Make sure your plug is properly hooked up identify ground green i think then switch the other two
That is physically not possible!
1. immediatelly switch off saw
2. remove cord from the plug
3. remove blade from machine
4. reverse blade 180degree and install it in direction of the rotation! if you look at saw from the blade side, rotation is clockwise!!! and cutting edge of teh teeth should point clockwise!
5. install and tighten the blade
6. plug in and switch in short burst only, check if it is rotating in proper direction and blade have teeth in proper direction
7. make test cut
Do not forget that this is not a toy, blade on circular saw cut through wood, metal and your fingers... always wear googles or eye/face protection shield, you have only two eyes and no spares...
Enjoy your woodworking experience! Always observe safety and machine rules.
Hope this allow you to fix the problem. Please leave note how did you go.
