Question about Sharp MD-MS702 Personal MiniDisc Player
Sharp MD-MS702 Minidisc recorder - no audio from 3.5 mm output jack...
There is playback signal on the LCD display. The unit records audio. It's just that no sound is heard from the mini audio output jack. I've tried several sets of headphones and listening monitors.
I have this problem too, i cant get it to work. can anybody help?
Posted on Mar 05, 2010
The solution which seems to have worked for most people is to take the unit apart and make sure that the ribbon cables inside the unit are all attached properly.
Marcus
Posted on Feb 17, 2009
What does utoc error mean on a Kenwood mini disc player
Well, what it means is
TOC errors often mean the recording head/optical block is cooked. A cleaner might work, but often it's the end of the MDR.
Are you sure the battery is correctly (fully) charged? Try removing the battery and running on (only) the charger.
try cleaning the lens with a minidisc lens cleaner.
open the unit and check the laser position - it should be all the way to the left. that's where it should start to read the disk.
Read these:
https://groups.google.com/forum/#!topic/alt.audio.minidisc/63uCBegyG8A
http://www.minidisc.org/repair_q2.html
http://forums.sonyinsider.com/topic/21439-fun-with-the-sharp-702-utoc-error-fixed/
http://www.mazdas247.com/forum/showthread.php?98358-TOC-Error-on-brand-new-disc!
http://www.borus.de/minidisc/303.htm
Jul 07, 2014 | Sharp MD-MS702 Personal MiniDisc Player
Sharp MD MS 702 shows sound is being recorded but on playback shows blank disc, what could be the problem?
That does not sound good. Being optimistic, though, what happens if you record something and then finalize it? Will it play then?
Will it play a previously recorded MD?
Feb 09, 2013 | Sharp MD-MS702 Personal MiniDisc Player
Kenwood MD plays ok but recordings fail to play; U TOC error?
Without a decent Table Of Contents, your MiniDisc will NOT work, as you've found out. Does it matter what brand of MD you use? I would record it at "1X" and NOT 4x speed too. Try erasing a blank minidisc first and then shut off the unit and then turn it back on and see if the TOC works. Try adding a title, then turn it off and back on. Then try the CD to MD.
Jan 16, 2010 | Audio Players & Recorders
TOC ERRORa
When you FINISH recording, the Minidisc recorder Writes the TOC (Table of Contents) - so you see it flashing TOC or Update when you finish recording - you need to Leave POWER ON and have the unit on for about 30 seconds for it to finish this. IF you don't, the unit doesn't know where to find the files since there is no TOC. Try a Sony home unit - you might get one more shot at it working with that.
Aug 19, 2009 | Sharp MD-MS702 Personal MiniDisc Player
I recorded analog music on md.now how can i transfer analog music to pc and chanege it to digital music on memory of pc.
Your analogue music will have been recorded digitally by your machine.
Digital transfers are only possible from the host pc/Mac to the player and not the other way around.
But you can transfer the audio signal by connecting the headphone output to the Mac audio input; look into the Minidisc player menu and you can set the headphone socket to "line" which bypasses the volume control circuits for better quality, your computer will then re-convert the analogue input into a digital signal with a small loss of quality.
May 04, 2009 | Sony Net MD Walkman MZ-N510 MiniDisc...
Record/playback
Run audio INTO the MD play in the L & R IN jacks.
For playback, run (RCA phono plug cables) from the L & R OUT to your amplifier AUX or TAPE inputs. Try playback working first, then add the record function.
Mar 26, 2009 | Audio Players & Recorders
MD Error Message
I'm sorry this isn't much help, but I had the same problem with my 702 unit. From what I've read it's very common with this model - Sharp claims to have remedied the error with their 831 unit. Luckily, when I had this problem, my recorder was still under warranty and I have to say that Sharp fixed it promptly and returned it to me. Have you tried contacting them? Since it's a design flaw, they might be amenable to working something out with you...
May 27, 2008 | Sharp MD-MS702 Personal MiniDisc Player
Sharp MD-MS702 Personal MiniDisc Player Logo
198 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
