working
  • Anonymous Jun 11, 2008
    Hey i just bought my Kicker L5 12"...I hooked it up right and there is no sound coming out of it. i spent like 350 bucks and it doesn't work. I was wondering if anyone could tell me how to fix it or what is wrong with it?
    Email me at brettwallace17@hotmail.com thank you
  • 790 Answers
Hi
maybe your voice coil is open circuit! or you have burn voice coil! thats why your unit is not functioning!
Thanks!!!!
Posted on Apr 30, 2008
Need An amp for 2, 4ohm Kicker 12" L5
i bought two Audiobahn A2300hcx on ebay for a little over 400. look around on ebay you can really score sometime dirt cheap........ Check out audiobahn amps, never did me any wrong...........
May 06, 2010 | Kicker Solo-Baric L5 Car Subwoofer
I have 2 kicker L5 subs and they are blown the
Yes you replace both voice coils. Get parts from another speaker but has to be equle in quality.
Apr 19, 2010 | Kicker Solo-Baric L5 Car Subwoofer
Kicker subs hook up problems
Connect one to each channel, for the best sound.
Jan 05, 2010 | Kicker Solo-Baric L5 Car Subwoofer
How do i make my two l5 10 subs sounds with clear
Try these:
Make sure the gain isn't set too high. That's a very common cause of distortion. You'll never want it set above 3/4 of the way to high. It will be a small dial on your amp marked "gain".
See if your receiver has a built in crossover on the channel your amp is hooked up to and set it so the cut off is at 400hz if possible. Meaning that the receiver will only send frequencies of 450hz or lower to your amp
Look on the amp for a built in crossover to the channel your amp is hooked to and set it to 450hz.
Make sure the cable that connects your amp to your stereo isn't running near any power cables of any kind because electricity running through a power cable can be picked up and then the sound it makes will be amplified, sent to your subs and cause distortion.
Make sure your amplifier isn't grounded to
your battery as this can cause what's called ground loop noise...also distortion.
Ground your amp as far away from the amp itself and your subs as the manufacturer safely recommends.
If none of those help then i'll try again :)
Apr 06, 2009 | Kicker Solo-Baric L5 Car Subwoofer
Solo x 10 dual 2 ohm smells burnt and smoke
there is no such speaker as a solo-X L5.
The Solobaric L5 is 450Watts RMS and 900 Peak.
Check your documentation, and no warranty except Massive Audio covers Burned Voicecoils as it is deemed customer abuse.
If it is a typo, and not an L5, your combination (as long as each is level matched) should be ok to run on that sub. When wiring it as you describe, the two amplifiers need to be identically matched in order for both coils to play at the same level.
Seek professional installations so your warranty is intact.
Dec 21, 2008 | Kicker Solo-Baric L5 Car Subwoofer
Kicker solobaric l5 12''
how to wire a kicker solo baric l5 12'' 4ohm down 2 and 1 ohm
Sep 25, 2007 | Car Audio & Video
Kicker Solo-Baric L5 Car Subwoofer Logo
188 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
