Question about Motorola Mobility RAZR V3
Dead screen My screen doesn't work, I disassembled the phone and found the integrated ribbon type cable worn through in the "hinge" area. Is this replaceable? Or is it not even worth trying to fix? Phone still "works" fine.
  • mica_boudrea Dec 27, 2008
    My phone was working perfectly fine, and then when I got home after a long day, I just wanted to relax and text some friends, and then everytime I would close my phone, I would have to restart the whole phone. So then, I finally got into the habit of not closing the phone, it would stay open, and then before I went to bed, I closed it. And, the next morning I restarted it at least seven times, and the screen is still dead. It doesn't come on at all, I can play ringtones, and text, but I can't see anything on the screen. Someone help me, I can't get a new phone for a while. And, this one is giving me so much damn trouble. Helllpppppp !?
To replace that cable you have to disassemble the entire phone including the keyboard, screens and the lower part, then buy a new flex cable (this includes the keyboard, keyboard backlight, backlight driver, cover sensor, screen cable and connectors. all of this is part of one flex cable) and replace it.
You have a 70% chance of breaking the new cable even before getting the phone reassembled.
Posted on May 04, 2008
I need to know how the sreen wirering goes in a toshiba c655d-s5300
Usually located around the hinges.Be careful... Try removing the hinge clips there is a ribbon cable ...these can break easily.but check that the connection into the main board has not dislodged before inspecting the screen area.the screen housing clips together at the bevel edges.be aware that faults can just be failed backlight,,,,inventor,,,,loose connections ,,,,broken ribbon,,,,dead or cracked lcd.
Feb 19, 2015 | Toshiba Computers & Internet
Trying to set up just the amp & tapedeck of the Sony TA-AX335 integrated stereo system, but can't get the ribbon power cord to work.
Does the deck light-up at all, or is it completely dead? I've found that in aging tape decks, the belts will deteriorate, and change into tar. I've repaired several of the TA series Sony systems, and that's usually the case. If the deck is just 'dead,' I would recommend retrofitting standard RCA jacks on the back of the amplifier. The pins on the ribbon cable are clearly marked on the PC board inside the amp. Then, you could use any deck you want, or even a CD recorder. Hope this helps. :)
Apr 13, 2013 | Audio Players & Recorders
My screen scrambles and i can't get it right
The problem with the phone that is causing the screens scrambling is that the flexi ribbon that supports the slides of the phone is getting weak or worn out, therefore, fixing the flexi ribbon of the phone will correct the problem for you. You will have to disassemble the phone to be able to replace the phones flexi ribbon. If you are not familiar with such repairs, i will advice you seek assistance from a friend who is technically able to assist you with disassembling and reassembling the phone back together.
Hope this information helped.
Jan 07, 2011 | AT&T Quickfire Cell Phone
How to disassemble LG u8180
To disassemble your phone, please follow the steps below.
  • Turn your phone over so the battery cover is facing you. Remove the battery cover and battery. Next remove the 2 rubber stoppers (circled below) and unscrew the aerial.
  • Remove the 6 screws (circled below)
  • Next remove the 2 rubber stoppers & screws above the main screen (circled below)
  • Prise the back part away from the rest of the phone by running your fingernail between where the two parts meet (as shown below)
  • Your phone should now look like the picture below. Unclip the ribbon (circled below)
  • After removing the ribbon cable (above), carefully lift the metal part indicated by the arrow above. Another ribbon will be attached which should be carefully removed. Take the circuit board & keypad out and you'll be left with what's below. Next remove the top part of the phone by pushing the housing in whilst pulling the hinge, which the top part is attached via, away from the phone. This is the hardest part and you'll need to bend and manipulate the housing the get the hinge out. Be firm but be careful so you don't snap the housing.
  • Your phone will now be in two parts. To open the top half of the phone and get to the screen, run your fingernail fingernail between where the two parts of the housing meet (as shown below)
  • Your phone should now be as pictured below. The circled areas indicate where you'll need to remove the speaker and ringer in order to solder them to the new screen. The screen can be lifted away from the phone easily at this point.
