Question about Dryers
I HAVE A KENMOR DRYER MODEL NUMBER GGQ8811LL0 AND I CANT OPEN THE FRON ACCES PANEL I DONT KNOW HOW
  • 172 Answers
Hello Velasco,
You have what is known as a dott dryer and to open the control panel you should take a flat blade screw driver and slide it straight into the groove above the bottom panel. about 2-3 inches from each side. when you find the small clamp you should simply push the screwdriver straight into the clamp. Pull out on the side of the panel and it will open. Please make sure to disconnect all power before you open the unit as there will be wires that you could touch. Good luck and I hope this helped.
Posted on Apr 30, 2008
Dryer will not come on after setting timer and pushing start. No light when door is open.
Most likely the door switch is bad. Listen for a click when the door is just opened or closed. Noclick = bad door switch. The number you passed is NOT the model number. The model number will have 3 digits followed by a period and up to 8 more digiits after the period. i.e 110.xxxxyyyy or 110.Cxxx.yyy (examples only as it can be other numbers depending on the manufacturer.) There are other numbers starting with 417 and 665 also.
This is what I think your model number is: 11064672400
The door switch is item 41 below link: PN 3406107
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-11064672400/0582/0151200/K0404036/00002?blt=06&prst=&shdMod=
Detailed view:
http://www.searspartsdirect.com/partsdirect/part-number/Kenmore-Parts/Dryer-Parts/3406107/0026/110/Model-11064672400/0582/0151200?keySuffixId=NA&productTypeId=x&searchModelNumber=11064672400&subCompDesc=Cabinet%20parts&brandDesc=KENMORE&modelDesc=RESIDENTIAL-DRYER&blt=11
This manual will help you:
http://applianceassistant.com/pdf/27gasElectricDryers.pdf
The top has to be opened and the front panel taken lose and tipped out to change the door switch.
The manual is not straight forward as to the sequence of remofing things but you remove the top... open the toe panel loosen the lower front panel screws and then take out the 2 upper mounting screws for the front panel to gain acccess to the door switch. POWER OFF at the CB or dryer unplugged of course!
Thanks for choosing FixYa,
Kelly
Jun 25, 2011 | Kenmore 64672 Electric Dryer
Kenmore dryer,, looking for adiagram for the belt on a kenmore dryer
Below are the belt diagrams for Kenmore dryers.
Figure 1. Whirlpool-made Kenmore dryers with removable back panel, filter on top, and model numbers starting with 110 or C110.
Figure 2. Whirlpool-made Kenmore dryers with non-removable back panel, filter below the door, and model numbers starting with 110 or C110.
Figure 3. Frigidaire-made Kenmore dryers (model numbers starting with 417).
Mar 01, 2011 | Kenmore Dryers
Kenmore dryer M#110.82822103 The dryer dosen't stop by itself after times up until open the door. Please advise me. Thanks
You need a new timer. This is the mechanism behind the control knob. Call your local appliance parts dealer with your model number an he will give you a price, you can take it fron there.
Mar 15, 2010 | Kenmore Dryers
We need parts for a dryer but do not know the model
The model number on Kenmore Dryers is located on a nameplate on the door facing as you open the dryer door. The number should be prefixed by "110". Hope this helps you.
Feb 15, 2010 | Kenmore Dryers
Where is the heating element in the kenmore dryer
It depends upon the model number.
Most Kenmore dryer elements are accessible after you remove the rear panel of the dryer.
If your dryer does not have a removable rear panel you must open the top lid and remove the front panel.
Jan 16, 2010 | Kenmore Dryers
Dryer won't heat
hey first you would have to take it apart for some reason i cant find a picture of your dryer to tell you exactly how to do so  so please if you can find a the right picture on sears.com or abt or some picture where i can see how it looks so i can tell you how to take it apart and how to fix it its pretty easy so just get me a picture please
and this model number gave me like 50 different dryer, washer  so i dont know if you got every number correct
Jun 09, 2009 | Kenmore Dryers
Broke start button
Look inside door and get the model number for me. Replacing the start switch is easy. From back cover inside the top control panel. Let me know, Thanks Sea Breeze
Mar 20, 2009 | GE Dryers
How do I remove fron panel
Try taking off the top of the dryer. This will give you easier access to the front portion of the dryer. I know it is the long way around, but it is the easiest.
Jan 10, 2009 | Kenmore 659 Electric Dryer
Dryer not heating
what is the model #the heater is not in the back of the he4.
Oct 21, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Dryer Model #110-86467810
remove bottom acces panel from under door, close door adnhook one end of sprinf to lower frame and other end around loop in hinge
Feb 21, 2008 | Kenmore 659 Electric Dryer
Dryers Logo
42 people viewed this question
Top Dryers Experts
