Can you please describe your problem more briefly so that i can help you fix it.
Waiting for your reply..
Comments:
May 02, 2008
- if u want to bypass it the simplest way....just take the park brake
ground, and ground it to the same spot as the main ground for the head
unit. problem solved...
Tthere is 1 wire that is suppose to go to your emergency brake, just ground it in with your ground wire in your wire harness.
I hope that helps
Please rate accordingly
Thank you
Computerrep
Hi can i just ask 2 quick questions1 With ignition switched off and no key in it does the dvd player come on 2If it does come on then check for me that it switches off when you release the handbrake
Their is a safety wire going to the earth on the handbrake ok this would need moving and earthing somewhere else but getting this wrong could either blow a fuse or worse blow the player, Also do you still have the wiring instructions or ont
The motorized face plate on my Kenwood KRC-X858 only sits at the half-way point. When I take the...
(More)
The motorized face plate on my Kenwood KRC-X858 only sits at the half-way point. When I take the face plate off the back rotates to the appropriate position. Remount the face plate and the system hangs at the laf
My Durabrand DB1200 Car stereo/cd player is stuck on mute. I don't have the remote to it. There is...
(More)
My Durabrand DB1200 Car stereo/cd player is stuck on mute. I don't have the remote to it. There is no cd stuck in it. How do I get it off mute without the remote?
I need a wiring harness guide to install this stereo in a 1972 MGB. I have no idea where the...
(More)
I need a wiring harness guide to install this stereo in a 1972 MGB. I have no idea where the different colored wires are supposed to attach.
I got a used car last year with a Kenwood KDC-692 CD-Reciever installed. Yesterday, my battery died...
(More)
I got a used car last year with a Kenwood KDC-692 CD-Reciever installed. Yesterday, my battery died in cold weather. Upon jumping the car, the Kenwood asked for a security code. I have no idea what the previous owner programmed. Is there any way to bypass this security?? thanks. -Derek
