Remoet control fro my hitachi plasma tv, wont sitch on /off but does other options
The remoet code cle 960 wont turn the tv on/off however does do other options, eg change av number , battweries are changed and new
  • Anonymous Dec 03, 2008
    my TV wont turn on or off. but it will do the others. just not the on and off
  • 2,712 Answers
You can find the remote control codes for difrent brands of devices from
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Posted on May 02, 2008
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved.
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
      (Positive Rating)
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
      (Positive Rating)
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated. (Negative Rating)
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
    If your issue is not still not resolved, do not
How can I get the TV to set to hdmi?
If you have a Hitachi remote HL02121, that means your TV model number is either 32PD7800 or 42PD7800.
According to the Owner's Manual the HDMI connector is activated by going to AV6.
While in the TV mode on the remote, press the '' button with the AV6 above it. That will tell the TV to use the HDMI input.
IF you don't have access to the TV remote, there are INPUT SELECTION buttons on the TV near the Lower Left hand Corner of the cabinet. Press the INPUT SELECTION button until AV6 is displayed on the screen (HDMI Input)
Feb 19, 2016 | Hitachi CLE-960 Remote Control HL02121
How to work the hdmi
how do you set up the HDMI input on a hitachi tv model #51F59A ...
Jan 8, 2010 - i tried to hook up an HDMI devise but i cant set it on input HDMI it ... My TV has HDMI, Component and AV inputs, which one should i use for my ...
HDMI not working - Hitachi 50VS69A - AVS Forum ' Home Theater ...
Dec 1, 2007 - 7 posts - ‎2 authors
I have a Hitachi 50VS69A 50 RP LCD HDTV connected to a Dish Network receiver that the HDMI input is not working on. I have been using the ... Hitachi P50H401 - all HDMI ports are dead - HELP!
Oct 2, 2008
Hitachi 51/57/65F59A CRT RPTV Tweaks Thread
Jan 19, 2007
More results from
Dec 27, 2015 | Hitachi CLE-960 Remote Control HL02121
Hitachi CLE-984 PROBLEM heads cut off on screen
You have it zoomed in.. There should be a option on the remote
Apr 10, 2014 | Hitachi CLU-5713TSI Remote Control
Hitachi cle 1018A tv remote replacement remote
For replacement of Hitachi TV remote controls under warranty, including CLE-1018A (for TV model DF4000DV and perhaps others), you need to contact Tempo Australia, phone 02 9975 2199 or 1300 886 649 (you may need to stay on the line for more than 15 minutes before you can talk to someone). Hopefully they can also advise you on purchase of a remote control if you are not making a warranty claim.
Dec 23, 2013 | Hitachi Televison & Video
Manual tuning of Hitachi cle-942 tv
Select the channel to tune & press "CH" this is the key to the right of zero on the CLE-942 remote, Now you can tune the selected channel. You also need this key to sort/move channels after running auto tune.
Aug 20, 2009 | Hitachi HL01453 Remote Control
Hitachi CLE-976 problem.
The CLE-976 was no a cellular phone but a remote control for a Plasma TV. I contacted Hitachi Australia who put me into contact with a company that sell spares.
Aug 04, 2009 | Sprint Hitachi P300 Cellular Phone
I have a remote to a hitachi 42 inch plasma TV that went bad, remote number/model is CLE-960... No one carries it... HELP...
You can check on ebay for this. They have many different options. You can also get a universal remote for the TV. If you buy one that learns, you can use a remote from Best Buy or somewhere that has the remote you are looking for.
Jul 04, 2009 | Hitachi Televison & Video
Enter channel number of double digits?
Are you being serious? Are there numbers on the remote? press 02 for channel two press 08 for channel eight press 10 for channel ten all the way up to 99 then back again.
May 30, 2009 | Hitachi CLU-5713TSI Remote Control
Code and instructions foremote radio shack 15-2114
I lost my manual for my remoet cat,no, 15-2114. Could someone help me with the code for a hitachi 60" TV?
Jan 11, 2008 | Radio Shack 15-2200 Remote Control
Hitachi cle-990
not sure your model number is correct please check here is a manual for the 42 CL plasma TV if it is a different set please check the model number, this should have a 42 in it (as it is 42")
Sep 27, 2007 | Televison & Video
Televison & Video Logo
278 people viewed this question
Top Televison & Video Experts
