Question about Kenwood DV-605 Multi-disc DVD Player
Tray will not open on my dv-605
Tray will not open to load disq.
  • arboc Nov 18, 2008
    Power is on, LCD says "loading" but cannot open the disk tray. All 5 disk lights are on at same time. It's like it is frozen,
  • arboc May 11, 2010
    Hey Z-Dawg,
    I really appreciate your input. Sadly, I just about went crazy not being able to open the darn thing...checked into what it might cost which would be about 300% more than what I paid for it, cuz it was a gift, used. So I gave it to Radio Shack for parts and bought another one for 50 bucks. I wish I could have tried your solution to see if that were the problem.
    Thanks bunches.
    arboc
Solution: Unplug power from wall. (Don't just turn off!) Next: Remove exterior case. Now gently turn the CD changer clockwise one position. Power up and try again.
I had this same problem after unit appeared to have froze up when unpacked from a shipping box. The CD changer had got off track and by gently moving the CD changer 1 position it fixed the problem. Works fine now.
Best of luck,
Z-Dawg
Posted on Dec 07, 2008
KONCICA MINOLTA BIZHUB C258 PAPER TRAY 1 WON'T OPEN AFTER LOADING PAPER
go to service mode ,
trouble isolation
choose Tray 1 to unset...
Restart copier
Aug 13, 2016 | Konica Minolta bizhub Office Equipment &...
DVD Tray will not stay closed
There is a leaf switch inside the loading mechanism, which detects the tray to fully closed state. If this switch has damaged, this kind of fault will occur. To repair it, you have to open the set, and take the loading mechanism out, and disassemble it. If you wish to get some details, check the site linked here.Pull up older posts.
Dec 06, 2013 | Haier TDC1314S TV
Panasonic BTT268 tray wont open
Dear Scott,
If there is a CD stuck inside a CD/DVD reader, you could try using a medium sized paper clip straightened up. Insert it in the small hole in the front of the DVD player bezel and push it till it opens the mechanism. Please, have a look at: http://www.youtube.com/watch?v=fa_4CsS7MKw
The problem can also be caused if one of the rubber band that moves the DVD drive "door" has dried out, or even if the power supply in not properly connected to the drive.
Hope you may find this info hopeful!
Best regards,
Miguel Luiz Martins
Nov 19, 2013 | Kenwood DV-605 Multi-disc DVD Player
Kenwood CD/DVD player moder DV-605 tray is jammed, how can I manually resease it
you have to play the disc in another player or you can change the type of the disc.. the player is just not compatible with your disc.
Dec 08, 2012 | managemylife.com
Unknown disq error
if you get that on all discs either a dirty optical pickup or a bad one.
Apr 12, 2012 | Televison & Video
Tray won't open
by just resetting the software will not work this is a mechanical problem this usually happens on players that is not use for a long time or improper closing of tray..fixing this kind of problem requires opening the cover of the unit..you need to lubricate all moving gears and parts by putting enough amount of lubricating oil..you have also need to assist the motor manually by helping it to push the tray out just gently pull the tray with your hands during a eject command on the unit clean also the limit switches of the tray make that contact are properly working..good luck!
Apr 06, 2012 | Kenwood DV-605 Multi-disc DVD Player
I close the tray. DVD player immediately re-opens the tray and leaves it open. If I repeat, it does too. I just did the firmware upgrade, still re-opens the tray. Samsung bd-c5900/xaa.
Check and replace the loading belt, then check for alignment of the tray and tray sensor. You may be able to replace the belt without taking the DVD player apart but you will need to take it apart if the tray needs to be removed and then realigned to the loading mechanism.
Usually, the tray needs to be removed, carefully, then turn the loading gears all the way back and then slide the tray back into position. All of this with the unit unplugged of course. Sometimes the belt. The belt tension and size need to be perfect for the unit to open/close and load the disc correctly.
Jul 18, 2011 | Televison & Video
Player will not play a loaded CD and No CD message comes up Also CD drawer opens and shuts on it`s own !!!
the tray opening by itself could be a faulty limit switch on the tray mechanism
the switch tells the system if the tray has reached the open or closed position.
if it closes then opens itself then this is the most likely
check that first
could be closing then opening without actually loading due to the switch
you will need to open it up to find the switches
usually at the bottom front were the tray goes in
darren
May 28, 2011 | NAD C542 CD Player
Got a bizhub c550 and error code c-0206 came up and it just wont reboot or do anything. Help
This code means that your paper tray 3 is not lifting the paper properly. Usually this is because the paper is not loaded properly. Open then close the front door to reset the code then immediately open tray 3. Check to insure that the paper is loaded properly. I would remove all the paper and then re-load. Leave tray 3 open long enough to verify that the machine will warm up and make copies. Then close tray 3 and see if the code comes back. If not then you are good to go. If it comes back then there is a tray lift problem with tray 3 and it will need service. Open tray 3 and reset the machine again. You can leave tray 3 slightly open to at least be able to use the machine until it gets repaired.
Good Luck and Thank You for using Fixya.
Sep 09, 2010 | Office Equipment & Supplies
Kenwood DV-605 Multi-disc DVD Player Logo
349 people viewed this question
Top Kenwood Televison & Video Experts
Jaime Hernandez
Jerry Greenberg
Jerry Greenberg
Are you a Kenwood Televison and Video Expert? Answer questions, earn points and help others