  • Remove the LCD and replace with new. Reverse the procedure for disassembly and it's finished.
Take care and good luck
Take note, the pictures are that of lg u8120, it has the same disassemble process as lg u8180
Oct 27, 2010 | Cell Phones
Razr v3x screen suddenly won't work even with phone turned on. Yesterday it was working just fine then this morning lcd is dead. I can hear it when somebody sends me an sms but I cannot read it since...
check the oem ribbon that runs to screen. the design of phone hinge is faulty, and usually cuts the ribbon that runs up to the screen after months of openings and closings,preventing it from lighting up. sometimes its the earpiece wires on the ribbon that get cut which prohibits u from hearing anything when u hold the phone to your ear and u have to switch to speaker...bummer..sooo my friend, CHECK THE RIBBON.
Mar 11, 2009 | Motorola Mobility RAZR V3x Cellular Phone
How to repair broken hinge of my Verizon LG Vx8350
I was able to take apart a VX8350 I have with a broken screen. I don't see any way to replace just the hinges with replacing the whole top part of the phone including the screen. The ribbon cable from the screen runs through the hinge part into the main assembly of the phone. It appears the cable can't be removed without cutting it.
Jan 11, 2009 | LG VX8350 Cellular Phone
Broken top screen (original DS)
Replying to the first post:
If you have broken the ribbon cable, which is highly likely if you have broken the hinge, then the DS will not work. It does not turn on unless there is a connection to both screens. You will need to buy a new ribbon cable for it:
A useful site I found is: www.consoleparts4u.co.uk
Once you replace this then it should work for you.
Repling to th second post:
I would recommend buying a new case for it at least because the ribbon cable will break if left broken due to the strain on it.
The more expensive but easier option is to buy a new one.
Hope this helps,
Mowcius
Jun 16, 2008 | Nintendo DS Console
7" LCD Video screen Ribbon Cable - need replacement - can anyone help?
You may be able to find a comparable cable on some other brand, but Cyberhome seems to be defunct. An alternative is to find another unit of the same make and brand and scavenge what you need...accordianman
Jan 04, 2008 | Cyberhome CH-LDV 700B Portable DVD Player
Samsung sgh-d807
Remove battery cover and battery. There are four small screws visible on the rear cover, remove those. Wiggle and distort the back cover a little at the bottom of the phone until it pull partly free from the phone, slide a guitar pick or small flat blade screwdriver between the phone and the rear cover, at the side of the phone, pry this cover off until it snaps free. You will see the main board now. Remove the two screws holding this board on, carefully fold it back towards the battery area. The main ribbon cable is visible now. Remove a green tape on the socket where the ribbon cable joins the board. pull the ribbon away from the board gently and use a screwdriver or something else to cut the adhesive between the board and the cable. The socket has a hinged brown piece closest to where the cable comes in, that flips up to release the cable. The small cable coming from the number pad is removed by gently prying up the rectangular connector from the board. Now with the board free you can remove six screws from the plastic backing plate, and remove that plate from the slider assembly (one of the screws is hidden by a piece of green tape). On the front half of the phone there are six small screws on the rear side (the camera side). Four are visible, two are hidden behind rubber plugs at the top of the phone. Separate the chrome trim from the backing plate by starting at the bottom of the phone, by the key pad, and it may be stuck from a little day-to-day dirt but separate it there, then swing the bottom end out and release the front cover from the two clips that hold the top end together. You now can separate the ribbon cable from the screen assembly in a similar way as you did with the other end of the cable. Reassembly is the reverse of disassembly. Be sure to replace the pieces of tape, and the wire mesh shield attached to them, they serve to prevent radio frequency interference between parts of this device, and between this device and others.
Good luck, and happy dreams.
Nov 05, 2007 | Samsung SGH-d807 Cellular Phone
White screen
Your flex cable has most likely gone bad. If the phone is under 1 yr. old I would suggest have it repaired by a warranty repair facility. If you are going to try replacing yourself let me know, I will try to help w/ disassembly. Good luck.
Sep 11, 2007 | Motorola Mobility E815
Motorola Mobility RAZR V3 Logo
178 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
